Question about Brother MFC-J430W Inkjet All-in-One MFCJ430W
Error 2001 sending fax to my warehouse show error message: "Comm error 2001", but we fax to others place no such error... why??
  • 990 Answers
SOURCE: brother 420 cn / 6 in 1 fax machine will not fax
Hello sir; I believe this problem belong to you phone comp, better contact with them.
Posted on Jan 07, 2009
Healeyman
  • 1198 Answers
SOURCE: have voip and brother mfc 7420. error code 2001 and 2006
Get a new phone wire. Put a phone on the line and listen for static. Too many phones on one line will cause problems. If the phone line is going thru a surge protector, check the quality of the sound with it and without it, it may be damaged. Keep power wires away from phone wires, they cause static.
Posted on Apr 26, 2009
MUKHTAR
  • 2017 Answers
SOURCE: I cannot receive faxes - it is coming up with
make sure there is no disturbance in phone line .
make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Feb 19, 2010
Jimsta01
  • 405 Answers
SOURCE: What is a Comm. error 2001?
This is an error message you get because of poor line conditions, this is common when sending overseas.
Please follow the directions below for sending overseas.
Press (Fax). Load your document.
Press up or down arrows to choose
Overseas Mode.
Press OK.
Press up or down arrows to choose On (or Off).
Press OK.
then dial number and press start.
Posted on Apr 12, 2010
Testimonial: "Thank you for your good advice!"
  • 76 Answers
SOURCE: Im trying to send a
there is a problem in your telephone line get it repaired
Posted on Jan 20, 2011
Comm error message
PROBABLY BAD PHONE LINE, CAN TRY SOME OF THE FOLLOWING
SLOW DOWN THE RX TO 1700
TURN OFF ECM
INSTALL DSL FILTER EVEN IF ITS NOT A DSL LINE
MAKE SURE THE PHONE COPANY KNOWS ITS A FAX LINE
IF ITS VOIP IT MAY NEVER WORK WELL
RESEAT ALL CONNECTORS IN FAX 3900
TRY SETTING TO MMR
MAY ALSO BE PROBLEM WITH THE SENDING FAX MACHINEOR, THERE PHONE LINE
Jul 11, 2013 | Konica Minolta Minolta FAX3900 Digital...
I've been trying to send a fax to an office in Sri Lanka for several days now, but it won't go. We are getting a Comm Error 388 in the fax error report. The unusual thing is we are able to send fax...
inernational fax calls quite often do not work on digitized phone lines or via satellite. You cannot fix that. maybe your fax has a "fallback 4800 bps" setting that might be helpful.
May 11, 2011 | Office Equipment & Supplies
Everytime I am sending a fax i get the common error 20 02
Comm Error will show on the display if there is an issue on phoneline that were using.
First please check if the machine has a dial tone or try to call the fax # where you need to send the fax, just check if it's ringing. Second before loading the paper make sure that the display shows date & time. Then load the document in the tray the display should show enter fax # & start. Start dialing the # then hit start.
Hope this helps.
Mar 29, 2011 | Brother IntelliFAX 770 Plain Paper Thermal...
Overseas Mode.
Press OK.
Press OK.
Apr 12, 2010 | Brother MultiFunction Center MFC-440CN...
Have voip and brother mfc 7420. error code 2001 and 2006
Apr 02, 2009 | Brother MFC 7420 All-In-One Laser Printer
Hp laserjet 3380
did it work before??
if it did, then your printer has been damaged due to a surge in your phone line
Feb 03, 2009 | HP LaserJet 3380 All-In-One Printer
ERROR MESSAGES
nthemba- all the error codes you see indicates phone line condition or error at reciving fax's end. For more details you can refer to
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02549&lc=en&dlc=en&cc=us&product=79477&rule=17804&lang=en
Sep 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Comm error
could be down to the line, had a similar issue which I believed to be hardware related, so got supplier to send a new fax out, spoke to someone at canon who said is def hardware related, any yet it turned out to be rabbits outside chewed through a cable (was in scotland..) so was a BT issue.
May 27, 2008 | Canon FAX-L1000 Plain Paper Laser
Comm. Error
Try this website: http://www.instruccionesweb.com/u2/pdf/fax/Canon-L120-en.pdf
Jun 25, 2007 | Canon L120 Fax Laser Printer
Brother MFC-J430W Inkjet All-in-One MFCJ430W Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
