Question about Home
Bathtub problem Is it the handle or the stem that is not stopping the water from running?
    Sergeant:
  • 330 Answers
The audio is not very clear, but i assume you removed the knob. Did you check inside the knob if the "teeth" were worn out? If you are not sure, take a pair of pliers and gently try to turn the stem to shut it off. If it feels like it is as tight as it should be, then I would think it is the gasket(or washer) inside the unit that is worn out. The repair can be made fairly easily if you have the basic tools and do not overtighten after replacing the gasket.
Let me know if this helps! Good luck.
Posted on May 03, 2013
2 Suggested Answers
  • 94 Answers
SOURCE: bathtub water constantly runs (hot water)
the washer's are most likely history,you will have to remove and repair .check for access panel behind tub. there may be shut offf valve's .don't know if your handy,or not but not that hard ,or call your plumber!!
Posted on Apr 24, 2010
We have no hot water coming out of our bathtub faucet. We took it all apart and water is only coming our of the cold side of the pipe
there is probably a shutoff on the rough-in valve in the wall. Sometimes the seal in that comes apart and blocks the water. Get new stem for valve. Unscrew the nut, replace stem, tighten nut. Clean inside valve before u put new one in.
Oct 10, 2015 | Delta & Single Handle Shower Faucet
We have a Moen one handle faucet in the bathtub. It was installed opposite for water but I see the answer to that question is to flip the cartridge. Well, now the appears that something is stripped as...
If the handle spins, but the cartridge remains stationary, then the stop inside the handle is broken and the handle must be replaced. To test, remove handle and see if you can turn the stem with a pliers. If you can turn the water on, then I'm right. Replace the handle. If not, then you have me stumped.
Feb 26, 2015 | Moen & One Handle Tub & Shower Faucet
We have a 2 handle Delta faucet in our bathtub and one leaks. House is 25 years old all the information I can find on Delta is for the single handle type and information would be appreciated
nathanolsen1.gif It probably looks something like this basically front of handle has a cap pops up usually phillip screw after unscrewing that the handle will pull off if its real difficult you may need a handle puller or cut off the handle with saw and replace the stems may just need a gasket but if its that old i recommend buying a whole repair kit that includes handles, stems, seats and will include everything except the seat wrench.
Aug 27, 2011 | Home
How do I tighten the faucet handle. The handle is floppy and unless you put downward pressure on the handle when you turn it, it will continue to move from left to right
From what you have described it sounds like the stem in which the handle rests on is stripped and allowing to move from side to side.
Remove handle it has a set screw in the side of it and turn water off. Check the stem may be in need of replacing or the retaining nut that holds the stem down to counter top may be in need of tighting.
Feb 12, 2011 | Kohler Brushed Nickel Roman Bathtub Tub...
Delta shower faucet loses pressure when turned all the way on (hot water). What could cause this? When it first happened yesterday, a few tiny pieces of black plastic/rubber fell out of the bathtub...
Turn off the water to the home. You need tthe stem beneath the handle. Remove the handle after locating the set screw, remove the cylindrical beauty cover, and unthread the retaining nut to access the valve stem. Take it to a plumbing supply house or home store to make certain of the match.
Oct 06, 2010 | Delta & Single Handle Shower Faucet
Water leaking at handle when turned on
1- Hanldle may have a cap that will come off to access screw to loosen or allen screw on the handle to remove it.
First thing you can check remove handle and make sure the nut that holds stem down is not loose. You can tighten it and try this first just replace handle turn on and check for leaks.
If not please go to step 2 in removal of stem
2- Cut water off and remove handle to gain access to stem. Next remove stem by untighting nut at the base. Remove stem and replace o rings on stem about middle of it. That will stop water from leaking at the base.
May 19, 2010 | Kohler Fort© Widespread Lavatory Faucet...
Leaking form shower facet also leaking from
id say your tub spout or shower pipe is leaking and running down behind remove both and replace teflon tape see if it stops
Mar 14, 2010 | Home
Moen single handle bathtub faucet
Something is caught in the stem. Make sure the stem is free of debris. Also check that the valve or cartridge is intact.
Jul 02, 2009 | Moen 2919 Chateau Two Handle Tub and...
The cold water won't turn off on our Bathtub
Sounds like you have a faucet that has a stop that is on the handle and it has broke. Remove the handle and turn the stem on its own. If you end up having to replace the stem, you will need to turn the water off to the faucet and if it is in the tub, you will need to turn the water off to the house. Hopefully this helps you.
Apr 09, 2009 | Whirlpool 6060 DL Corner Pro-Fit Acrylic ...
Hot water running after shot down inside bathtub after replacement of water boiler
Sounds like some debris is caught in the stem and it won't close completely. Turn water off and remove the stem. Look for any debris that might be stuck down in the manifold.
Mar 17, 2009 | American Standard Home
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
