Question about Toshiba Satellite A135-S4477 Notebook
Touchpad doesnt work
My touchpad doesnt work, i have to use an external mouse to browse through my toshiba laptop. I once dismantled it and when I put it together, everything worked well except for the touchpad. [i didnt spill any liquid on it]
    Problem Solver:
  • 10 Answers
Try going to your Device manager and right click on mouse properties and click on the touch pad tab. If you look it probably has the touchpad as disabled. Sometimes this will happen when you use an external mouse. You should be able to unclick the box and change the field from disabled to enable. Its 99.9% of the time NOT your drivers just that the touchpad was disabled. I hope that helps
Posted on Sep 30, 2015
  • Toshiba Master
  • 32,281 Answers
Try reinstalling the touchpad driver.
You can download the touchpad and device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Please click on this link: -
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Posted on May 03, 2013
  • mavradz
    mavradz May 03, 2013
    Hi chris, I have done that but there is no change...
SOURCE: Toshiba Satellite A85-S107 laptop touch pad L-R key not working
try using the fn and f9 to enable or disable the touchpad.
Posted on Aug 02, 2008
SOURCE: toshiba satelite laptop mouse not working
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} So in regards to the touchpad, it’s not working. Device Manager is where you want to go to see if something is wrong with it. You know also, I'm not sure if any other Toshiba has this built in it. Like on some HP, they have a button just to the top of the touchpad. If you hit it, it turns off the touchpad. Hit it again, its back on.
I’m pretty it doesn’t. If the button is not there, then it might be just your touchpad is dead or loose cable on the inside.
Let me know
comier957
Posted on Aug 10, 2008
TampaNative
  • 778 Answers
SOURCE: Hi! My touchpad mouse has stopped working in my
While holding the "FN" key, press the "F9" key and that should re enable your touchpad.
Posted on Apr 19, 2009
benwabnick
  • 2404 Answers
SOURCE: Toshiba Satellite Touchpad not working
Restore the defaults in the BIOS to begin with, this will make sure its not a setting in there that is disabling the mousepad.
Then in windows see if the touchpad is working. If not then take the keyboard out with the power turned off.
When you take the keyboard out you will see the ribbon cable that comes from underneath the touchpad. disconnect it from the motherboard and reseat it firmly back in. Then turn back on the motherboard and see if the mousepad works. If it still doesn't then try the shortcut key to enable it.
If it does't enable then that means its either going to be a mousepad problem where you would have to replace the top cover assembly or a motherboard problem cause it could be where the voltage required to run that mousepad is missing.
Posted on Jun 27, 2009
  • 232 Answers
SOURCE: touchpad on toshiba equium A200-1VO laptop not working
you have lost your driver for the cursor .
go to :
  • www.toshiba.com/taecdpd/support/drivers.shtml
  • this should have all the drivers required for your PC .
    give it a try and let me know how you go
    Posted on Sep 30, 2009
    i heard that the touchpads are UV ray sensitive,, if you expose them to sunlight for very long time, they will lose their sensitivity...or else you just check the driver for it for its working properly or not..
    May 03, 2013 | Toshiba Computers & Internet
    My touchpad and control buttons on toshiba satellite pro c850-FJ don't work
    Contact seller. I'm a bit confused? Brand new Windows 8 install then Uninstalled ? Why? Is Win 8 still installed?
    Feb 11, 2013 | Toshiba Satellite E205-S1904 Laptop
    Sony Vaio laptop (PCG-61317L) once I start browsing the internet, the screen freezes and the mouse cursor disappears from screen. When I don't browse the internet, it sometimes does the same thing
    The reason this is happening is that as you are typing; you're resting some weight on the thin plastic above the touchpad...which then makes contact and registers a 'click'; thus moving your cursor around. Or you're brushing your thumb against it when hitting the space key.
    Some laptops are more susceptible to this than others. Some more modern laptops come with a button to turn the touchpad off to solve this very problem.
    The only thing you can do about this is to disable the touchpad through the touchpad driver (down by the clock, usually) and use a mouse instead. Depending on how you use your laptop, this will be more or less inconvenient- if your laptop never leaves the desk; disable the touchpad and use a mouse...no problem. If you go mobile a lot, you'll have to enable and disable the touchpad all the time.
    The other thing you can do is adapt your typing style so you don't put any weight on anything but the key you're pressing. This is quite difficult and uncomfortable, and is not recommended for long sessions.
    Dec 01, 2012 | Sony VAIO VNCX1/B.CE Mouse
    The touchpad mouse on my toshiba salellite does not function even though it shows it working properly when you go into the touchpad icon. I have an external wireless mouse (usb) hooked up that works fine...
    The touchpad is most probably defective. If you have dropped your laptop the touchpad cable could have get out from its connector on the mainboard. You can get a new touchpad/palmrest on ebay. You have to remove your touchpad/palmrest as shown in the link below, steps 17 to 19 :
    http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
    Identify the part number of your touchpad/palmrest. Search on ebay.com : Toshiba Satelitte A105 palmrest. Buy the one with the same part numer as yours.
