Question about Panasonic DMR-E60 DVD Recorder
Sony rdr hx510 recovery - Panasonic DMR-E60 DVD Recorder
Unable to eject cd from sony rdr hx510
Try the instructions under "To unlock the disc tray (Child Lock)" on page 53 of this manual.
Mar 21, 2013 | Televison & Video
Hi there, My sony rdr hx510 will not open and is making a grinding rotating sound. Baby girl either put 1 one or 2 discs in incorrectly. Can you advise on how I can get it opened and renove the discs.
Must used a philip screw driver take out all the screws to the dvd player.Must take the DVD player aparts.Take aparts out the dvd player guard shield to the dvd drive to take out the dvd dic or dics out.Don't push the open button any more,the disc or discs is jamming ur dvd door tray.Will burn out ur disc tray motor,if u keep trying push the open button,trying opening it that way.
Sep 24, 2010 | Sony RDR-HX520 DVD Recorder
What is the type number for sony rdr-hx520 laser pickup unit? It's a hardisk/dvds recorder. not the laser but the whole pickup unit is broke. i want to replace it. what is the typenumber?
If the DVD asembly is the same as for model RDR-HX510, the part number is 1-797-247-12 and costs: $358.56 with a refund of $145 upon the return of the defective unit. Pricing was from tritronicsinc.com a Sony parts distributor. (I could not find a listing for the HX520 model)
Hope this helps.
Dan
Oct 05, 2009 | Sony RDR-HX520 DVD Recorder
Have lost instruction manual for our DVD Recorder
Hi. You can download user manual as PDF file at http://safemanuals.com/user-guide-instructions-owner-manual/SONY/RDR-HX510-_U
(just press on Adobe PDF icon. When the new window
pop-ups copy the 4 falling numbers. Then "Download the user guide" button will appear active.
Good luck and rate my solution!
Feb 14, 2009 | Sony Televison & Video
Sony rdr hx510
i think its your tv. Have you got a widescreen tv?  when i changed my old tv for an lcd the problem disapeared
May 07, 2008 | Sony RDR-HX510S DVD Recorder/HDD Recorder
Dark horizontal lines on Sony KLV-26HG2 LCD TV screen
If you can fix it by yourself, there is a problem in horizontal circuit panel, you need to check that in series because the part appear visbly good but when tested by the exact tester you register busted. that should be replaced immediately. Check also the vertical panel parts of the circuit. but if hard you do the job you may consult the service center of your TV or the vendor of the TV.
ps. please don't rate me if you are not convince of my suggestion.
best regards, melnavz
Apr 08, 2008 | Sony WEGA KLV-26HG2 26 in. HD-Ready LCD...
SONY RDR-HX510 DVD RECORDER
Most likely the hard drive is faulty, or it may need resetting/ formatting.
Chances are that the HD has gone.
capital98
Nov 23, 2007 | Sony RDR-HX510S DVD Recorder/HDD Recorder
Sony rdr-hx510
HOLD THE BLUE HDD BUTTON ON THE FRONT PANEL FOR MORE THAN 10 SECONDS TO REFORMAT THE HARD DRIVE. THIS INFORMATION IS AT THE BACK OF THE USER MANUAL BUT MAY NOT CURE THE FAULT.
Oct 12, 2007 | Sony DVD-NS530 DVD Player
I have a Sony RDR HX510, can you help me?
Have you finalised the dvd disc in the machine ? you must finalise all dvds before playing them in other machines.
Mar 18, 2007 | Sony DVD-NS530 DVD Player
Panasonic DMR-E60 DVD Recorder Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
