Nc6000 will not power on and i have repaired it
Nc6000 will not power on and i have repaired it once.after a month the problem comes back,WHAT MAY BE WRONG WITH MY LAPTOP?PLSSSSSS I DONT MONEY TO KEEP REPAIRING IT.
  • 32,281 Answers
When you connect the power adapter into the laptop, does the power LED light up If not then
The battery adapter or the adapters power lead or the laptops power socket could be faulty.
Check power adapters DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power battery charging LED light and wriggle the power plug in the laptops power socket. If the power battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Posted on May 03, 2013
4 Suggested Answers
  • 3940 Answers
SOURCE: the reair center forgot to put my power cord back
Contact acer, see if they will send a replacement (866) 695-2237
Posted on Feb 25, 2010
Geekman
  • 32281 Answers
SOURCE: I bought a DELL LAPTOP 2 months back,now i realise
Get the Dell repaired under warranty, check if they will give you a replacement instead of a repair.
Posted on Aug 13, 2010
rinkunitesh
SOURCE: repair for power supply section for IBM Laptop R51
ibm thinkpad r50 power section
Posted on Oct 15, 2012
What the solution of laptop hp compaq nc6000 when turn on won't start up
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
http://www.chargerbuy.com/original-hp-compaq-nc6000-ac-adapter-65w-cord.html
http://www.chargerbuy.com/replacement-hp-compaq-nc6000-ac-adapter-18-5v-3-5a.html
Nov 13, 2012 | HP Compaq nc6000 Notebook
My hp nc6000 laptop wont boot up i need to reset it to factory setting
When you power on your laptop immediatly after powering on your laptop start pressing F8 key on your laptop keypad, after few seconds Advance boot options menu will appear in front of you in that menu select (repair my computer) option will take you to unother sub menu which will give you an option of load factory image.
Sep 02, 2011 | HEWLETT-PACKARD Hewlett Packard Compaq...
The problem is that when u start the laptop it will come on but after some time it goes and yet the indicator light will still be on and nothing will respond again. its hp nc6000 laptop
Hi Sir_chiks,
I see that you are epxeriencing a no boot no video issue on your Laptop.
Have you tried power cycling the Laptop, turn the Laptop OFF then unhook the AC ADapeter remove the battery then press and hold down the power button for about 15 seconds this should drian way all the reamaining power from the systemboard. once the power cycling is done. reconenct the Adapter and the battery on the Laptop and try turning it ON again see if the machien will boot back into windows.
If still the issue is the same, try going into the BIOS of your Laptop see if it will boot to the BIOS.
If the system boots to BIOS set the BIOS to defaults tehn restart the machine, but if it does not boot inot the BIOS then there is something wrong porbably with the motherboard.
I hope that this few detail can help.
Have a nice day,
mvincentc
May 06, 2011 | Computers & Internet
No sound after fixing a new hdd to hpcompaq nc6000 laptop.Why?
Why dont you reinstall all the drivers back on the system including the sound drivers.
It might help
Sep 23, 2010 | HP Compaq NC6000 Business Notebook
HP Compaq nc6000 wont start up
Hi there.
This could be a problem with the system memory.
Take the battery out and the AC power, turn the laptop over and look for a panel with screws on it, unscrew the panel and you should see something like this >>>>>>>>>
Unclip the memory by pushing the little lugs outwards and the memory should pop up ready to be taken out, get a clean dry paintbrush and clean the memory and the slots.
If you have more than one stick of memory just put one of them back and try booting the laptop up.
If one works try the other and see how you get on.
Post back for any additional help
Good luck and thanks for using FixYa!!
May 26, 2009 | HP Compaq nc6000 Notebook
Compaq NC6000 would boot up once in a while, would die after a few minutes......
My computer is an Hp Compaq nc6000 PC notebook
My fan was constricted for about 2 hours and my computer froze.After about a day the computer came back on, the fan fan blew during start-up but cut off and doesn't come back on. The computer freezes and the bottom gets very hot. Whats wrong and how can I fix this?
Jun 22, 2008 | HP Compaq nc6000 Notebook
Acer 5100 laptop
If it is doing exactly the same as it was before, and the problem before related to a motherboard failure, then I would imagine it's the same problem again and needs to go back to Acer.
As it's the second time, I'd be a lot less understanding with them, and demand either your money back or a different model which doesn't suffer this fault consistently. As they have had to replace components, then by law those components have a new 12 month warranty. If they've gone wrong again within 12 months, Acer are obliged to repair or replace at their expense.
May 28, 2008 | Acer Aspire 5100-5022 Notebook
Screen will not power on
try pluggin an external monitor to the laptop. If you see the screen then your filament ribbon might need repair or replace.
May 06, 2008 | HP Compaq nc6000 Notebook
Gfx card or overheating or power management or memory or what? problem
Hey, I had a 1522wlmi, witch is the brother model of your laptop, the models have issues, parts fail within 12months. Your only option to get the problem fixed is to send your vga card to www.acerparts.com by ordering a replacement model. Only option is repairflow as far as i know at the time.
I had my vgaboard at acerparts for 6months, I got it back but had issues with games, i send it back waited a few months and got my money back.
Then I send my laptop to my local acer. It was analysed since it had taken more than 3 months to replace my card. I they suggested to repair the laptop for 300eur thats around 400-500 usd. Im pretty sure it wont last more than 12months so in the long run your better off buying a new laptop, dont buy acer.
Good luck.
Mar 11, 2008 | Acer Aspire 1360 Notebook
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
