Question about Home
How many volts can this light handle?
I have a few of these but none of them say the volts, with a cell phone battery 2.5 volts dc it lights up pretty good but I would like to know how much it can handle
    Sergeant:
  • 315 Answers
The picture was not extremely clear but it looked like an LED to me. LEDs have different voltage ratings and can handle a certain amount of current. If you plan on hooking up any LED to any system, you should know what voltage range the light is. If you know that, the LED is usually installed with a resistor in series to protect against overcurrent. Sounds like a complicated answer for your question, right?
I propose you go to an electronic supply store and get the LED and the associated resistor. It's not expensive and the person should be able to tell you whether or not it can be done.
Good luck and I hope this helps!
Posted on May 03, 2013
Engine light and battery light lit up
Hi Anonymous, your battery has discharged to a non functioning level. Recharge your battery to 12.5 to 12.8 volts and perform a load test on it to check for a bad cell if your meter reads 10 volts or lower after load test replace the battery. Check your charging system should put out 14.3 to 14.7 Volts DC at the battery. Good luck
Feb 11, 2014 | Harley Davidson Motorcycles
I have a G'zOne S series phone. In my line of work the phone is great. But, I've tried 3 different bluetooth devises and a couple of verizon ear pieces and I have the same problem with each one, LOW...
The best bluetooth headset for ur phone will be BLUEANT X3 MICRO BLUETOOTH HEADSET.
Here are the PRODUCT FEATURES:
  • High quality, Full duplex audio makes a natural conversation on your cell phone or computer!
  • All these recharging options are provided in the box: USB charging cable for computer, AC travel charger for 110-120 volt AC, and a 12 volt DC car charging cord (SAM460CLA).
  • Use with VoIP programs, and handle calls between both your cell phone and VoIP if Bluetooth enabled!
  • Supports Bluetooth Profiles of Hands-free, Headset.
  • LED lights can be switched off for night time driving.
  • Tiny Ergonomic Design provides a Very small size of only 52 mm x 26 mm x 28mm, and weighs only 13 grams!.
  • Rechargeable Lithium Ion Battery lasts for more than 7 hours talk time, or 180 hours of Standby time.
  • Stores Bluetooth pairing information for up to 3 different Bluetooth devices, one at a time.
  • Bluetooth Version 1.2 for Fast connectivity & security, and Bluetooth Class 2 for range up to 30 feet.
Goodluck,
Don't forget to rate me as fixya..
Jan 12, 2008 | Cell Phones
Dc lo keeps blinking on the fridge and lights go low in rv, power converter middle light is blinking green
The battery is not being charged OR is no longer accepting a charge.
The inverter does not charge the battery. An inverter consists of components that first convert the battery's low (12) volt "direct current" (DC) power used to power automotive devices to a higher (120) volt "alternating current" (AC) power that is required by nearly all household appliances to operate properly.
The charging of the battery occurs when either the RV's engine is running and spins the alternator, etc. OR when connected to another charging device - whether it is permanent or portable.
With the RV engine running, there should be about 13.5 - 15 volts, DC on the battery posts or terminals. This voltage is coming fromt he RV alternator and since it is greater than the 12 volt battery, "charges" the battery. If you use a portable charger - that is part of a generator, or plugs into a power port at a camp site, etc. this will charge the battery.
When none of these things is happening, the battery voltage will slowly drop. Once it is at ~10 volts, it is "dead" and will need to be recharged.
The battery will no longer accept a charge if a "cell" inside it has "opened" or "shorted", or if the battery is at the end of its useful life. The battery state can be checked quickly by any mechanic.
I hope this helps & good luck!
Nov 19, 2013 | Electrical Supplies
It does not seem to be charging the batteries. 12 volt lights work good for about 2 days then go dim until I put a charger on the batteries and bring them back into working order. The battery connect...
The Parallax 7155 converter should not require battery support for any 12 volt load amperage that is less than the maximum amperage capacity of the converter. A standard RV incandescent 12 volt lamp draws about 1.5 amperes for each bulb. With the battery disconnected and other 12 volt loads off, turn on lamps (not fixtures) and calculate the number of bulbs which can be turned on. If you run out of lamps, turn on vent fans etc. The idea here is to try to get to 55 amperes of DC load if possible without going over 55 amperes. At a sustained DC load of about 25-30 amperes or higher, the fans should cycle on continuously after about 5 -10 minutes. Lamp brightness should be normal and the measured voltage from the converter should be above 13 volts if under 55 amps of DC load. If the voltage drops with only a few lamps on, a converter issue would be likely.
Diagnostic tests an RV technician should make would be to:
1. Disconnect the battery system.
2. With the converter system powered on, measure the DC amperage with a DC ammeter capable of reading at least 60 amperes DC from the blue lead at the DC fuse panel terminal VCC.
