Question about Scuba Diving & Snorkeling
Face mask attachments - Scuba Diving & Snorkeling
How many time is normal mask life ?
it depends on the quality of the mask and it depends on how you stored it (if you leaved it at sunlight, if you washed it thoroughly after using it in the sea...)
i have a mid quality mask Mares mask, i have been using about 20 times for snorkeling, then i used it to take diving certifications in pool, then i used it for about other 20 dives in the sea... i always stored it in a dark bag (the mask is now about 8 years old)
you can check if you mask is still in good shape, and the silicone has not worn out, in this simple way: just put the mask on your face without straps.. remove all the air inside the mask by inhaling with your nose.. then look at your feet (keep inhaling): if the mask remains on your face you can keep using it
Apr 05, 2017 | Scuba Diving & Snorkeling
Tip
3 activated carbon Mask mask DIY
Activated charcoal - not to be confused with plain charcoal - has become a common ingredient in skin care products, due to its deep-cleansing properties. It can be found in facial soaps, masks, liquid cleansers, and even in makeup primers with the purpose of preventing your skin from getting oily. Activated charcoal, which is a form of processed carbon, has an adsorptive quality that allows it to bind to dirt, oil and environmental pollutants, lifting them from the skin. It's inexpensive and easy to find at pharmacies and health food stores, usually in the form of capsules or loose powder. You can mix it with your face cleanser for a deep cleanse or use with other ingredients to create simple, effective facial treatments.
Warning
Activated charcoal may stain your clothes. Before preparing any of these face masks consider changing your clothes. Make sure to wear something you don't mind getting dirty when you apply the mask to your face. If your clothes get stained, rinse them right away.
1. Gentle purifying mask
Quickly detox your pores with this easy-to-make mask, which harnesses charcoal's absorbing powers to remove impurities from your skin.
Things You'll Need
Activated charcoal (1 capsule or 1 Tbsp)
Aloe vera gel
In a bowl, mix 1 tablespoon of aloe vera gel with the content of 1 capsule of activated charcoal until it creates a smooth paste. Apply to the face avoiding the eye area. Keep the mask on the skin for 15 minutes and then rinse off completely. Repeat twice a week for optimal results.
2. Purifying Mask for Blemish-Prone Skin
Want to banish pimples? Use this purifying mask to prevent blemishes from becoming the bane of your existence.
Things You'll Need
Tea tree essential oil
Face oil (carrier)
Mix the content of 1 capsule of activated charcoal with 1 tablespoon of facial oil (like jojoba or grape seed) and 2 drops of tea tree oil. Apply to the face avoiding the eye area (tea tree can be irritating to the eyes). Keep the mask on the skin for 15 minutes and then rinse off completely. Repeat twice a week.
3. Deep Cleansing Mask
Clear your pore with this ultra-deep cleansing mask.
Things You'll Need
Clay powder
Face oil (carrier)
Face mask brush or mixing tool
Mix the content of 1 capsule of activated charcoal with 1 teaspoon of clay powder (choose the best one for your skin type), and 1 tablespoon of face oil, like jojoba or grape seed (you may also use avocado oil or olive oil). Apply to the face avoiding the eye area. Keep the mask on the skin for 10-15 minutes and then rinse off completely. Repeat up to twice a week.
on Mar 21, 2017 | Health & Beauty
My new KA2000 mouse sander's dust collection part keeps falling off with the vibration. Is it safe enough to do with out it?
the dust collector is normally attached to a vacuum cleaner to remove or limit the dust
you can use it but make sure that you have a properly fitted dust mask on your face
Apr 02, 2017 | Tools & Hardware - Others
Need a copyable face mask of Sesame Street's Big Bird
try this link for patters:
https://www.google.co.il/search?q=big+bird+mask&hl=en&tbm=isch&tbo=u&source=univ&sa=X&ei=wMpBUeaROILnswb-ooD4Aw&ved=0CDwQsAQ&biw=1680&bih=878#imgrc=_
Dec 01, 2012 | Rubies Costume Big Bird Plastic Face Mask...
What food item is an anagram of face mask
Hi gedbax2
According to Wikipedia the anagram of face mask is:
Please take time to rate me
maks
  1. Third-person singular simple present indicative form of mak.
Sep 02, 2011 | Computers & Internet
How do you assemble the face mask on this help?
use the tabs that come with the mask and bolt them to the pre-drilled mask holes.
Mar 02, 2011 | Rawlings Cfbh Coolflo Batting Helmet with...
How to use safe second with a Scubapro full face mask
Yu only need the octopus adapter kit to put on an octo and you can swap out should your primary reg **** out.
Feb 18, 2009 | Scubapro Full Face Mask, All
How to choose a scuba mask
"The shape of the scuba mask and the silicone skirt on the mask must conform to the shape of your face to provide you with a comfortable fit. Ensuring the silicone skirt is a high-grade, flexible silicone can help to ensure the scuba mask conforms to the shape of your face and the long life of your scuba mask. Some people are allergic to different types of rubber, if you have an allergy to rubber, be sure to choose a silicone scuba mask because silicone is hypoallergenic. Always talk to your scuba diving gear retailer about the alternatives available to you. When trying on scuba masks you will notice the different shapes of the nose pockets. The nose pocket protects and cushions your nose, helps to keep your scuba mask from fogging during a dive and helps you to maintain equalization. Ensure the size and shape of your nose pocket is comfortable; not too tight and not too large. This will improve not only the comfort of your scuba mask, but your ability to purge your mask efficiently. There are increasingly different styles of scuba mask straps on the market. You may like the factory issue strap on your scuba mask or you may want to purchase a separate strap. Scuba mask straps are available in a single strap or a double strap design. The single strap should wrap around the centre of the back of your head. The benefit of the double strap is that you can position the top strap on the upper part of your head and the bottom strap on the lower part of your head to offer extra stability and comfort. Most scuba mask straps are rubber or silicone and fasten with a post-hole belt enclosure. Newer scuba masks offer a slide-lock type enclosure, which allows you to adjust the scuba mask quickly and easily when wearing the mask. Scuba masks are constantly improving. If you wear prescription glasses or contact lenses on a daily basis you can purchase a scuba mask without having to wear your glasses or contact lenses under your mask. Many manufacturers will create custom scuba masks which include your prescription in the front lens. A good sign you have chosen the right scuba mask for your face is when the mask stays on your face comfortably without using the straps to hold it in place. You should try this simple test with each scuba mask you try on for the first time: See our choices for scuba masks 1. Place the scuba mask over your eyes and mouth ensuring the mask is in the correct position. 2. Take a quick, light breath in through your nose and immediately start to breathe through your mouth as if you are scuba diving. This will create a slight suction between the scuba mask and your face. The scuba mask should stay on your face. If you must push the scuba mask against your face, or inhale repeatedly to help the mask stay on your face, the mask is not a good fit. 3. Keep the scuba mask on your face for approximately one minute. This will help you to determine how tight the seal is and how comfortable the mask is on your face. 4. Exhale gently through your nose to release the seal on your scuba mask and remove the mask from your face. There should be no mark on your face from the scuba mask. If there is a red line around your face from the seal of the mask, the seal was too tight or the mask is not the proper size for your face. Try the test a second time. If you still have a red mark on your face after you remove the mask, you need to continue your search for a scuba mask. Remember, a good scuba mask is one that's comfortable, doesn't leak and is easy to use."
Dec 01, 2008 | Vision Mares Pure Mask
Scuba Diving & Snorkeling Logo
90 people viewed this question
Top Scuba Diving & Snorkeling Experts
David Bugden
David Bugden
ray gallant
Bill Boyd
Are you a Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
