Question about Acer Extensa Computers & Internet
Battery not charging laptop
Jus bought a new battery for Acer Extensa 5230E and battery light not coming on, and suggestions???
  • Acer Master
  • 32,281 Answers
When you connect the power adapter into the laptop, does the power LED light up, If not then
The battery adapter or the adapter's power lead or the laptops power socket could be faulty.
Check power adapters DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptops power socket. If the power or battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Posted on May 03, 2013
  • 153 Answers
SOURCE: Where is the wifi switch and what does it look
should be on the front of the unit. it's a small silver slider on the left on the front
Posted on Oct 06, 2009
Testimonial: "thanks ! Now let's hope my laptop will recognise my modem... Thank you all the way from Gouda, The Netherlands"
benwabnick
  • 2404 Answers
SOURCE: where can I download for free the acer extensa
Here is the link for the user manual for your laptop:
http://support.acer.com/acerpanam/notebook/0000/Acer/Extensa5230/Extensa5230ul.shtml
Just copy and paste that link into your web browser.
Posted on Nov 26, 2009
  • 42 Answers
SOURCE: How to replace Acer Extensa 5230E hard drive?
unplug power cord, remove main battery, remove lower cover , the hard drive is crome in color 4in x 5in there will be one silver screw holding it on , be sure to touch the metal frame before removing the hdd , that way you,ll discharge your static electricy on not hurt the computer , also you may want to go tohttp://tim.id.au/laptops and download your service manual as a guide .
Posted on Feb 25, 2010
  • 183 Answers
SOURCE: i have an acer extensa 5230e laptop and forgot my
Boot up into safe mode (F8 at startup) and pick the 'administrator' login. By default there is no password for this, and that should get you in. Then you remove the password from the other account. :-)
Posted on Jul 25, 2010
mariolands
  • 2296 Answers
SOURCE: forget bios user password, so
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD.
Posted on Jan 14, 2011
New Battery
Return the battery. Some aftermarket batteries don't work well, and COULD be a fire hazard. Get a genuine Acer battery replacement, beware of inexpensive aftermarkets.
May 03, 2013 | Acer EXTENSA 5230E COMPATIBLE LAPTOP LCD...
Will acer extensa 5230E reinstallation cds contain windows
A driver restore disk works with a windows disk to return your Acer Extensa 5230E Windows 7 back to the original factory setup.
Once windows has installed you put this disk into the drive as soon as windows gives you a found new hardware dialog box. Once inserted the Acer Extensa 5230E Windows 7 will automatically find all the drivers and also install most of the original factory software. BEWARE OF GENERIC DISKS ! All Drivers and factory software are operating system specific so you must have the correct software and drivers for your Acer Extensa 5230EWindows 7. Some of the drivers you would find on this Acer Extensa 5230E Windows 7 Restore Disk are listed below. Not all will be applicable to your system as this list is for information only for Acer Extensa 5230E Windows 7 Restore Disk.
THIS DISK DOES NOT CONTAIN AN OPERATING SYSTEM!
YOU WILL NEED TO INSTAL Windows 7 FIRST OR USE AN EXISTING INSTALL.
Hope this helps
Dec 18, 2012 | Hitachi Travelstar 5K320 HTS543232L9A300...
Acer Extensa 5230E laptop not charging
More than likely you need to check your DC Power Jack where the power cord plugs into the laptop. If it is loose or broken, it will not charge the battery and will not boot.
Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
May 20, 2012 | Acer Extensa 5230E2913 Notebook
Forget bios user password, so i can´t boot windows on Acer Extensa 5230e. How to clear bios password to use my laptop?
Jan 10, 2011 | Acer Extensa 500T Notebook
Where can i get circuit diagram of Acer Extensa 5230E laptop's mother board..???????
Hi
Following is the link for the manual
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Thanks
Dec 09, 2010 | Acer Extensa 5230E2913 Notebook
I have a laptop acer extensa 5230E, and i want to reset default bios becose i forgot my password
What you could try is to carefully take off the keyboard and look for a little battery on the mainboard of the laptop. Carefully take it out and place it back in the right way.
Make sure that you don't leave stains or greasemarks on the battery.
With kind regards,
Jeffrey
Feb 16, 2010 | Acer Computers & Internet
Jan 08, 2010 | Computers & Internet
Where can I download for free the acer extensa 5230E manual ? for my new computere
Nov 26, 2009 | Acer Extensa 4620 Notebook
Computers & Internet Logo
51 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
