Question about Baby Gear
4baby reclining carseat
How so i install this car seat?
You need to put a seat belt through the bottom of it you should see where and then at the top you will see an anchoring point that attaches to the car. Google the type of car seat and you should find the manual
Posted on May 06, 2013
ozark333
  • 396 Answers
SOURCE: I installed the car seat
Try this site and input your model # and date of manufacture.
You should be able to print instructions. If not call them.
http://www.safety1st.com/usa/eng/Instructions?ProductNumber=22152BVL
Dorel Juvenile Group
Consumer Relations Department
P.O. Box 2609
Columbus, IN 47202-2609
Phone : (800) 544-1108
Posted on Mar 11, 2011
SOURCE: removing carseat
If you mean that you can't get the hooks off the metal latches in the car then simply push the top of the baby seat to the top of the seat in the car that should give you some slack. I had to do it this morning when I went to turn my sons seat around. Also when you undo the hooks turn them sideways to make sure they just dont rehook.
Posted on Nov 19, 2008
  • 25 Answers
SOURCE: how to install infant car seat
The two clips are both for the LATCH system - they're not top tethers (which go to the back of the seat for forward facing seats only).
You need to choose EITHER the LATCH installation OR the seatbelt installation - doing both together can put too much stress on the belt path of the seat, causing the plastic to weaken.
If your car has the LATCH system, there will be two metal U-shaped anchors in the seat, where the seat back and the bottom of the seat meet. Some cars only have them for the side seats, not the middle, so check your car's owner's manual - if you don't have them specifically for the center seat, you'll have to either install with the seatbelt or put it in a side seat to use the LATCH - don't try using one anchor from each side, as they won't be the proper distance apart.
If you'd prefer to use the seatbelt to install, kneel with all of your weight in the seat to tighten the seatbelt. It's tight enough when it can't move more than 1 inch from side to side if you grab it at the belt path and pull it back and forth. You probably will still be able to pull the TOP of the infant seat back towards the back of the seat of the car - that's not a problem - it helps the seat to cradle the baby through an accident.
You need to have an owner's manual, though - to request a copy, contact their customer service at consumer@djgusa.com or call them at 1-800-544-1108.
Posted on Feb 18, 2009
  • 25 Answers
SOURCE: reclining seat
On the front of the seat, below the harness adjuster, is a handle (on mine, it's red). Pull that handle out while pushing back on the top of the seat.
Posted on Feb 19, 2009
SOURCE: my maxi cosi tobi seat wont recline
Yes it seems to be a design fault. Has happened twice on our Tobi seat.
To fix, lay the seat on its back.
Locate the 3 Torx head screws middle front and rear left and right. You'll need a Torx screwdriver or head of the correct size. http://en.wikipedia.org/wiki/Torx
Undo the screws, then pop the four catches at each corner with a flat-head screwdriver and remove the base.
Look at the recline mechanism, you'll see large bar at the rear (both sides) which is meant to be there. At the front, on one side or the other, you'll see a smaller bar which is part of the hinge for the recline handle. It's slipped sideways and into one of the recline mechanism slots.
Jiggle the recline handle and push the hinge bar back into the centre. It might help to use gravity - lay the seat on its side with the blocking bar uppermost. I can't see a way to prevent this slipping out again over time.
Snap the base back on and replace the Torx screws.
Posted on Apr 23, 2010
I have a quinny senzz stroller and the bracket and or brace that allows the seat to recline has come detached. I am trying to figure out how to put it back together. Any ideas?
I would do research about the stroller with carseat custom car seats and strollers are on recall and be very careful what you're putting your child in and look up research about the company if this keeps up I would recommend you buy a better stroller and carseat
Oct 09, 2016 | Quinny Baby Gear
Lost Maxi cosi recyning rod
Hi
Which model Maxi-Cosi Priori is it?
The original Priori was discontinued some time ago and we can no longer support this product for spare parts or repairs. We would advise that this particular seat is replaced.
The Priori SPS, PrioriXP and PrioriFix carseats are still part of the current range so can be supported for spare parts and repairs. If you visit www.maxi-cosi.com and select which country you're in you'll find a Contact Us tab on the right side of the page where you can click to send your enquiry to the customer care team in your country.
Replacement Recommendation for Older Carseats Carseat Bases
Apr 01, 2014 | Maxi-Cosi Priori
Cannot adjust position
Hi
Grip the carseat on the underside of the front lip, push the button in and lift the front to recline / push down to put in a more upright position.
Feb 11, 2014 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Baby start multi recline car seat fitting instructions
Hi
What is the make and model carseat that you require instructions for and what is the product manufacture date?
Sep 08, 2013 | Baby Gear
Hi, i cannot get my maxi cosi to recline. can you offer any help with ideas?
Hi Lorna - Most commonly this issue is caused by dirt/debris getting caught in the tensioning strap of the harness and gradually pulled into the mechanism of the carseat over time. First recommendation is to remove carseat from the car and remove cover (do not remove harness system from seat) give the carseat fabric and the seat itself a clean and see whether this improves the recline situation. If not, please contact your customer services department - if you're in the UK this is 01284 413 141 Mon-Fri 8.30-4.30
Aug 11, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
I cannot get the seat to recline.
Good Morning
The Maxi Cosi CabrioFix carseat does not have a recline option.
Jul 23, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Can't take off maxi cosi carseat cover, because grey strap at the bottom doesn't come loose.
Slack off the straps as far as possible and recline the seat. Open the strap guard door on the rear of the bit of the seat that reclines (Item 3 on diagram http://www.maxi-cosi.com/media/producthandleidingen/maxicosi/PrioriFix.pdf). The shoulder straps can be released from the metal clasp which is in here.You can now pull the straps through the back of the seatand release the cover.
Oct 20, 2009 | Maxi-Cosi Priori
Need instructions for installing carrier in stroller of Graco Travel system -- aka baby carrier into stroller
Recline the stroller seat. There are probably little plastic handles on each side of the stroller seat that you push in while you stand behind the stroller, to recline that seat. Then, you put the carrier into the stroller, facing the back of the stroller. The little notches in the bottom of the carseat fit right onto the edge of the stroller tray. You can test that you've done it right by pulling upward on the carseat. It should not come up and out of the stroller unless you pull the red handle on the back of the carseat as you life the handle of the carrier. I hope this helps!
Sep 29, 2009 | Graco Quattro Tour Travel System
PEG PEREGO 2006 P3. HOW TO CONNECT AND INSTALL CAR SEAT TO STROLLER?
Recline the stroller flat,under the seat pad there should be 2 pegs that pull out the carseat will click on these,good luck.
Aug 18, 2009 | Peg Perego P3 Stroller 2006 Rubino...
Graco ex duoglider in colburn
the car seat faces the mum and just slops in hun
Mar 29, 2008 | Graco DuoGlider Travel System 7444SAR -...
Baby Gear Logo
480 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
