Question about Atomix Productions Virtual DJ
Dixon abma3 dj mixer table
Purpose of dc 5a input
How do I open my mixer to repair the mic input jack
Gemini mixers are a hassle. You should take out all the phillips screws on the front, see if there4 are any on the side panels, and then see if it comes apart. If not, go for the screws on the back panel (the side and front /back ones). Be careful not to take out the one for the transformer (usually a big one or a nut). Peace.
Jun 09, 2015 | Gemini DJ Gemini MM-2400 4-Channel Stereo...
I am not getting sound thur my mixer what could be the problem.
Is there any hum sound? Are the switches set to the proper inputs-phono, line?
Feb 14, 2015 | Numark Im1 2-channel Pro Dj Mixer With...
Hey . just wondering how do i connect my phonic max 2500 amp to my Numark M6 USB mixer. then i will be connecting my laptop up to the mixer..
The M6 has balanced XLR outputs on the back, which can be connected directly to the XLR inputs on the back of the Phonic Max 2500. You just need two XLR cables.
Feb 20, 2013 | Numark M6usb M6 Usb Four Channel Table Top...
Put wrong power supply into unit
You probably blew it. It sounds like the power supply put out more voltage then needed. Also they come in AC/DC, putting AC into a DC input usually blows things, dC into an AC normally does not hurt it assuming the voltages are in range in all cases.
Jan 12, 2013 | American Audio VMS2 VMS702 Table Top MIDI...
How can i open the music file for my digital dj pro mixer
I don't know what you are trying to do. But your mixers needs analog inputs such as cd players or turntables.
Feb 12, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
How do I connect CDJ 800 to work on mixer AND surround speakers?
you did not mention that you have a power amplifier to drive your Speakers. well you need to have one unless you have a powered speaker. the sugnal comes from the mixer main output goes to the input of your amp. or powered speaker.
Feb 03, 2009 | Pioneer CDJ-800 Turntable
Connect turntables(technics SL1210MK5) to a mixer?
None. The cables are already attached to the turntable. They are hard wired to the unit. The red & White cable. Just connect to the PHONO INPUT on your DJ MIXER, and connect the thin ground wire to the GROUND terminal on the mixer. That's it your ready to go.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Dec 17, 2008 | Technics SL-1200MK2 Turntable
Dj deck
hello -  i purchase used xdm-352 mixers- working or not if you are interested -  give le a shout -  203-910-7903 John
May 07, 2008 | American DJ Q2422MKII 19" 3 Channel Mixer...
I'm have'n a problem
You should be connecting this product to a dj mixer because this unit has no internal mixer.To accomplish this you should connect the two outputs lines for channel 1 from this cd player to the two input lines on channel 1 of your mixer and the same for channel two, connect channel two from your cd player to the channel two input on your mixer and then hook your mixer to a amplifier, then amplifier to speakers. D.J Fire in Louisiana***
Oct 15, 2007 | American Audio DCD-PRO310
Hooking up a turn table
You should get a turntable adapter. They adjust the impedance so they can be plugged into a typical auxiliary input. Or you get a DJ mixer; most can do the same thing. I have an old Realistic Stereo mixer that does the job, and it has two phono inputs, as well as a Tape input. Very handy for this purpose. Go to Radio Shack if your budget is tight, but a pro DJ mixer would probably be the best solution for an audiophile.
Oct 24, 2006 | Yamaha HTR-5830 Receiver
Computers & Internet Logo
200 people viewed this question
Top Atomix Productions Computers & Internet Experts
David Payne
David Payne
Are you an Atomix Productions Computer and Internet Expert? Answer questions, earn points and help others