    ...or have your laptop repaired by a professional.
    Oct 09, 2009 | Toshiba Satellite A105 Notebook
    How do you unlock the mouse touch pad?
    1. The touchpad and external mouse drivers should be able to work together. Just make sure that you have the touchpad enabled. To see if you have the touchpad enabled, hold the Fn key and press F9. The combination Fn-F9 locks and unlocks the touchpad. If pressing Fn-F9 once, twice, thrice does not seem to lock/unlock your touchpad.. then you might not have the Toshiba hotkeys working or enabled. So lets forget it and try step 2. If Fn-F9 solved your problem.. there you go !
    Arrow The way it works is you have to keep holding Fn key and have to hit F9 once, that should lock the touchpad. Again if you keep holding Fn and hit F9 again, that should unlock it and so on..
    2. Sometimes this solves the problem.. Do a power cycle of your computer.. i.e., unplug the AC.. take the battery out.. Plug the AC back in and try to turn computer ON with AC alone (i.e, leave the battery out and just start computer with AC power).. Once windows loads up and everything is fine, then turn system off. Unplug AC.. put battery back in.. Plug AC back in and restart computer.. All should be working now.. if not, keep reading..
    3. Click on START>go to RUN>type devmgmt.msc
    4. Now in the Device Manager, click on the + sign next to Mice and other pointing devices. Right click on each device listed under "Mice and other pointing devices" and Uninstall ALL the MOUSE Devices you see listed there..
    attention Make sure you ONLY uninstall the Mouse devices and not ALL devices from Device Manager like your CD, Display etc.. Just uninstall the devices listed under Mice and Other pointing devices after you have clicked on the + sign to the left of it..
    5. Go to http://support.toshiba.com there click on Downloads.. select your computer.. Product=Portable, Family=Satellite, Model=M35X-S149.. then click on "GO" button on the right.. Again in the next page that comes up click on "Downloads"..
    6. In the page that came up saying Downloads ( All operating systems, All categories ), at the top drop the list Filter by Operating System and select Windows XP (I am assuming you have XP.. if you have another OS, select that instead).. then on the right of it, drop the list Filter by Category and select Touchpad.. then click on the button "Apply Filters"..
    7. Now you just see two drivers listed..
    09-30-2004 Toshiba Utility
    Touchpad Toshiba Touchpad Enable/Disable Utility for Windows XP (v1.27.0.3; 09-24-2004; 5.34M)
    06-15-2004 Driver
    Touchpad Alps Touchpad Driver for Windows XP/2000 (v6.0.303.5; 05-26-2004; 2.43M)
    Click on the Download link on the right.. Save them to your computer somewhere in a folder or desktop, where you can remember.. After the files are downloaded, double-click on the file.. Unzip.. then Run.. and it will install the driver..
    8. Restart your computer.. Now the Touchpad should be working fine.. Try Fn-F9 combination.. i.e, keep holding Fn key and tap F9 once, twice to see if it locks/unlocks the touchpad..
    If above doesnt solve it, then please post any errors that you get and I will see if we need to try something else.
    Thanks for using fixya...
    Sep 15, 2009 | HP Compaq nc6000 Notebook
    My mouse button is lock how do i unlock it
    5.Install Drivers
    06-15-2004 Driver
    If above doesnt solve it, then please post any errors that you get and I will see if we need to try something else. Thanks, CF
    Jun 25, 2009 | Computers & Internet
    Touch pad refuses to work
    Try going to Toshiba's support page and re-install the driver for the touchpad. If this does not work. You may need to replace the touchpad itself.
    Apr 16, 2009 | Toshiba Satellite A135-S2386 Notebook
    Mouse or touchpad not working
    add an external mouse/keyboard to fix the onboard fault.
    check the device manager for any yellow exclamation marks. as there may be a faulty or corrupt. keyboard/mouse touchpad driver.
    other option, is to add remove touchpad drivers, and re-install.
    finally, you could check if the settings are correct in the bios.
    Thankyou For Using Fixya.
    Mike @ compurepair.
    Jan 05, 2009 | Toshiba Satellite A105 Notebook
    Frozen mouse
    well the touchpad can be frozen for many resons, primary reasons could be.
    1. the compter is hung in other words it needs to reeboot.
    2. the touchpad has spoiled, if your laptop is under warranty please visit the nearest toshiba service center.
    3.Yes, an external mouse would work but please check if you have a ps/2 port for regular mouses or otherwise please buy a wireless mouse they arent expensive now a days but very convineint.
    Best of luck :-)
    Have a nice day !!
    Apr 19, 2008 | Canon BJC 1000N InkJet Printer
    Toshiba Satellite A135-S4477 Notebook Logo
    138 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
