Question about Behringer B215D Powered Speaker (550 Watts 1x15 in)
How to change a driver on Behringer b215d active speaker???..
Driver is not working he is dead I think so I opened the box remowe the amplifier and try to get out the driver but it stuck anyone have an idea how to remove the driver and replace with new one??..
  • 5603 Answers
SOURCE: How do I connect my behringer mixer desk to
The first thing to do is to swap teh L & R INPUTS to the amplifier. Did the speaker that works change?
If som the problem is with the setting of the mixer deck. If it did not change, then the problem is with your speaker wiring of the dead speaker, the speaker itself, or that side of the amp.
If the working speaker did swap, that means problem is with the mixer. The question then becomes how are you connecting to the mixer. You should be using TRS 1/4 inch connectors or preferably XLR from the MAIN outputs. These are balanced outputs connections.
If the inputs are from one of the mono inputs, the PAN control for that channel will control how much goes to each speaker... If at center, both will get same signal.
There are so many possibilities that I can't evaluate them until you try the test to find if it is problem of the amp or the mixer that I have given you to try.
Posted on Dec 28, 2009
  • 5603 Answers
SOURCE: I have a B215D Behringer
This should be close to your schematic;
http://elektrotanya.com/behringer_b215a_power-amps_psu_sch.pdf/download.html
Scroll down to "Get Msnusl" link and download. Leaving it on should NOT have caused a failure, however, if it was running and the input was not being driven there may have been feedback going on that did damage. Only thing to do is take it for repair.
Posted on Mar 20, 2011
mechanicsonl
  • 431 Answers
SOURCE: Beringer PMH 660M has very low power output to speakers and when the volume in increased the output pops in the speakers and goes completely dead, everything else works ok and the lights stay on
could possibly be the volume switch, try changing the switch with one that you hardly use to eliminate the problem. any further probs just let me know. hope this helps
Posted on Feb 16, 2012
  • 23 Answers
SOURCE: direct out kills speaker signal on my behringer bx1200
If it's still under warranty, get it replaced. Otherwise, take to an authorized behringer repair shop, or your local pro-audio repair shop.
Posted on Apr 14, 2012
lucastroo
SOURCE: how do i get parts for behringer b215d my power ic is burn out
Regards, urgent help.
I have a powered speaker Class D, and the PWM isdead. change the IC 3525, is controled by a NE555 which is shutting down. works when connected to a higher voltage 150v, but turned it off, I think by overheating. I already changed mosfets, and ICs. I think that may be some component failure is triggering the protection, someone could help me. I'm a musician and I depend on this car for my livelihood. Thanks
Posted on Nov 23, 2012
How do i change the woofer in the eurolive B215d..does the front screen pop out
Yes, the front screen should just be a compression fit. Something a bit stronger than a paperclip should work fine to pull it out. Work around the edges.
Jan 18, 2015 | Behringer Eurolive B215DWH 550W 2Way PA...
Why does Behringer B215D loudspeaker come on, then after a few seconds shuts off
You have a problemm in your power supply. It's not user serviceable, it needs to go to the repair shop.
Aug 06, 2014 | Behringer B215D Powered Speaker (550 Watts...
How do i connect a Behringer 1202 mixer to a Behringer B215D Powered speaker
Looks like both units accept 1/4" jack & I think the 1202 is unbalance out, so just use a standard screened mono (i.e. 2 pole "TS") jack to jack lead & you should be fine. Good Luck! :-)
Jul 28, 2014 | Behringer B215D Powered Speaker (550 Watts...
How dso I connect a seperate mixer to a Behringer B215D powered speaker
Use the two balanced outputs, intot he inputs on the back of the speaker, 1/4 inch jack should fit.
Alternativly you can do the same via xlr, for a balanced connection.
Jul 28, 2014 | Behringer Xenyx 1202 12-input 2-bus Mixer...
Feb 16, 2012 | Behringer Music
How do i get parts for behringer b215d my power ic is burn out
Jan 06, 2012 | Behringer B215D Powered Speaker (550 Watts...
The compression speaker does not work
Here is your schematic for the power amp. There is a separate amp for the tweeter using a LM3886 which is fairly well protected. Open the unit and test the tweeter driver.
Scroll down to "Get Manual" and click on it to download the schematic. At the site is also the preamp section as a separate schematic. You probably don't need that for the failure you are seeing. A lot of the tweeter drivers seem to get blown up, but once you test you will be able to find if the problem is in the amp or the driver.
May 03, 2011 | Behringer B215D Powered Speaker (550 Watts...
Behringer B215D Powered Speaker (550 Watts 1x15 in) Logo
71 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
