Question about PermaGreen Triumph Ride-On Spreader Sprayer T000801
Perma green spreader
It shut off
I have a speedy green 1000 and the drop chute will not close is there a repair kit for this machine?
Phil, Check the attached links,instruction and guides contact Scotts if you have to. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Help Center Contact Lawn and Grass Experts Scotts
Scotts Speedygreen 1000 law spreader spring repair
Replacing Rusted Axle on Scotts Speedy Green Spreader
scotts speedy green 1000 parts diagram Google Search
Apr 15, 2015 | Scotts Company Scotts& Accugreeen 2000...
Need a setting for Scott's Speedy Green EdgeGuard mini
First, I went to the products website, in this case Lesco and looked up the spreader settings:
https://www.johndeerelandscapes.com/home/spreader-settings.aspx
Then, I went to Scotts website and looked up spreader settings:
http://www.scotts.com/smg/node2/SCOTTSCOM/lawn-care/lookup-spreader-settings/7800015-24900013-s
I cross referenced a product on the Scotts website that uses the same settings as one of those listed on the Lesco website and I found my settings that way.
In my case I was using Lesco Pre-M 0.86% 0-0-7 and wanted to apply 5.3 lbs/1000ft. My spreader was a Scotts Turf Builder EdgeGuard Mini with settings from 0-15. I found out by cross referencing that the Scotts Speedy Green 1000 and my spreader used the same settings. So I ended up using the recommended setting of 5.5, as listed on the Lesco website for the Scotts Speedy Green 1000, to apply 5.3 lbs/1000ft of pre emergent using my Scotts EdgeGuard Mini.
Hope this helps!
Mar 30, 2013 | Scotts Company Garden
Where do I get a part for scotts speedy green spreader? A plastic part broke which controls the fertilizer shut off spout.
Scotts does have some replacement parts available, depending on the SpeedyGreen model you have. Please give Scotts a call at 800-543-8873 and we'll be happy to assist you with replacement parts. Hilary @ Scotts
May 19, 2011 | Scotts Accugreen 3950 Spreader Green 73730
I have a scotts standard spreader what setting should i set for using xl 2g specialty herbicide
If the product you are planning on applying has a spreader setting for a Scotts Speedy Green, or specifically for the Speedy Green 2000; you can use that recommendation in your Scotts Standard Spreader. If they do not have a suggested spreader setting for the SpeedyGreen, or SpeedyGreen 2000 settings then this question would best be answered by calling Scotts directly @ 1-800-543-8873. One of our associates would be happy to assist you further.
Feb 19, 2011 | Garden
Speedy Green Parts
Replacement parts for your model can be found at amazon, click here and take a look: Amazon com scotts lawn parts. I hope this was helpful. Cheers
Mar 18, 2010 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
How to use Ace Green Turf Spreader
At the bottom of the spreader hopper is a gate, there should be a setting lock that allows the opening to move only so far. This may be at the handle controls but unlikely.
To be sure of your spreader pattern and rate, use the spreader on a parking lot to see the pattern, you can always sweep up the granules and reuse them! Walking speed is the biggest factor in spreading rates.... Opening is the next....
Jan 30, 2010 | ACE R Broadcast Spreader - Set of 2
How do i calibrate my scotts speedy green 3000 broadcast spreader?
From the OEM Scotts SpeedyGreen 3000 Broadcast Spreader Owners Manual: Calibration Your SpeedyGreen 3000 spreader was calibrated at the factory. You may check the calibration as follows: 1.) Adjust the micrometer setting to 2. 2.) Squeeze the trigger against the handle. 3.) The Calibration line engraved in the Green casing above the top of the shut-off plate should be flush with the back edge of the hopper opening. 4.) To adjust alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer rate setting barrel.
Sep 25, 2009 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
Need spreader settings for Scotts Speedy Green 3000
I found this:
For 18-24-12 %50 PPSCU
Product Application Rate:
*LBS PER 1000 SQFT 4
Coverage:
* 12000
Craftsman 3
Craftsman Drop 7
Cyclone 4.25
Earthway 14.25
Lely 4.5
LESCO HD-1 7
LESCO R-94 7.5
LESCO Rotary (80# & 100#) 15
Ortho 3
Precision 6
Red devil 6
Republic 3
Scott's Accu Green 7.25
Scott's Easy Green 26.25
Scott's R7- X F.5
Scott's R8-A J.5
Scott's Speedy Green 1000 6
Scott's Speedy Green 2000 7
Scott's Speedy Green 3000 6
Spyker 4.5
True Temper 1500 \ 5000 5.5
Vicon 28
Jul 21, 2009 | Scotts Company Garden
PermaGreen Triumph Ride-On Spreader Sprayer T000801 Logo
42 people viewed this question
Top PermaGreen Garden Experts
Dennis Key
Dennis Key
john h
Are you a PermaGreen Garden Expert? Answer questions, earn points and help others
