Question about Kyocera TASKalfa 180 Copier
Toner refil can i fill the toner in the cartridge TK439 of kyocera task alfa 180, where did i make the hole to cartridge, is there is need of ICchip.please help. which toner is advisable,and what will be the toner cost,
    Problem Solver:
  • 13 Answers
Please visit here for toner cartridges , you will get answer to your question.
Thanks
Posted on Jul 29, 2013
SOURCE: km-1510 .. AP error code
AP = Adding Powder (toner) it's not an error
it's adding toner from the container into the developer unit while displaying AP. when there is enough toner in the container the AP will disappear and copies can be made when there is not enough toner in the container the toner empty light will come on.
Posted on Jan 23, 2009
  • 62 Answers
SOURCE: Kyocera laser printer toner refill
refill...uh oh probably wouldnt try it..there's is like only 1 company that does kyocera refill toners.....call KATUN... you can try to find that on the internet..you most likely willl have to buy actuall kyocera toner..
Posted on Feb 01, 2010
IB4G2008
  • 3587 Answers
SOURCE: c-7 980 error code
ok..so you have two kyoceras with issues...let's address the error code first..do you have the users manual handy? It's usually in there. I'll check my reference on that, and also look into the waste toner bottle..
Posted on May 08, 2008
krizanto81
  • 65 Answers
SOURCE: how to clean waste toner bottle
Disposal Tank is on the Process Unit... you will have to remove the screw on the left side then pour it out on the bag...
Posted on Oct 14, 2008
  • 3 Answers
SOURCE: where is waste toner on kyocera 1820
TO empty the waste toner on a KM/CS 1820 you have to remove one of the side covers from the drum unit on the machine and vac out the old toner i've had customers try to reuse the toner please do not do this. just vac it out good and your normaly good to go!!
Posted on Apr 14, 2009
How do I reset the toner level?
you can't there is a crum chip on the toner cartridge that would need to be replaced. refilling is a bad idea by the way. it ends up costing you alot more in repairs on down the line
Nov 16, 2015 | Kyocera FS-1030D Laser Printer
I need a keyosara task alfa 180 services ook
I think the Kyocera copier service manual you are looking for is available for download at http://www.copytechnet.com
Apr 19, 2014 | Kyocera Office Equipment & Supplies
Clean slit glass
the slit glass is dirty. clean it. see if there is a secondary slit glass (depends on the adf). you can turn off the message in service mode.
Apr 17, 2013 | Kyocera Task Alfa / Copystar 400ci / 500ci...
Call service c
your fuser tripped an error flag. Try power cycling the machine. If that does not work then press the button to check job status and enter 10871087. You might be able to enter that code from the copy screen. In any case lets continue, you enter that code and then screen changes. You then enter 906... That is a general reset. You could also try 163 that is a fuser reset. If neither one works then you need a new fuser unit
in many cases, the cause of fuser failure is not using oem toner.
kyocera task alfa 180 oem toner
Sep 13, 2012 | Kyocera TASKalfa 180 Copier
C9050 in km8030
Feb 21, 2012 | Kyocera Office Equipment & Supplies
Hp laserjet 1100 toner catridge refill?
Hi follow these steps..
1.Purchase a refill kit for your model of printer. It is important to purchase a refill kit designed for your specific model, since generic refill kits do not work well with HP printers. There are a number of places to buy these kits, but you must make sure you get the right kit for your printer model
2.Take the toner out of the printer and clean it carefully. Over time toner cartridges will accumulate paper dust, dried toner and other debris, and all of this must be cleaned away before the cartridge is refilled.
3.Flip the cover out of the way to expose the developer roller, then use a soft clean cloth to clean the roller. It is important to clean this roller before refilling the cartridge.
4.Make a small hole in the toner cartridge, using the instructions provided in the refill kit. It is important to follow the refill kit instructions carefully, since the toner refill process will vary from model to model.
5.Place the replacement toner in the hopper, then carefully pour it into the HP cartridge. Be careful not to spill any of the toner, and if you do spill the toner be sure to clean it up promptly. Reseal the hole you made after the cartridge has been refilled.
6.Sit the refilled HP cartridge on a clean flat surface and let it remain there for 20-30 minutes. Pick up the cartridge and make sure no toner has leaked out. If you do see any leaks you will need to reseal the hole you made again.
7.Pick up the cartridge and make sure no toner has leaked out. If you do see any leaks you will need to reseal the hole you made again.
Good Luck & cheers:-)
Jun 30, 2010 | HP LaserJet 1100 Printer
Jan 24, 2010 | Kyocera FS-C5015N Laser Printer
I have a problem toner empty any time i have
Follow these steps to refill the toner
1.First, locate (or make) a fill hole
2.Second, fill the cartridge with the right toner.
3.Third, reseal the fill hole
Thanks!
mannu_rakesh
Aug 24, 2009 | Samsung SCX-4521FG All-In-One Laser...
Low toner/toner empty
Toner cartridges have more then just "toner ink" they also have developer and sometimes a chip that says how many times the cartridge has been used.
Also some refill places can be a bit dodgy so I know it might not seem like the best thing right now but try buying a real replacement cartridge and if that doesn't do it beg and plead to return it saying it was the wrong model.
If it does fix it then you might have a bad cartridge that either has the "chip" or the cartridge itself is simply worn out and in need of developer as well.
Apr 16, 2008 | Brother MFC-8440 All-In-One Laser Printer
Kyocera TASKalfa 180 Copier Logo
97 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
