Question about Canon PIXMA iP90v Printer
Printer does not work
My printer is not working. That is, the green light shows it´s working, but when trying to print, it shows that it is printing, but nothing happens. I went to a repair-store and they used another cable and it worked. Bought myself a new cable after that and it worked. However, after one day, it all started over again. The indicator shows that it´s inactive. If you have any form of useful suggestions, I really would appreciated it, because this is really frustrating :(((
Thank very much in advance!
    Scholar:
  • 104 Answers
If the printer is fine then the problem should be in your computer. Therefore, i suggest reinstalling the printer driver and after that you should be able to print normally.
Posted on May 08, 2017
artifixit
  • 59 Answers
SOURCE: Canon PIXMA iP 1500
Your print head is most probably blocked.
First try and run the deep cleaning program a few times, it make penetrate deep enough to get through.
If that doesn't work you can either replace the print head or try and clean it.
To clean it you could soak it in a mixture of window cleaner and water (filtered best), but don't let the electronics get wet by this and try to avoid wetting the rubber seals where the ink tanks go get wet by this too, it should only soak the very bottom part of the head.
Let it dry off and wipe any residue with a soft cloth especially on the bottom where the print heads actually are. You may need to soak it a few times to get all the gunk out.
Posted on Jan 25, 2008
SOURCE: Canon Selphy 510
I have a similar problem saying that the cartridge was not installed. Try winding the film on until you can just see the yellow film and try printing again. This normally fixes my problem for that print run, but the problem seems to regularly re-occur. Hope this helps.
Posted on Mar 04, 2008
SOURCE: Printer won't print on my MacBook
Mine won't print from PC. checked everythong, re-installed drivers, got new ones... nothing, ...yes even formated the pc. but nothing.. unless i connect it to my canon s5 cam.... then the &"¤?& thing works....
Posted on Apr 18, 2008
SOURCE: iP 4300 Canon Printer printing horisontal gray lines
To solve this problema, proceed with LF correction procedure, which is well documented on Canon IP4300 simplified service manual (it can be found at Emule network). This procedure prints some patterns and the user has to choose the best among them. One of them will probably enough to compensate (or, at least, to minimize the problem to the point that naked eyes can't observe it) the line feeding error which causes dark horizontal lines along the printer lifetime (probably because of feed roller wearing).
Posted on Aug 19, 2008
SOURCE: canon i550 printer stoipped printing
My cannon printer no longer responds to any commands. I get 4 yellow blinking lights and then 1 green blinker.
Posted on Nov 12, 2008
The printer does not accept print jobs and orange warning light is on along with green ready. Both lights sart blinking when a printing job is sent. The printer does not print. How can I fix the probl
Dear
I am not familiar with Ubuntu. So in case of windows SMART PANEL/EASY PRINTER MANAGER can be down loaded from samsung web this will show the errors that the machine has.
Try to print a self (demo page) pressing stop s/w a while. If it works check the life of toner cart.
Thanks.
Sep 19, 2014 | Samsung ML-2571N Laser Printer
My printer HP laserjet P2015, have a problem that no error light blink ready status light on (GREEN) but no test print out and nor other printing by USB cable from computer. Please advice about this i
May be cable loose or heavy dust available in printer that`s why your printer not proper response it. Or may be printer main board damage position so i suggest you contact it printer technician or checking it, which area damage.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01764440&tmp_task=solveCategory&cc=us&dlc=en&lang=en&lc=en&product=3811075
Thanks,
HP Printer Support
May 15, 2014 | HP LaserJet P2015 Printer
Printer won't print documents. Green light on
Hmmm, try feeding a sheet of paper into the manual feed slot... you might have inadvertantly sent a Manual feed job, and the printer is waiting for a sheet to be fed by you.
Feb 10, 2010 | Dell 1710n Laser Printer
My Canon pixma ip 4000 won´t print. The light at the turn on button blinks five times orange and then comes one green blink. I have tried to clean the print head but that didn´t change anything....
this indicates a the print head is not installed correctly or is faulty.
if the green and orange is alternating 5 times then it is caused by the sheet feeder.
Dec 08, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Have just changed refilled cartrige, alarm light is blinking
The printer does a longer green flash and then the amber flashes. you need to tell me how many flashes between the green flashes, to know what the problem is.
Aug 13, 2009 | Canon PIXMA iP1600 Printer
OKI C5650n USB port not working
Yes, well I can´t help you to solve that problem and in fact i´m hoping that you´ve already solven it, cuz right now i got the same problem with my c3450... It worked just fine under vista x64 but now on windows 7 x64 i have the same problem as you have/had!
Cheers
Jun 02, 2009 | OKI Office Equipment & Supplies
Dear Experts, We have just got a Canon iR2022 Copier/Printer. The copier is working properly but for the printer here is the scenrio. The printer is on the network no net work issues. i have installed
if it hapen´s just after you acces it via web and if you turn it off and back on everything get´s right your problem is the firmware.if it´s your problem call me back.
Apr 15, 2009 | Canon iR 2022 Printer
PRINT ENVELOPES
You MUST use the bypass tray and bve sure to enter the custom size, media type and weight in the driver. The settings MUST be set the same on the 180 before printing.
Running envelopes is a tricky situation, but once mastered it should work. Note that not all envelopes will run, try different sizes and brands and keep the ones that work.
Nov 16, 2007 | Konica Minolta bizhub 180 All-In-One...
Canon PIXMA  iP90v Printer Logo
4,569 people viewed this question
old marine
old marine
