Question about Cannon Office Equipment & Supplies
Crease in page when printing cannon image runner 1310
I am getting a crease down the center of the paper when going through the printer. Can you help?
    Scholar:
  • 34 Answers
A crease is usually caused by two issues. 1 ) paper is hitting something on the way to the fuser causing a skew. This type of problem would be repeatable every page as well as causing the image to be off centre. The 2) reason is the more likely cause. A bearing on the lower (pressure roller) is beginning to seize. Causing paper not to feed straight through the fuser. This cause a wrinkle from from to back on the sheet of paper. This wrinkle although repeatable generally the wrinkle position up or down on the sheet. This gives the impression of something that is getting in the way of the sheet. If you can change your lower pressure bearings you should be ok again.
Posted on Nov 10, 2013
3 Suggested Answers
Soulvisitor
  • 1113 Answers
SOURCE: Printed paper is creased
First thing to check is try it with a fresh unopened ream of quality paper, paper with too much moisture content, drys out and goes wavy when it runs threw the fuser roller at rear (180 deg), otherwise it will be the fuser rollers themselves causing your problem, which means that you need to replace fuser assy
Posted on Dec 05, 2007
BigdaddyTDW
  • 62 Answers
SOURCE: Printer is creating a crease and smudge down center of page.
There sounds like there is somthing in the path of the printhead. Using a flash light, remove back cover of machine and look for a small piece of paper,etc. Be careful not to jam anything in to th machine. It may take running a thick piece of paper through manually with your hands to remove the object.
Posted on Feb 12, 2009
Crease in paper when printing
Your information is a bit limited but we'll try anyway.
If the crease is a corner fold or a pressure line down the page, it will often be caused by something in the paper feed path close to the main drive bar in an inkjet or near the fuser in a laser printer. Have a look at the leading edge of the paper as it exits the printer for a nick or mark that may give a clue where to start looking. If there is a fold or crumple line down the length of the page, look at the paper pick up mechanism in an inkjet (usually the paper tray is a good start) or if it is a laser printer you should remove the fuser and check the fuser sleeve and pressure rollers. If you could let me know what the machine is and where the crease is I may be able to give better advice.
Jul 09, 2015 | Office Equipment & Supplies
Hp laser jet P2035N has a crease down the center of the page as the paper exits it is actually slightly raised so the print is smearing
Check to make certain that the fuser unit is not damaged. Often a crease or dimple is caused by foreign material on the fuser roller or the fuser is damaged. If the fuser is damaged, look into replacing the device, it may be cheaper than repairing the fuser.
Jan 31, 2013 | HEWLETT PACKARD - LASER JETS New - Hp...
Paper comes out creased on one side
If the printed image is smudged, as well as creased, you might have a torn Fuser fixing film.
You will need a technician to fix that.
If it is just a crease, just check that
1. Your paper is not damp. Try a fresh packet of paper
2. The paper input tray guides are set to the width of the apaer, to prevent the paper skewing as it feeds.
Good luck.
Jun 21, 2010 | HP LaserJet 1012 Printer
I am getting a crease on top-half, right hand side, when I print.
Your paper is probably getting caught on the roller or rollers need to be replaced. By having a certified technician do a maintenance cleaning this should resolve this issue.
Jun 07, 2010 | HP LaserJet 3030 All-In-One Printer
Feb 12, 2009 | HP LaserJet 1012 Printer
Appears to be a roller crease on the paper
i want the installation cd fo my printer HP PSC 1410
Jan 01, 2008 | HP PSC 1410 All-In-One InkJet Printer
Dec 05, 2007 | Samsung CLP 300 Laser Printer
52 people viewed this question
Top Cannon Office Equipment & Supplies Experts
Cosma Papouis
Cosma Papouis
Greg Cann
Greg Cann
Iqbal Husain
Iqbal Husain
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
