Question about Targus Amu83us Mouse - Optical Wired - Black Gray
Mouse disassembly Right click not working
Microsoft 800 wireless. How do I disassemble and clean?
How to open microsoft wireless mouse 800 - YouTube
? 3:06
https://www.youtube.com/watch?v=ptrvp9Vjz8g
Aug 25, 2013 - Uploaded by rabb able
This video is about if ur mouse left click is not working or hard clicking for use then this is simple way to open ...
Microsoft Wireless Mouse 5000 disassembly - YouTube
? 0:53
https://www.youtube.com/watch?v=vnU3xYoxcSo
Jan 31, 2012 - Uploaded by keroronsk
Microsoft Wireless Mouse 5000 disassembly ... to get to my scroll wheel...the dang thing's rubber seal has detached and I can't scroll anymore.
Microsoft Wireless Mouse 800 Teardown/Disassembly ...
? 3:35
https://www.youtube.com/watch?v=_I4n-WM3nh8
Mar 21, 2015 - Uploaded by Shin2_D
Microsoft Wireless Mouse 800 Teardown/Disassembly ... [Quick tips] Simple way clean your Android Wear LG Gwatch - Duration: 1:05. by ...
How to disassemble Microsoft Wireless Mobile Mouse 1000 ...
Dec 12, 2015 | Computers & Internet
Why isn't my Acer Aspire 5720 mouse pad responding?
do you have disassembly it????? try to reconnect cables in right position .
Apr 09, 2015 | Acer Aspire 5720 Notebook
Hi, I have USB keyboard and I installed PS/2 optic mouse to my PC. Mouse doesn't work .i have windows 7 ultimad 32 bit and MB DH55TC intel i am changin my optic mouse by roll mouse and again dont...
click start control panel view devices and printers you should see your mouse right click mouse you could open it and then select configuremy mouse or select settings then hardware make sure you have the correct mouse selected also right click on the mouse select properties to make sure you have the correct mouse right click on mouse you can troubleshoot this will activate the troubleshooting for you
hope this will help
Jul 23, 2011 | Computers & Internet
Sometimes debris will obstruct the button contact and can be cleared by disassembling the mouse or blowing in some compressed air.
Feb 24, 2010 | GE Wireless Optical Mini Mouse 3087897985
Microsoft wireless standard mouse won't right click
First, within "Control Panel", and the "Mouse" control, check that the right-button is "associated" with some "action".
Then, you could try to disassemble it, and clean it.
As a last resort, you need to buy a replacement.
Nov 05, 2009 | Computers & Internet
Right button doesn't work; single click with left button
You can probably repair this yourself if you are technically inclined and careful.
There is a tutorial here showing how to disassemble the mouse: http://www.vk2k.com/Logitech-MX1000-Battery/
The microswitches for the buttons can be opened if you are very careful, and then you'll have to clean the contacts. Regular rubbing alcohol should work fine. Be careful not to lose any parts when opening the switch.
If the switch contacts have corroded, you may have to replace the contacts or the entire switch. You may be able to take a similar switch from another mouse (many manufacturers use similar switches). SWometimes there are MX1000 or similar logitech nonfunctioning mice being sold on eBay for parts.
Good luck
Mar 03, 2009 | Logitech MX1000 Laser Cordless...
Right & left click buttons not working
hmm quite interesting
has your laptop suffered some damage
i recomend you try to disassemble your laptop and check the connector for the touchpad.
dont know how try this site:http://repair4laptop.org/disassembly_acer.html
Nov 30, 2008 | Toshiba Satellite A105 Notebook
Mouse Right click doesn't work
hello!
o Install fresh batteries. Try brand new-high quality batteries you absolutely know are fresh and working.
o Install the latest software. Totally remove all software and reinstall from scratch.
o Try a different port and Resynchronize your device to the receiver. Try plugging the mouse into a different USB port try powering down the computer and using the PS2 port for the mouse instead. Mice in my experience overall work better using PS2 ports on PCs that have them.
o Clean the mouse lens. This problem may occur if you are using an optical or laser mouse and the lens on the mouse is dirty.
May 08, 2008 | Microsoft Wireless Optical Mouse
Microsoft wireless intelimouse explorer 2.0
Having experienced the same problem with (2) Intellimouse Explorers I analyzed the problem and found a solution after driver updates failed to correct it.
Remove the single screw inside the battery compartment, lift off the rear portion of the mouse top cover, then gently lift up the back end of the remaining shell.
Once you have the inner workings exposed, use a Q-Tip to dab rubbing alcohol on the right click button's micro switch, manually clicking it a couple dozen times to clean the button's inner workings. Do not work about shorting out the mouse, as alcohol is non-conductive, and non-corrosive. It will not harm the electronic circuitry.
It doesn't hurt to do the same for the left click micro switch and the side button switches as well, as long as the mouse is disassembled.
Next use a clean Q-Tip to clean the edges of the top & bottom housing. This is the most likely cause of the right click button failure - there are small particles of debris lodged along the edge where the travel of the right click button is supposed to depress, but cannot.
Next, turn the top cover over and move the catch on the right underside forward and push it gently downward to uncatch the edge of that latching clip. The click on the left underside is a bit more complicated and requires a gentle lifting of the rear pins and moving the left clip more to the left and downward to release it from it's locking position.
Once you have freed the actual button's cover from the rest of the top cover, clean it thoroughly with a Q-Tip swab soaked with rubbing alcohol.
While the works are exposed, check for hair and debris around the scroll wheel as well. The small plastic wheel cover lifts off starting from the read and tipping up and forward.
Carefully reassemble all parts and hte right click function should now be restored. The debris has been removed and the right click now has it's full range of travel restored.
Apr 29, 2008 | Microsoft Wireless IntelliMouse Explorer
Targus Amu83us Mouse - Optical Wired - Black Gray Logo
24 people viewed this question
Top Targus Cameras Experts
Are you a Targus Camera Expert? Answer questions, earn points and help others
