Question about Makita MLT100 TABLE SAW FOR 220 VOLTS
Switch wiring I am struggling to wire the switch on the table saw, the Instruction manual does not include a wiring diagram.
    Sergeant:
  • 468 Answers
Did you manage to get in contact with the manufacturer of your saw? They would surely help you with your problem.
Posted on May 03, 2013
5 Suggested Answers
SOURCE: makita table saw switch wiring
After much trial and error, a little smoke, and wrecking one replacement switch, I solved a similar problem with my Craftsman Cmpd Mitre saw. Different saw, but likely the same principles are involved.
If the switch is a double pole single throw switch, with one side normally open (N0) and the other normally closed (NC), and the saw has a separate wire for the brake, this will probably work.
One side of the switch should have contacts that are normally open (NO) and only connect when the switch is ON. The Hot (Black) wire from the plug connects to the wire on the machine side (red or maybe black) through this NO side. So, connect these two wires via this NO side and the saw will run when the switch is ON but will have no brake; so far so good.
There should be another wire (Not the neutral white) which is the brake wire. This gets connected to one of the connection sites of the Normally Closed (NC) side of the switch. From the other connection site of this NC side run a short "jumper" wire (of the same guage as the other wires) to the Machine Side of the NO side of the switch (same place as that Red or Black? wire above) .
What seems to happen is this:
There's no power to the machine or the brake when the switch is OFF. Turn it ON and power goes from Hot through the NO (now closed) side and the saw runs. The brake doesn't run when the saw runs because the NC switch is now open. Turn the switch OFF and the NC switch is in fact closed and power is transfered to the brake via the jumper wire from the still spinning armature which now acts as a generator (alternator?). Once the brake has done its job and the armature stops spinning there's no power anywhere until you turn the switch ON again.
Or at least that's the theory, and in my case it works; no more smoke.
Posted on Feb 04, 2009
i need the owner/operator manual for a makita table saw model 12711 please tell me what steps to take to get one
Posted on Oct 20, 2009
Nomodo4u
  • 863 Answers
SOURCE: Table saw will not turn on. I have replaced the
Look for a fuse on this thing. Also, try plugging into a different outlet that you know works.
Posted on Feb 19, 2010
Fiero_GTV6
SOURCE: I have a makita 2703
Actually, it's part #74 in the diagram. Part #75 is one of the 2 brush holder covers that each screws out to access and remove each brush.
Posted on Jun 06, 2012
Model 36-979. Where can I get a wiring diagram for the power switch?
images for Delta Table Saws wiring diagram for power ...
Replacing a Table Saw Power Box and Switch. Rocket ...
? 7:45
https://www.youtube.com/watch?v=8A25b9BjkmY
Feb 12, 2014 - Uploaded by AdventuresInDIY
See how an in the way power box on a 10 inch Delta table sawwas switched out ... Would you happen to have a wiring diagramfor your saw.
Oct 28, 2015 | Delta Saws
Where can i find a wiring diagram for a table saw 113 295750 ?
By that number this is a Craftsman (Sears) saw. Contact Sears and see what they can do.
Not quite sure what you're attempting, but there's really not much in the way of wiring. The AC comes in to the switch, the switch controls the AC to the motor. I don't believe Sears ever made anything but a two phase, 120VAC saw, so there's really only three wires to worry about. AC plus and minus (black and white wires) and a green ground.
Parts are available for almost any Sears saw ever made.Here is the link for the manual for your saw:
CRAFTSMAN 113 29570 Owner Manual
Oct 08, 2014 | Saws
Wire diagram for craftsman 10" table saw
Hi there.
Prior to plug it try this.From your 3 prong grounded plug trace it up to your saw were you should have a black and a white from the same wire's end.Now the two whites are probably from the reset that you haven't replaced?Write back to let me know if this is right and I'll proceed.
Jul 25, 2013 | Craftsman 10" Table Saw
Need a wiring diagram for ryobi ets 1525 table saw switch
http://www.motoruf.de/n/ersatzteillisten.html?id=657306
This is as much as I'm able to find regarding the breakdown and wiring. Sorry I cant seem to fins anything more detailed.
Apr 05, 2013 | Ryobi Table Saw Manual
Powermatic 66 wiring problem
Simple solution: switch two of the wires. Doing so will reverse the direction of the motor. You can switch it at the motor or on the electrical plug end.
Mar 28, 2013 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
I need a wiring diagram for a Delta xl-10 table saw.
Unfortunately, the manual for the XL-10 saw is no longer available online. Here is a link to the parts list and diagram.
If that is not helpful, please consult a qualified electrician, who should be able to guide you in the wiring of the switch and motor for that saw.
Without access to the schematic, I'm afraid the best solution to your wiring question is for some capable electrician to take a look at your saw in person.
Mar 28, 2009 | Saws
Hitachi c10fr table saw wiring diagram
Here is a hand drawn diagram
Please rate this a fixya
Feb 13, 2009 | Hitachi 10", Table Saw with Stand,...
On/off switch table saw
It sounds like you are wiring the switch wrong. Give me the model # and I will look for a wiring diagram for you.
Nov 02, 2008 | Saws
Makita MLT100 TABLE SAW FOR 220 VOLTS Logo
317 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
