Question about Tools & Hardware - Others
Culligan mc450 constantly dripping through overflow pipe. Any ideas what I should do.?
Overflow constantly dripping. Not sure why or what to do.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 306 Answers
If it is running at the drain for the softener, it has a bad seal pack and it needs to be replaced. You will need a Culligan service tech for this if you are not handy.
RJH2O
Posted on May 10, 2013
Our toilet systern is constantly running it won't shut down
Faulty flush valve or leaky flapper
Nov 30, 2017 | Home
I have a Utica Gas Furnace; the overflow pipe is continuously dripping hot water. What could be the problem?
you did not state which model, therefore detailed instruction or remedy is not possible, telepathy do not work that hot as they show in the movies... these two are most "popular " choices in most of boilers, regardless of brand or heating element.
your release valve is blocked by calcium build-up, lift it few times and it should clean and close correctly, if it is not - need removal and cleaning or replacement, cleaning is cheaper...
another reason can be location of the boiler, if it is much lower than lowest radiator - it can constantly overflow and drip hot water from overflow valve as well.
if these two do not apply - unfortunately - with available information, need to call technician or at least relative with plumbing skills...
Dec 27, 2014 | Water Heaters
Why does my home A/C unit result in a constant stream of water coming out of the overflow drain? I've had the same unit for 5 years, and it seems that it drains water in ever-increasing amounts. Als
Sounds like it is freezing up. Kind of hard to say since you did not say whether it is a central heat and air system. My overflow was constantly draining onto my patio from overflow. I crawled up in the attic and followed the pvc pipe where it came in from the outside and closer to the central unit in the attic I drilled a hole in the 90 degree elbow of the pvc and unclogged the pipe which was frozen from running so long. Then I covered the hole with silicone. no more leak coming from overflow
Dec 27, 2014 | Heating & Cooling
Worcester 35cdi overflow problem
if by overflow pipe you mean pressure relief valve either your expansion tank is full and needs to be drained if that type or replaced if bladder type. but if 1.5 bar is normal pres reading then the pressure relief valve is bad (it is a wear item )
Nov 12, 2013 | Heating & Cooling
Boiler losing pressure and overflow pipe dripping water
replace that leaking safety valve first
May 12, 2017 | Water Heaters
The toilet keeps running constantly - the tube in the tank is overflowing and i can not get the dripping sound to stop. Anything i can do?
The noise is because your float in the toilet is set at too high of a level and it is overflowing and making noise.
Reset your float, to adjust the water level just below the overflow pipe...this should stop your noise.
If it does not correct the problem then you will have to replace the water control unit inside of the toilet tank.
Please rate me
Dec 05, 2010 | Toto Washlet Elongated Toilet Seat Bidet
My waterside watersoftener mc450 Ultra s display keeps flashing
This is under warranty still call Culligan for service. Is it flashing an error code? In the meanwhile unplug the system for two minutes and plug back in, this may reset the controls.
RJ
Aug 08, 2010 | Culligan Sales #SY-750S Under Sink Water...
Overflow outside bathroom dripping how do Ifix it?
Just make sure that the over flow is tight with gasket in place. And all fitting's tight behind wall goin gto tub overflow. If it is check out out next step
1-This is a common issue that comes up. Make sure that the shower valve plate is sealed and tight to tub wall. Reason why I ask that is when you take a shower water will find a way out, down the plate or if tile at the point of where it meet's tub. And will look totally like it's the overflow every time.
May 23, 2010 | Plumb Pak Waste & Overflow Pipe Kit, 1...
Toilet system will not completely stop dripping, resulting in constant drip from overflow. How do I stop it?
Is the drip comming from the small fill tube going into the overflow? If so you may need to raise it a little. The nost common leak is from the flapper or seal. On rare occasioms the flush valve itself has a defect that will cause it to leak. Take a close look at the problem and Im sure you will find it. I hope this helps.
May 14, 2010 | Home
I have a baxi 130he which loses pressure and I have to top up once a day. The copper pipe outside which I believe is an overflow is constantly dripping. Boiler runs fine central heating and hot water.
Hi the pipe out side is the pressure relief valve change the valve or it has something stuck on the seating , changing it will stop the pressure drop
Mar 03, 2010 | Heating & Cooling
Tools & Hardware - Others Logo
81 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
