Question about Brother MFC-9420CN All-In-One Laser Printer
My laser color 9420
First page prints good, remaining pages do not print on the upper left hand corner. Is new printer, have not replaced cartridges yet.
  • 328 Answers
Sometimes when toner starts to get low prints will faed or not print on sides. Make sure the printer is on a very level surface. Remove the toners and shake lightly left to right and reinstall.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 09, 2007
SOURCE:
Printer not printing Magenta with new printer cartridge installed
Are they HP cartridges or knock offs ? Cartridges have circuits in them and they will not work if they don;t match up with the printer. If it continues..contact HP. HP has gotten real messed up in their attempt at preventing people from using knock off cartridge. So much that sometime they screw up their own HP cartridge products.
Dec 12, 2017 | HP Photosmart Pro B8350 InkJet Printer
How to change ink in HP Deskjet F480 printer???
  • Check the ink levels by opening the HP Solution Center. Click on "Settings." Click on "Toolbox." Click on "Services." Click on "Service this device." Click on "Estimated Ink Levels." A graphic will appear showing the estimated ink level in each cartridge.
  • 2 Verify that the unit is on. Open the print cartridge door allowing the print carriage to move to the far right side of the unit. Once the print carriage has stopped, lightly press down on a print cartridge to release it. Pull the print cartridge toward you out of its slot. To replace the tri-color print cartridge, remove the print cartridge from the slot on the left. To replace the black or photo print cartridge, remove the print cartridge from the slot on the right. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  • 3 Remove the new print cartridge from its packaging. Remove the plastic tape by using the pull tab, being careful to not touch the copper-colored contacts or the ink nozzles under tape.
  • 4 Slide the new print cartridge forward into the empty slot. Gently push the upper part of the print cartridge until it clicks into place. The tri-color print cartridge fits into the left slot. The black or photo print cartridge fits into the right slot.
  • 5 Close the print cartridge door. If the print cartridge alignment sheet prints, load it on the left front corner of the scanner glass with the top of the page to the left. Verify that there is plain paper loaded in the input tray, and then press the "Scan" button to align the printer.
  • Read more: How to Replace an Ink Cartridge in an HP Deskjet F340 ' eHow.com http://www.ehow.com/how_2303716_replace-ink-cartridge-hp-deskjet.html#ixzz16MAooFTf
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Nov 26, 2010 | HP DeskJet F380 All-In-One Printer
    Xerox Phaser 7760 prints white diagonal lines across the page. The pattern is pretty conisitent. It starts white on the left side of the page and white remains till the right end of the page. I have...
    Are the white lines in one color or all colors? If it is just one color you should try cleaning the laser window. Open the front cover and in the cover there should be a cleaning wand. Remove the waste cartridge and use the cleaning wand to clean the laser windows located behind the waste cartridge.
    May 18, 2010 | Xerox Phaser 7760/YDX Laser Printer
    Left side of page prints lighter than rest of page
    You should contact Dell about returning these for a replacement, it sounds to me like a manufacturer's error.
    Jan 27, 2010 | Dell 1320c Laser Printer
    Every page covered in magenta and black won't print across the page
    This is caused by toner contamination in the laser scanner unit, it is quite a complex job removing and cleaning the laser scanner. I would suggest you contact HP regarding the repair.
    Sep 04, 2008 | HP Color LaserJet 2600n Printer
    Very faint printing in xerox 3117 laser printer
    my ml 2010 never has printed as dark in the centre of the page even when the toner is full?
    Sep 02, 2008 | Samsung ML 2010 Laser Printer
    Page count unreasonable
    Re you using genuine HP NEW cartridges? If not, you must make sure that whoever has re manufactured the ones you are using has replaced the chip on the cartridge. This tells the machine how many copies are on the cartridge.
    Nov 14, 2007 | HP LaserJet 2550L Printer
    Color Printing Problems
    Are these non-original cartridges by any chance?
    We've had this problem - try oiling the cogs
    Nov 09, 2007 | Konica Minolta magicolor 2300DL Laser...
    HP Color Laserjet 3500 printer - no black on left side of page
    The folded paper solution for for me. Thanks to all for sharing!!!!
    I had the same problem. No black or cyan on the left side of the pages. From this advice... I folded a stack of 4 pieces of paper in half and then half again. I took out the transfer unit and put the folded paper in the upper left corner and then put the transfer unit back in. WORKS BEAUTIFULLY! Thanks you all sooooo... much!
    Sep 25, 2007 | HP Color LaserJet 3500 Printer
    Brother MFC-9420CN All-In-One Laser Printer Logo
    100 people viewed this question
    James Cagle
    James Cagle
    ctnozil
    Victorman
    Victorman
