Question about Radio Communications
Galaxy 88hl My galaxy dx88hl is a monster that on low has a deadeye of almost 2 and swinging almost 20. My amp is a kl Italy 503, a low input amp. Will I damage the amp? Do I need to turn something down? It's a very crunchy sounding radio, the way it's set.
  • Jesse Coffin May 10, 2013
    ("ucrunchy" is this case meant "good". My only real concern is whether the amp is capable of withstanding an actual pep of 20+ watts. I'm not sure that on a mod monster like this, that a low deadeye is enough, if I'm swinging that much. The amp works well. It's not getting hot. It'll deadeye over 250, and swing 100 more, on am.
    Novelist:
  • 500 Answers
Always check your swr's.. it should be fine with those settings.
90% amps 1 to 5watts input is fine and then the modulation wattage of yours is good. most can take 50w RMS.
use short coax jumpers.. make sure the radio doesn't have the modulation limiter cut. and it is on frequency. and it should be good. maybe try putting little bit of wd40 on the microphone switch to see if thats the crunching sound..??
also make sure you have enough amperage.. and a good heavy gauge power wire to the amp..
if you have any more details let everyone know.. may help narrow down a problem.
Posted on May 07, 2013
SOURCE: Galaxy DX Radios DX88HL
i have a galaxy radio and i need help adjusting it
Posted on Dec 28, 2008
  • 8 Answers
SOURCE: used galaxy 88hl
If you have a receipt for it and you had it less than 2 years it can go to Galaxy in Calif. if is defective. Just go the the Galaxy tech support webpage and follow the directions for an RA #. They do good work. If you want to send it to a top notch repair shop try Dons CB in PA. They are a real Galaxy warranty service center. The # is 814-898-1046
Posted on Mar 29, 2009
  • 773 Answers
SOURCE: kl 203 rm italy linear amp transmitt
You just have to lower your RF power so that the radio is putting out about a 2 watt dead key. Any higher and you will over drive the finals and burn out the final
Posted on May 03, 2009
kb8dns
  • 494 Answers
SOURCE: I have a Galaxy dx 88 hl that don't swing
You will need a good technician. I know of a few but I do not like you to spend money again and again. Email me at...... poikaa@yahoo.com
Posted on Feb 13, 2010
tscmusa
  • 95 Answers
SOURCE: need more talkpower without a linear amp
Send it to a CB shop and ask em to peak it and tune it,shouldnt cost more than 75.00
Posted on Apr 01, 2010
Galaxy DX88HL will not switch from TX to RX and light going from green to off what part do I change?
you cannot do it .Take it to a tech,they will have the proper equipment and knowledge to do it.
May 26, 2014 | Galaxy Radios DX- 88HL Base CB Radio
On my radio I need the settings for the knobs because other people can hear me but I only get static and cannot hear them. Thanks
Band should be E Band high/low button on high 10 khz off AM selected
To check that you have done this correctly frequency counter will read 27.185 plus or minus 5 khz. This is of course proved you have a radio that is converted for 11 meter cb frequencies.
http://www.cbtricks.com/radios/galaxy/dx88hl/index.htm Frequency Conversion is the channel expansion mod/conversion
Sep 16, 2011 | Galaxy Radios DX- 88HL Base CB Radio
What are the buts & nubs go to make the cb work which ones trun or push ?
Assuming you're talking about the Galaxy DX88HL, and assuming the mad has been done to reach the 11 meter band, you press the band button in, that put's you to the E-H banks, select the E/A bank which is high bank E. with the frequency counter on, it should read 26.965 for channel 1. If it reads 26.975, then your +10KHz switch is on, turn it off. you'll then be properly set for 26.965 (ch.1) - 27.405 (ch.40). You also have 5 "hidden" frequencies, these are at ch. 3, 7, 11, 15 and 19. To get to the "hidden" frequencies, go to any of the channels listed and turn on your 10KHz switch. Those frequencies are not attainable on radios that do not have a +10KHz switch or a clarifier capable of sliding that far over. To do repairs and for a full list of schematics, diagrams and so forth, I suggest this site, it has the most coverage of the Galaxy DX88HL as well as other galaxies that I've been able to find. http://www.cbtricks.com/radios/galaxy/dx88hl/index.htm .
May 25, 2011 | Galaxy Radios DX- 88HL Base CB Radio
Sep 14, 2009 | Galaxy Radios DX- 88HL Base CB Radio
Dec 06, 2008 | Galaxy Radios DX- 88HL Base CB Radio
Radio Communications Logo
47 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
