Question about Vehicle Parts & Accessories
Tail light 2006gmc denali envoy needs new tail light bulb
  • 51 Answers
The first thing you need to do is open the back door (hatch door) then on the right side were the bulb is ting working there should be two screws mounting the tail light lens in place remove care full not to lose them then you should be able to the lens cover out far enough to disconnect the wire clip holding the wires on then pull bulb.
Posted on May 04, 2013
2 Suggested Answers
  • 44200 Answers
SOURCE: Rear hazard flashers don't work 1994 Chevrolet Cavalier
Hazard flasher power comes from the 20A S/LP fuse in the fuse block. It is applied to the hazard flasher in the convenience center. Flasher output is applied to the turn/hazard/headlight SWITCH assembly where activation of the HAZARD switch causes flashing power to be applied to the turn indicators and the turn filaments of the front and rear dual park/turn lights. If replacing the fuse doesn't work, trace the power through the circuit. Check for misssing/disconnected ground wires.
Posted on Sep 16, 2012
Where is the tail light fuse?
The tail light fuse is under the rear seat on the drivers side.
Jan 17, 2016 | 2003 GMC Envoy
Which fuse is for the licenses plate light. I've changed the bulb but it still doesn't work
licence plate bulb is on the same circuit as the tail lights
if you have tail lights but no number plate light ,then problem is in the bulb holder or wiring
Nov 11, 2015 | 2001 GMC Yukon Denali
What cause my 2006 gmc envoy danai to go in an out of limp mode
you need to hook up an obd2 scanner to the port under the steering wheel and see what your computer says which sensor or circuit is acting up
free service at my local autozone or advance auto parts stores
Apr 13, 2015 | 2006 GMC Envoy Denali
Tail lights dont turn on
1. Replace your car tail light. You will need working gloves to protect your hand during the process. Of course you will also need a screwdriver, cleaning cloth, wire brush, and a good set of tail light bulbs.
2.Understand that different models of car have different set of tail light covers. Naturally, these covers will require different un-installation procedures. So, determine if you can dismount the cover from the outside or you will have to dismount it from the trunk of the car.
3.Determine how to dismount the tail light cover, carefully detach it from the car. You can use different sets of screwdrivers for this. Be careful not to break the tail lights cover. The important thing is you must be able to expose the bulb in order to extract it.
4.Remove the tail lights cover, unscrew the bulb from its socket. Sometimes you will have to press a little and twist the bulb in order to extract it from the socket.
5.Extract the bulb, bring it to your favorite auto parts and accessories store and find the exact match of your tail light bulb. Be sure to get the correct match because if you use other types of bulb, your tail lights may not work properly.
6.Reinstall the tail light bulb, clean the aluminum casing of the tail light. Wipe the socket and wiring with a dry cloth. You can use wire brush if there are corrosion around the tail light casing.
7.Put the good bulb on the socket. You might still need to apply a little pressure on the socket before you can install it fully.
8.Reinstall the tail light bulb, replace the cover of the tail lights and secure it tightly.
9.Test to make sure your new tail lights are working. Start the engine and apply the brakes. You can ask someone to see if the tail lights are really working.
resource: http://www.wikihow.com/Fix-Car-Tail-Lights
Aug 27, 2012 | 1998 Buick LeSabre
I have a 2005 GMC Envoy. Have tail lites but no brake lites. Third lite on top works whet brakes applied
Since the high mounted brake light works you know that the brake light switch is working. Now you need to check the brake light bulbs in the rear tail light assemblies. The brake lights are separate from the tail light (parking or running lights). There are two screws that hold the rear light assemblies in place.
Mar 13, 2011 | 2005 GMC Envoy
My tail lights dont work or break lights but when i depress the break pedle my cargo break light works...i drive a 02 GMC serrira....my hazards, turn signals, and back up lights work
It sounds like you have burnt out bulbs. All those other lights that you say work are all different bulbs. The tail light bulbs have dual filament so that they can perform the tail light and brake light function. You should change out your bulbs and that will probably solve your problem.
Dec 03, 2010 | 2002 GMC Denali
Brake lights won't work. tail lights do. I
need to know if your third brake light up high is working or not.if it isn't,you need to check the brake light switch on the brake pedal with a test light,one side hot all the time,the other side should turn hot when brake pedal is pushed.
Jan 19, 2010 | 2002 GMC Envoy XL
BRAKE LIGHTS..... A SHORT MAYBE?
FYI - there was a recall on the GMC Envoy tail light circuit boards back in 2004-05. I would suggest taking it to an authorized dealer and ask them about it. A lot of times these types of things are taken care of at no charge if it is/was a factory recall. It's a safety issue - they should take care of it.
May 19, 2009 | 2002 GMC Envoy
Were to access tail light wiring harness 2008 Denali Envot
look goto autozone they have a all in connector for towing so much me easer about 40 dollars you go back to driver side rear harnes when you unplug it the pig tail joins all connectors to geather along with your traller pig tail no mus no fus
Mar 21, 2009 | 2008 GMC Envoy Denali
Vehicle Parts & Accessories Logo
93 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
