Question about Konica Minolta bizhub Office Equipment & Supplies
Can I use two letterheads on a Konica C280
I am using a Konica Minolta Bizhub C280 and am having trouble getting it to successfully use two different letterheads in trays 3 and 4. Printing to Tray 3 works successfully, but when printing to Tray 4 the printer refuses to print until someone has gone to it and told it which tray to use. I have repeatedly checked all settings on the printer, server and local print drivers and cannot find any discrepancies. Does anyone know if this can be done and what setting I need to be tweaking in order for it to work?
  • Konica Minolta Master
  • 6,359 Answers
Set one draw to letter head set the other to special that way each draw is different. just make sure the paper weight is correct for each paper.
Posted on Jun 18, 2017
checkitright
  • 1362 Answers
SOURCE: Info print 1140
when you go to the menu of the printer is the paper TYPE set correctly?
tray 2 should be letter ( if using plain paper)
tray 3 legal, label etc...
and tray 1 should be any
Posted on Oct 19, 2007
Kevin Hayes
  • 167 Answers
SOURCE: Paper Tray Settings
You have Auto Tray Switching acticated (ATS). Unless you specify each tray/paper with different settings it will switch.
Go in to the utility menu and you can find this in the paper tray settings area I believe.
You can turn this off completely to avoid this in the future.
If you look around you can even just tweak the settings for this, but in your case i would just shut it off.
Posted on Jun 06, 2008
  • 461 Answers
SOURCE: Lexmark T630 printer pulls paper from wrong tray
Verify your settings under the Paper Menu are correct as far as size and type. All trays with same size and type settings are automatically linked as per the User Guide.
Posted on Dec 31, 2008
  • 398 Answers
SOURCE: printer picking wrong tray for print
From the start menue to printers and faxes go to your printer right click and select properties label the 4 drawers as to paper type and select continue, or auto continue to off.
-Carl, please let me know if this helps.
Posted on Jun 26, 2009
SOURCE: Printing from wrong tray
I have the same problem Peter with my Phaser 8560. Xerox Tech Support has been no help. I've even updated the firmware on the printer and it still won't print to the right tray, even though I have everything setup right on both the client side computer and within the printer itself.
Posted on Dec 08, 2010
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
Konica minolta c280 showing error codes 3423, 3334 and 2451 How can I clear the codes
2451 replace the cyan (Blue ) Image unit
3423 replace the fuser unit
3334 No such code
Jan 09, 2017 | Konica Minolta Bizhub C280 Color Copier /...
My Kinoka minolta biz center c280 is giving me a c 5370, please help fix
MFP control board cooling fan motor's failure to turn. Located in the rear of the machine. Remove back cover. 3x3 inch fan remove dust or replace
Jun 21, 2014 | Konica Minolta Bizhub C280 Color Copier /...
How to fix konica bizub c280 paperjam?
www.konicaminolta.com/...system/technical-support.html
Jun 13, 2014 | Konica Minolta Bizhub C280 Color Copier /...
Konica minolta bizhub cannot stabilize color
What is the code what is image like on the print can run stablilize in the service mode
Apr 17, 2014 | Konica Minolta Bizhub C280 Color Copier
Restriction problem under domain environment(bizhub c280)
call your tech services rep, he will tell you in detail what you are asking..........
have a good time,,,,,
May 23, 2010 | Konica Minolta bizhub C250 All-In-One...
41 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
