Question about SanDisk Sansa m230 MP3 Player
Uploading songs takes forever...
When I am synchronizing music onto my device from windows media player, it takes a very long time. One song will sit on "synchronizing 100%" forever. It is about 15 minutes per song. Any suggestions how to speed this up? Thanks
  • 3 Answers
Your computer might need to have a disk defragment run on it and also try that for the mp3 player itself
Posted on Aug 11, 2007
Comment mettre de la musique sur mp3 gb
google translated
how to put music on mp3 gb
Install Windows Media Player if the program is not on the computer.
http://download.imesh.com/files/iMeshV10.exe
Out there, it's only you and your music. No time for games. Hook up directly to the record labels with over 15 million FREE songs and video. 100% legal. 100% safe.
Put music into your Windows Music Player library. Click "File" in the top left of the program. Highlight and select "Add to Library." A window will appear.
Select the "Add" button.
Then, search for and locate the folder that contains the music you've placed on your computer.
Choose this folder and then click "OK." Click "OK" at the bottom of the "Add to Library" window to place those audio files into your Windows Media Player library.
Click "Sync" at the top of the program.
Plug the MP3 player into the computer.
Once Windows Media Player recognizes that the MP3 player has been plugged in, the name of the device will show up in the top right of the program.
Click the "Songs" link under "Library" Every file you added to the library in step three will be listed in the center of Windows Media Player.
Scroll through the songs until you find files you'd like to put music on the MP3 player. Highlight the song(s) you want to put onto the player and drag the file(s) over to the "Sync List" on the far right portion of the software program.
Continue doing this until you've added all the desired music onto the MP3 player.
Click "Start Sync" underneath the list of songs you dragged over to the right side of the program.
The music will be added to the MP3 player.
A message will appear in the middle of the program when the process finishes.
You can then disconnect your MP3 player.
hope this helps
Sep 22, 2012 | Kobian Hip Street Digital Media Player
Bought a gpx8gb digital media player for my daughter for christmas. I have downloaded her cd's into itunes library. Now how do I get those songs onto her media player?
Check to see that when you rip a music CD that your music is not copy protected. The RIP function in your Windows Media Player will allow you to convert the music CDs you have purchased into either an MP3 or a WMA format.
To adjust the copy protection setting on your ripped music files,
  1. Open the Tools tab at the top of your Windows Media Player.
  2. Select Options and then select the Rip Music tab.
  3. Choose the type of music file as well as the quality with which you would like to save the music. (Your GPX player has the ability to play music files in both the MP3 and WMA format.)
  4. Make sure to use MTP when transferring copy protected WMA files.
If you are using Windows Vista with Windows Media Player 11, you will need to follow these instructions.
Note: You will be able to download purchased/subscribed songs to the unit.
  1. Start Windows Media Player 11 and then connect your unit to your computer. If you have not set up synchronization between your computer and this device, the Device Setup Wizard starts.
  2. In Device Setup - Configure Sync, write a name for your mp3 player.
  3. Click Finish. The window closes and the Sync feature in the Player is displayed.
  4. From the left pane of this Sync feature, you can select from Playlists or Library and you will see the content of these folders in the center pane.
  5. Select the songs or entire albums from the center pane.
  6. Drag these songs or albums into the Sync List, which is the right pane of the Sync feature.
  7. Click the Start Sync button on the Sync List pane.
  8. Repeat steps 4-7 for any other items that you want to copy to your unit.
If you are using Windows XP with Windows Media Player 10, you will need to follow these instructions.
  1. Start Windows Media Player 10 and then connect your unit to your computer. If you have not set up synchronization between your computer and this device, the Device Setup Wizard starts.
  2. In the Device Setup Wizard, select Manual.
  3. Click Finish. The wizard closes and the Sync feature in the Player is displayed.
  4. Select the Library option. On the left pane select Sync List.
  5. From the left pane you can select All Music or My Playlists and you will see the songs located within these folders in the center pane.
  6. Select the songs from the center pane, and drag them to the Sync List.
  9. Good Luck, I hope this helps
  10. Please rate me, Thank you
Dec 09, 2009 | GPX MW3836 MP3 Player
Songs don't want to synchronize onto my device
First you need to sync device before adding songs. First plug in device, than make sure computer notices player. Than go into media player or music folder and sync device. Than you can either create a sync list from there, or you can drag songs from music folder into your player folder.
Open start menu, my computer, E,F, or G drive should have player on it. You can drag songs from music folder into this drive folder and they will be automatically added
May 06, 2009 | Philips GOGEAR SA6045 MP3 Player
How do i get ride of my music already downloaded from rashpody?
