Question about Zenith C27A24T 27" TV
My tv will not turn on.
My children were playing with the tv remote so I took it from them. I noticed that they had hit the program button on the remote. After that, the remote would not work. I tried to turn the tv off and kept getting the menu info. It would not stop.I pressed the off switch a few times. The tv would not allow me to turn the tv off. I unplugged the tv and now it will not turn back on. When you plug it in it clicks and makes the sound like it is plugged in but the tv will not turn on. Help meee!!!!!
  • 2 more comments
  • Vytis Dec 07, 2007
    My TV will not turn on using the remote or the front power switch. I thought that the cord was kinked so I replaced it but it still will not work. I disconnected the cable and pluged it into another out let and still nothing.
    When I hit the power button in front, it sounds like it wants to come on but even the red power light does not come on.
    It is a Fisher Model #PC-1013. Please Please help.
    Thank you
    Vytis
  • Anonymous Feb 24, 2008
    my tv does not turn on
  • mark1216 Mar 26, 2008
    my Zenith tv wont turn on when i push the power button it makes a click noise and nothing happens
  • SammiO May 16, 2008
    I cannot get my Zenith tv out of "video'. I cannot turn the tv on or off. HELP!!!
My tv does not click at all
Posted on Apr 27, 2008
  • 398 Answers
First of all, forget about the remote and see if the TV functions normally using the buttons on the front of the set itself. If the TV will not power on with the power button on the set itself, then something is wrong inside the TV. If the set works fine from the front buttons but no longer responds to that remote, then the remote has either gone bad or was accidently set to a different brand. In this case, look for the original book that came with the remote (or TV if it is the original remote) and follow the instructions for setting the remote back to Zenith. Try that and post your results here.
Posted on Aug 09, 2007
The GUIDE button on the remote (model EN-33926A) for a Hisense 55K610GWN does not work
my children messed around with the remote and now i can turn the tv on from the actual tv but from the remote when i press channel up or down or hdmi buttons it turns the tv of.. remote model en-33926a
Dec 19, 2013 | Hisense Televison & Video
How to enter to service menu?
you have to program a universal remote to the tv....when it turns on/off and you can adjust the channels then the universal is programmed.......then you have to find the magic button on the universal remote which will open up a little box on the screen with a 4 digit code....I have seen some use 0000. yet for the remote I used (Magnavox MG500S the code was 0413) then you will enter the Service Menu! To access My magic button I had to hit the TV button then the input button on the universal remote.......took me a few times to play with it, yet I finally got it.......hope this helps!!
Nov 10, 2010 | LG 42LD450 42 in TV
How do you program an RCA "RCR 615 DCM1" universal remote? Any instructions out there?
I know this is an old post, however if anyone else needs to know how to program the RCA RCR 615 DCM1 universal remote here is how: Turn on the device you wish to program, dold the device button you wish to program (tv, vcr, dvd, etc.) While holding the button with one hand, press and hold the power button with the other, hold both buttons until the device button lights up and stays on then release both buttons at once. Light should remain on. Point remote toward the device and press play button every 5 seconds until device shuts off. Once the device shuts off, with remote still pointed toward the device, slowly hit the reverse button (rewind button) until the device turns on again and then hit stop button. Now your device should be programmed. Repeat for each device. Hope this helps someone, because I had this problem myself and I played around with the remote until I figured it out . This may work for other RCA RCR----- remotes as well.
Apr 29, 2010 | RCA Universal Remote Control
Can't see "Setup" screen, or any other screens on t.v. monitor
There should be a tv vcr button on the remote control. What you done was you accidently shut off the VCR function. If you hit that button again the tv vcr button it will come back on.
Aug 11, 2009 | GoVideo Go Video DVD/VCR Combo
RCA universal remote
I programmed an rca universal remote by:
TURN ONTHE TV
HOLDING DOWN THE TV ANDTHEON/OFF BUTTON ATTHE SAME TIME.UNTILTHEON/OFF BUTTON STAYED ILLUMINATED.
PRESS THE PLAYBUTTON IT WILL BLINK,IF TV DOES NOT GO OFF PRESS PLAY EVERY 5 SECONDS UNTIL TV GOES OFF.
ONCE TV TURNS OFF HIT THE REVERSE BUTTON THE TV WILL COME BACK ON.
HIT THE STOP BUTTON TO SAVE THE CODE.
REPEAT THIS BUT HOLD THE OTHER DESIRED DEVICE INSTEAD OF THE TV.
HOPE IT WORKS
Igotthisinfo from google....then typed in rca universal remote...there was a sight for programming remote.
Jul 26, 2008 | Sanyo DS24425 24" TV
RCU410wms RCA Remote
http://remotefinder.rca.com/default.aspx?site=rca
This site will give you the codes;
Enter the codes 1> Press Hold Code Search until light stays on
2> press device button ie.TV
3>enter 3 digit code from site
4>Try Power button, if works great if not try another code
That's It!
Feb 10, 2008 | RCA Universal Remote Control
Sentry RMC-10 "Really Big Remote"
What I did to program. Hit "tv1.gif" and then hold down "code search" until it turns the light on. Then hit the on/off button until it turns off the tv......it took at least 20 times for me. Then hold down the "tv" button until it starts blinking. Then hit "ok". Mine then worked!
Dec 25, 2007 | Zenith DBZN-311 Remote Control
Need instruction to program the remote RCA 450
took me awhile but I figured it out
ok
Put your TV/DVD/VCR on
hold in what you want to program TV/DVD/VCR BUTTON
(you dont need codes or anything)
then while holding in what you want to program (TV, DVD, VCR) hold in ON/OFF
both at the same time
when the light comes on and stays on
keep hitting ON/OFF BUTTON
do it slow, when the TV turns off hit the STOP button at the bottom
then hit the button you just programed
then hit the ON/OFF button, the TV/DVD/VCR will turn on
if it doesnt work, repeat. make sure you hit the stop button when the TV/DVD/VCR shuts off, if you hit it an extra time while the TV/DVD/VCR is off it wont work.
took me about 30 mins to figure it out.
I lost my codes too, but I wanted to help all you other people too.. now since I helped you.. check my band out... www.myspace.com/jumpercablenj
Nov 21, 2007 | RCA RCR450 Remote Control
Need codes for the RC450 remote
ok
Nov 13, 2007 | RCA RCR450 Remote Control
Orion TV remote
my orion if you channel down below channel 2 it goes to aux.
Oct 24, 2007 | Orion1934 19" TV
Zenith C27A24T 27" TV Logo
993 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