3. Measure the DC voltage at terminal VCC and DC ground.
4. Record both readings.
At any DC load amperage less than 55 amps, the voltage should be above 13.0-13.2 volts DC. This method should take out all guesswork and confirm a DC converter section issue or not.
Nov 04, 2013 | Parallax Power Supply Parallax 7100 Series...
I lost the adapter/charger and purchased a new one of the same size. The light will work when plugged into the car cig lighter, but not while plugged into the dc adapter (has been plugged in for approx. 3...
The battery life for these lights are for about 2 years at the most if left uncharged. The best way to determine if you need new a new battery or batteries would be to dismantle the light, remove the batteries and check the voltage with a volt meter. If they are dead, you may be able to fine a suitable replacement at: http://www.batterymart.com/c-04-12-volt-sealed-lead-acid-batteries.html
Nov 12, 2010 | Vector 20 Million Power Series Spotlight
3 way dometic RV fridge RM2612 won't work on propane or 12 V
Check any fuses/circuit breakers in harness from battery. That battery should supply 12 volts dc to fridge lugs/terminals at bottom of fridge on outside behind vent.
If battery is good and hooked up properly but no 12 volts to fridge, then you will have to trace back to battery for broken /bad wire. If you want to test quickly, just run 2 jumper wires from battery to those 2 lugs marked + and - Battery + to + (pos)at fridge, and - battery to -Neg at fridge. That should allow you to run it on propane or 12 volt. Remember, running it on 12 volts will kill that battery pretty quick, unless it's being charged. When you are plugged in, the converter supplies the 12 volts to your fridge, as well as should be charging your battery.
Jun 18, 2010 | Dometic RM2652 Refrigerator
The fuel filter light,battery light and 4 WD light wont go out until the engine reaches 2000RPM
Guessing that the charging-system/battery is borderline. With a voltmeter, measure the battery voltage with the engine off--should be 12.6 volts DC. Start the engine, then measure the battery voltage again, it should be ~13.5 to 14.5 volts. If the battery has a shorted cell, it will decrease by 2.1 volts/bad cell and will probably decrease the running voltage as well. The battery must be replaced if it has a shorted cell. If it has removable caps, check the water level in each (add distilled water only, but don't over-fill). Clean the battery connections with a special wire brush and put anti-corrosion grease on the terminals and posts. Wash your hands after this procedure to prevent mysterious holes appearing in your clothes. Once the battery and charging system check ok, look for the check engine light on. If so, read the code(s) with a rented scanner and pursue to repairs. If no codes, erase the light. Hope this helps!
Aug 24, 2009 | 1998 Isuzu Trooper
Sidekick Gekko Wont Turn On
try to charge phone battery in 12 volts dc
Jul 17, 2009 | T-Mobile Sidekick ID Cellular Phone
Vector Sport Spot 1,000,000 candle power spotlight
6 Volts, here is info from site.
VEC127Y
VECTOR SPORT SPOT 1 MILLION CANDLE POWER CORDLESS-RECHARGEABLE SPOTLIGHT
  • HIGH CANDLE POWER QUARTZ HALOGEN BULB DELIVERS A BRIGHT AND TIGHT BEAM
  • AREA WORKLIGHT IN HANDLE PROVIDES UP TO 15 HOURS OF LIGHT WHEN FULLY CHARGED
  • PROVIDES CONTINUOUS SPOTLIGHT USE FOR UP TO 25 MINUTES WHEN FULLY CHARGED
  • HIGH IMPACT, BREAK RESISTANT ABS AND POLYCARBONATE HOUSING
  • TOUGH, WEATHER RESISTANT AND BUILT FOR RUGGED OUTDOOR USE
  • REPLACEABLE 6 VOLT, 6 AMP HOUR, NON-SPILLABLE, SEALED BATTERY
  • LOCKING TRIGGER FOR ON/OFF LIGHT CONTROL
  • INCLUDES AC AND DC CHARGING ADAPTERS
  • INCLUDES BUILT IN HANDS FREE WORKSTAND
Sep 07, 2008 | Vector 2M Pwr Rch Spotlight
Charger
The light can come in a box with just the light alone (light with battery), single ac(light with ac cord and 1 charger), single dc(light with dc volt cigarette outlet and 1 charger), double (light, 1 ac, 1 dc cord, 2 chargers) pb charger...and so on. The sticker on the box that contains the UPC code should have the listed detail on what the box should contain. Still confused check out the website www.streamlight.com search the light you're looking for and check out the product part number list. Hope that helps ;)
Jul 21, 2008 | Stinger Streamlight 75000
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