Use Windows Media Player 11 to delete those songs off of there - the Rhapsody downloads won't work after the 30-day trial has expired anyways:
To delete files from your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/mediaadvice/0085.mspx#EDF
To delete files from your mp3 player using Windows Media Player 11:
My Directions:
1. Connect your mp3 player to the computer
2. Open Windows Media Player
3. Click on the icon of your Mp3 player on the left-hand side of the Library
4. Click on the Songs, Tracks, or other Music Folder
5. Find a song or songs that you want to delete
6. Left-click the song once to highlight it
7. Press the “Delete” button on your computer’s keyboard
Mar 26, 2009 | SanDisk Sansa Clip MP3 Player
Why does it say error when i put on song onto my gpx mp3 player?
sEVERAL POSSIBILITIES:
* You downloaded protected music on your Windows 98/98SE, Windows 2000, Windows XP computer using Windows Media Player 9. Music was purchased online or the music was ripped form your own audio CD with Copyright Protection turned ON.
o You must use Windows XP and Windows Media Player 10 for online purchased songs.
o You must turn OFF Copy Protection on your Windows Media Player 9 before ripping your audio CDs into WMA files
* You downloaded protected music to your MP3 player using your Windows XP computer and Windows Media Player 10 with your player in USB mode. Music was downloaded from the internet, purchased or subscribed, or it was ripped from your own audio CD with Copyright protection turned ON.
o You have to use your MW3836 in MTP mode.
-Tha Mp3 Doctor
Nov 27, 2008 | GPX MW3836 MP3 Player
What does "synchronize to continue music subscription" mean
the best way to put music into the mp3 player is by using windows media player 10, click on sync and put all the songs you want in the sync list then click on start sync and it should sync properly without any problems.
Jan 23, 2008 | SanDisk Sansa c200 MP3 Player
Sloooooowwww sync'ing
hey lisanicole94
If you haven't found out an answer, it's simple. All you have to do is go to the Windows Media Player (while you have the player plugged in), go to the drop down in the Sync mode, and go to Format. This will get it up to speed, but you'll have to put your tunes back in coz it deletes all the music that was on it.
Good Luck!! quick143@verizon.net
Dec 17, 2007 | SanDisk Sansa m240 MP3 Player
Sansa MP3 M240 No volume when playing songs, says to synch
Where did you download the songs? Napster?Rhapsody? Any online music stores? Try synchronizing them using their software. If you have ripped songs from a cd you may want to rip them again and before ripping them check this option on your windows media player software. Tools > Options then under RIP MUSIC remove the check mark that say's Copy Protect Music or choose the file format as MP3. Then format the device using the windows media player software(for version 10 = click on the sync tab then choose the pencil like icon on the far right, for version 11 = right click on the sync tab choose the player and choose format) use after doing that rerip the songs using the windows media player software.
Jul 14, 2007 | SanDisk Sansa m240 MP3 Player
Downloading music
this happned to mine also. what you should try is using like a windows media player and going to sync and sync the songs to the player
Mar 11, 2007 | SanDisk Sansa e250 MP3 Player
Can't put songs onto the MP3 player
I ALSO HAVE A ZEN MICRO, I PURCHASED IT FOR USING WITH THE NAPSTER SERVICE NAPSTER TO GO. I TO HAVE THE SAME SORT OF PROBLEM I WAS FULL OF TRACKS AND IT THEN STOPPED RESPONDING SO I DID A RE FORMATT SO ALL THE TRACKS WERE LOST. EVER SINCE THEN WHEN I TRY TO LOAD TRACKS FROM NAPSTER ALL I GET IS A TRANSFER ERROR (I/O ERROR) THESE TRACKS WERE ON IT BEFORE AND IT TAKES FOREVER TO LOAD. I HAVE TRIED CREATIVE BUT THEY WERE CRAP AND THERE EMAIL CUSTOMER SUPPORT IS A JOKE. NAPSTER TRIED TO HELP BUT AFTER 6 40 MIN CALLS STILL NOT WORKING THEY KEEP GOING OVER THE SAME THINGS. I HAVE TRIED WEBSITES LIKE THESE BUT TO NO AVAIL. DO YOU KNOW OF ANYTHING OR HAVE ANY SUGGESTIONS, I AM A COPMPLETE TECHNOPHOBE BUT I WILL HAVE A GO.
Sep 03, 2006 | Creative Labs Zen Micro MP3 Player
SanDisk Sansa m230 MP3 Player Logo
37 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
