Question about Scubapro G250 2nd stage and Mark 10 1st stage regulators serviced and upgraded
Chevy van left rear running light no working - Scubapro G250 2nd stage and Mark 10 1st stage regulators serviced and upgraded
What to do right side runing light is working. Left is not 1996 voyeger van
Chexk fuses first. Some vehicles have seperate fusing for left and right lighting circuits. Which specific lights are you referring to? Daytime running lights (that would be dim headlight on only...no tail or parking light), parking lights (front and rear), fog lights? The term running light is used br people for different light s
Jul 13, 2016 | Cars & Trucks
2000 chevy express van, no brake lights; left, right and above rear door. Tail lights good and signals all work.
probably a fuse. if the fuses are good check the brake light switch on the brake pedal.
Mar 10, 2014 | 1998 Chevrolet Express
Turn signal
reach up from the outside under the rear drivers side the wires you will see go through a opening in the panel .the wires break here every time the opening rubs through the insulation it corrodes and stopps working . fixxed this problem probley 30 times .
Nov 21, 2013 | Motorsports
Running light problem on chevy express 3500 box van
Vehicle electric trouble shooting is the worst. Some of the problems you described the bulbs may have multiple filiments with only some burned out. It may sound silly but change the bulbs. Get a couple of new bulbs and try them in the different spots. Time, road vibrations and spring pressure causes the contacts on the bulbs to wear until they get a poor connection then you get a little arcing that build up a residue and a bulb that test good doesn't work.
Your on the right track with the ground wire. Try a test lamp with a good gound connection and test the different sockets, if your test light works but your bulb doesn't you have a ground fault. If neither work check the switch and fuse before you start tracing the wiring. These are just general trouble shooting tips It's very hard to trouble shoot electrical problems sight unseen.
Jun 13, 2010 | 2002 Chevrolet Express
Have to replace a chevy uplander 2008 left rear (passenger side) tail light assembly -- how to?
open rear hatch and will see the access screws un screw careful not to drop and pull away like opening a door and assembly is free from van
Jun 10, 2010 | 2008 Chevrolet Uplander
2009 cargo van chevy 2500-- cant find fuse for left directionals
first never plug back in to that trailer, it may have bad wiring, the next thing to do is to check the front and rear bulbs, they may have blown,if it was a fuse the signal inside would not blink,so this tells me you may have blown the bulbs,and also this trailer is unhooked from the van and lights still dont work?. good luck.
Mar 21, 2010 | 2009 Chevrolet Traverse
Where can i find a stereo wiring diagram for a 2001 chevy astro van without having to pay for it ?
I couldn't find a 2001 but I think this will work
2000 Chevrolet Astro Van Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Feb 03, 2010 | 2001 Chevrolet Astro
93 chevy g20 van interior lights not working
Auto Zone, Discount Auto, Pep Boys
Sep 16, 2009 | Cars & Trucks
I have a99 Express 12 pass. van i get backfire and lack of pickup until i get to about 40mph sometimes and then others times it just runs fine.
2002 Chevy Express Van>>>>with headlights off--the rear left taillight works, but no right. When the brakes are stepped on, both taillights don't work. Also, the little lights under the back doors are out. Also, some lights are dim>>rear only.
Nov 05, 2008 | 2001 Chevrolet Express
2002 Astro van ventilation fan problems.
The problem is a 1/8 diameter hose that runs from the front of the engine over the top and connects at the rear of engine on the drivers side. It is a vacuum hose #GM15967970 It cost about $6.22 at your GM dealer. Hope this helps Bill. My E-Mail is Uflyups@aol.com
Jul 14, 2008 | 2002 Chevrolet Astro
Scubapro G250 2nd stage and Mark 10 1st stage regulators serviced and upgraded Logo
223 people viewed this question
Top Scubapro Clothing Experts
Erin Wood
Erin Wood
shuyumeng
shuyumeng
treeeee
treeeee
Are you a Scubapro Clothing Expert? Answer questions, earn points and help others
