Gateway notebook ZE6 , what is my next step ? What
Gateway notebook ZE6 , what is my next step ? What option do I select not the safe mode tried those all ready . Thanks
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 51 Answers
Reinstall windows, or Factory reset...
Posted on Jun 06, 2013
5 Suggested Answers
acoi
  • 22 Answers
SOURCE: Toshiba Satellite L20/L25 Series
what is the error message, can you type it here??
Posted on Feb 18, 2008
SOURCE: Presairo V5000 notebook will not boot
Try this, get a boot able CD copy of RIPLINUX 6.2 nonX. Go into your Compact bios and select CDROM as the first boot device. Open cd dvd player and install 6.2 Power down and then power up to 6.2 Install GRUB and select HARD DRIVE Partition #2 from the menu and wait.
Now here is what will happen. GRUB will load and execute drive partition #2 which contains the original factory install for your Compact V5000T. Warning!!!! You will lose any customized programs that where added after you bought your computer (goes back to factory default operating system) by reformatting #1 partition. There are utilities that can retrive the contents of a formatted partition, but this is beyond the limits of this topic. Use Google to search for those utilities. They are sometimes free.
Posted on Feb 26, 2009
dcolvard
  • 65 Answers
SOURCE: How to remove BIOS memory cache
Since it is a Toshiba Tecra if you are not worried about losing data on the laptop you can try turning on the laptop and start pressing the zero key. It should give you the option to restore your laptop if you haven't deleted the restore partition on the laptop.
Posted on Mar 20, 2009
  • 942 Answers
SOURCE: when trying to boot up
Hello
So in that case you need to reinstall the Windows so that it will fix the problem. Some instances of that problem corrupted Operating System it needs a new copy.
Regards
PCmania
Posted on Sep 25, 2009
How to run safe mode
Try tis.
start windows > select run command > type msconfig
select BOOT.INI tab select safe boot in boot options and restart the system
this will start the system in safe boot next time re-started.
Jun 21, 2013 | Lenovo ThinkPad R60 Notebook
Gateway dx4710-05 will not start upgoes to repair , will not repair
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
You should have no input while chkdsk utility is in progress any input might further damage your computer also
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
If this fails you might use the system restore option
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System.
Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
May 19, 2013 | Gateway DX4710-05 PC Desktop
The windows 7 was already program in the computer , so I don't have a windows 7 cd to reinstall . So should I click on directory services to restore mode or disable driver signature enforcement on my...
go to start then at the search bar type in recovery chose it. Then go to advance recovery. Then chose restore todefault .If you do not have that option please let me know and ill tell you how to do it another way.
May 03, 2013 | Computers & Internet
How can i get rid of Dxerror 8876086C
Step 1:
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 22, 2013 | Logitech QuickCam Computers & Internet
Hp pavilion will not boot, error0xc0000409
Step 1:
As the computer is booting repeatadly press the F8 key as the computer is booting If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Enable VGA mode
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select the safe mode option then run your antivirus if still cant get rid of the virus restart again Use the up and down arrow keys to move the highlight to your choice. select safe mode with networking download anti malware and microsoft security essentials http://www.microsoft.com/en-us/download/virus-malware.aspx?q=virus anti virus and malware http://windows.microsoft.com/en-US/windows/products/security-essentials If this fails you might have to go back into safe mode. You might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System Configuration utility Installation restore points that occur before you install a program or a service. You can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
Feb 03, 2013 | HP Pavilion dv7-1245dx Notebook
Power button goes green screen is black
Your first troubleshooting step should be this:
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On until you get the Safe Mode Option.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->Click 'System Restore'
A 'System Restore' window will appear.
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
Note: It is better if you could remember from which date you are facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot your problem should be resolved.
If you feel that, my answers have helped you getting solution to your problems then please give a vote.
Thanks.
Dec 03, 2011 | Gateway One ZX4300-41 (PWGAW02017) 20 in....
My gateway notebook is locked n I can't remember my user password ..help very frustrated ...I tried ctrl alt del twice to make the admin acct pop up but nothing
Try booting in safe mode.
Restart your computer.
As the computer restarts, begin pressing the F8 key after the Gateway BIOS logo appears until the Windows Advanced Options Menu screen appears.
On the Windows Advanced Options Menu screen, use the arrow keys to select Safe Mode, and then press the ENTER key.
After logging on to Windows XP Safe mode, in the Desktop dialog box, click Yes.
Good luck, post back if this helps.
Jan 28, 2011 | Gateway Computers & Internet
INSPIRON 640M WILL NOT GO INTO SAFE MODE , IT GIVES OPTIONS BUT NONE OF THEM WORK , THEN IT GOES TO THE BLANK SCREEN.
Try going to safe mode manually. The steps mentioned below will help you accessing the safe mode
Step 1: Shut down your PC completely.
Step 2: Turn on the Power button.
Step 3: As soon as you turn it on start hitting the F8 key on your keyboard until you get to a black screen called "Windows Advanced option". (If you don't get to that that screen but you end up reaching the blue screen than that means you have delayed in hitting the F8 key. start again from step 1.)
Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Safe Mode/Safe mode with networking".
Step 5: Select that and HIT ENTER.
Jan 20, 2011 | Dell Inspiron 640m Notebook
Gateway desktop wont boot up into OS XP just blinks with cursor on black screen
try this strt the pc when you see setup on screen press F8 key a few times then you will see options like safe mode and safe mode with networking and you will see an option to boot from last known good configuration use keyboard arrows to select this option your pc will reboot if this doesnt sort it the repeat these steps and on the screen select safe mode and hit enter key or return key let the files load on the screen when th pc goes into safe mode the screen will look different clik on strt then select alll programmes then select accessories then select system tools then select system restore ....select a date when your pc was last working correctly and clik next let the computer do its work when it restarts it should be working correctly (NOTE) any progrmms you downloaded from the date you selected will be eresed but not your documents or downloads like movies ...hope this helps
Dec 19, 2010 | Gateway GT4016 Desktop PC
Display
Try going into safe mode and remove the video driver.
To go to safe mode you will need to press the F8 key.
Step one = turn the pwr on and press the F8 about 8 times
Step 2 = select safe mode
May 31, 2008 | Gateway 310X PC Desktop
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
