Question about Garden
Bitron 25 uv pond filter - Garden
3 Suggested Answers
SOURCE: Missing a owners manual for a Garden Treasures biological filter
I have the manual, and I can scan it as PDF, but dunno how to send it to you.  I guess this site won't want us to post email. The Canister is very easy to use, just DO NOT remove the metal tension seal ring.  To prep it, you first have to remove the 4+1 top screws; remove the top part (be careful do not pry the clear plastic cover off, that should stay intact); plug the UV in its socket and carefully insert the UV light into the center chamber; reassemble the top with 4+1 screws; attach the two cone-shape nozzles to the "In" and "Out" of the canister, if you use 3/8" tubing for the pump, then no need to cut the nozzles, if you use 1/2" tubing, then cut the 3/8" section off, likewise for the 3/4" tubing, make sure the In and Out should have the same flow to balance the pressure inside the canister; turn the handle to "Work" plug the tube from the pump into "In" and connect the "Out" with the tube return to the pond or water fall; Turn on the water pump and plug in the UV light (use GFCI), wait 30 secs, and you should see the flow from the return tubing. Note:  use a 650+ gph bump at least; DO NOT submerge the canister in the water; put the canister on an even surface; cover the canister against rain and moisture.  My 800-gallon "green" pond clears up in 7-days. Good luck!
M
Posted on May 21, 2009
  • 10865 Answers
SOURCE: Tetra Pond GreenFree 9W UV Clarifier
Hello. Get a tube of plumbers GOOP. Joe
Posted on May 02, 2010
How do i go about replacing the uv light
obtain proper replacement bulb
shut down entire filter for a moment before unscrewing the top locking ring off Uv filter (left turn) lift top off set asside
using a soft clean rag retract uv tube from its cylinder holder inside , remove power connector from tube end (you should have already removed all power from converter box) with extremely clean rag handle new tube ( allow no forign material to touch outside of tube ) reinsert power connector onto new tube (same way it came off old one) then reinsert tube into holder sleeve , route power cord to proper places away from lid , replace lid and install lock ring back with enough force to ensure a leak proof seal , re start pump ck for leaks if none found then restart power converter for Uv filter
Jun 05, 2015 | Sunterra 300207 Pond UV BioFilter 2000...
Filter works fine, except one side where it clamps down is leaking. Other than that it works great and I don't want to replace it. Any ideas?
Is there a gasket or o-ring that is damaged or bad? IF not you can run a bead of silicon around it where the surfaces join and let it dry before you put it together. This would make a gasket.
Apr 18, 2015 | Tetra Pond Bp4000-uv Koi Pond Bead...
WHY DOES THE FISHMATE FILTER HAVE 2 POWER LEADS
One lead is for the pump/filter the other is for the UV sterilizer.
Mar 22, 2011 | Fish Mate Pressurized Filter with UVC and...
How do you change the uv bulb in a hozelock vorton 2200
remove the 2 screws at the end of the unit and pull the end off.the bulb is attached and will come out with it.pull the bulb out uf the holder and replace.(on mine the screws have 2 differnent heads on for some unknown reason)
Apr 18, 2009 | RTO Vorton UVC500 Clarifier For 500gal...
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
