Question about Acer EXTENSA 5230E COMPATIBLE LAPTOP LCD SCREEN 154 WXGA GLOSSY CCFL (22099239338)
New Battery just purchased a new battery and battery light on laptop not coming on. Any suggestions pls ???
  • Acer Master
  • 7,627 Answers
Return the battery. Some aftermarket batteries don't work well, and COULD be a fire hazard. Get a genuine Acer battery replacement, beware of inexpensive aftermarkets.
Posted on May 04, 2013
I bought brand new laptop dell inspiron 1525 and now battery looking damage in less then one years. I need some reliable source where i can purchase quality battery with reasonable cost
I have used a web site for purchasing several replacement laptop batteries, it's called richbattery.com. Both the branded and richbattery.com batteries come with same warranty, both are new, both are the same rating, money back guarantee and I would bet both come from the same factory in China!!! . Try this http://www.richbattery.com/New-Battery-for-Dell-Inspiron-1525-7200mah-9-Cell-Laptop_p_58649.html i hope it helps
Jul 10, 2011 | Dell Inspiron 1525 Laptop
How do I know if it needs a new battery? It has been charged for 2 wks now and it still does not come on at all. I tried just plugging in it with the battery unhooked and it still does not come on. What...
The problem is one of two things:
1) Your charger is bad and not powering or charging the battery. Purchasing a new charger can rectify this situation
2) Your motherboard is bad and not letting the charge get through to your batter. In this case you need to send the computer to the manufacturer for repair or purchase a new laptop.
If your battery was bad then plugging it in with the batter unhooked would power on the laptop. They troubleshooting steps you took were good.
Regards,
Jacob
Mar 01, 2011 | Visual Land VNet VL760 Netbook
Hi, I bought Acer4741Z from India on September 2010............now, when i charge the laptop, it shows 52% charging and it wont go till 100 %. Any solution for this............pls help..............
When you first bought the laptop did you fully charge the battery for at least 20-24 hours before use? To ensure the lifespan of your laptop battery is long you will need to follow these easy steps:
1) Charge the battery at least 20 hours before use.
2) Completely drain battery power before you charge it again.
3) Try not to have the laptop battery plugged in if you re going to use AC directly from the wall socket.
You may need to purchase a new battery as this one's lifespan seems to have been reduced as it can only hold 52% charge. When you purchase another follow the above steps.
Feb 26, 2011 | Acer Computers & Internet
Acer aspire 5516 battery and charger problem
Hi, this could be an unhelpfull suggestion but the charger may not be compatable with your laptop. Laptops notoriosly have different power settings, you may be forced to purchase a new Acer charger. Try ebay, you may be lucky
Aug 01, 2010 | Acer Computers & Internet
Power light not coming on
Is the power light maybe flashing once when you try to turn it on? Rechargeable batteries slowly lose their energy holding capacity. A new battery may be the answer, this is not a guaranteed fix. I would first suggest trying a friend's battery if any of them have a DS lite before purchasing a battery if possible.
Oct 30, 2009 | Nintendo DS Lite Console
Have a Gateway Laptop Computer Model #MT6708. Previously computer had blank screen and no power. Currently purchased new battery and power cord. Computer now operating screen and power is on. However, when...
First thing check that the battery charge light is on when the battery and the charger are connected.
If it is it indicates that the power supply is charging the battery,
If it isnt it may indicate a fault with the battery or that the charger is not compatable with the laptop or that there is a fault with the charger.
If the battery is charging then try running the laptop on battery only without the charger and on charger only without the battery.
This will eliminate which one is faulty.
You mentioned that if you wiggle the cord then the light comes on again.
Check to see if the charger end plug is lose or the actual port on the laptop is lose.
If the charger plug is lose then return to seller and make sure they gave you the correct charger. if the actual port on laptop is lose then perhaps u got a bad connection and you need electrician or local laptop technician to open it up and solder properly on motherboard.
Let me know how it goes.
Oct 26, 2009 | Gateway Computers & Internet
The battery light remains on unless the power
If the computer will run on battery alone, and you cannot fully charge the battery, it's probably time for a new battery. The life expectancy is 2-3 years if treated right. Some people get a lot more life than others.
Here's a suggestion: when you run your computer, let the battery run fully down at least once a month. Do not leave it plugged in to line power all the time. Do not keep charging it when it is only a little bit discharged.
Jul 01, 2009 | Dell Inspiron 6400 Notebook
Battery not getting charged-power supply on ac power
hi thanks for using fixya!!
Is your laptop is brand new? Try to remove the battery. Then, try using your laptop and AC adapter without the battery, you will get the power supply directily from AC adapter. If it works properly, then its okay. Now, try to install back your battery then try to charge it. If not charging, perhaps you need to buy a new battery. However, I suggest you bring your laptop to a service technician to further check the error, before you purchase a new battery.
If you need further assistance, let me know!
May 25, 2009 | Computers & Internet
Acer Travelmate 2480-2968
You might have to try an new a/c adaptor.
Mar 09, 2009 | Acer TravelMate 2480-2968 Notebook
New battery will not work vaio VGN-TX2HP
mAh denotes the amount of current the battery requires for its charging....
Thus.. the battery works out ur system but it will not charge.. ubetter replace ur new battery or get ur money back... the VAIO is not designed for so much adaptability....
Jan 18, 2009 | Computers & Internet
Acer EXTENSA 5230E COMPATIBLE LAPTOP LCD SCREEN 154 WXGA GLOSSY CCFL (22099239338) Logo
44 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
