Question about Brother MFC 7860DW - Multifunction fax / copier / - MFC-7860DW-US
Brother MFC-7860DW Displaying " unable print-Error 6B"
Mix-it-up
  • 832 Answers
SOURCE: Brother Mfc 420cn says machine error AF
Open the small cover that hides the scanner flat cable. It has to be reconnected to the main pcb.
Posted on Oct 23, 2007
  • 12 Answers
SOURCE: I have a Change Unable 51 Error Message on my
hi karn..you need to disasemble your printer and clean your Maintenance unit....the coz of this error 51 is usually you are using competetor ink and then you have reset the counter (error 46) ,after you reset it, you need to change ink absorber if not it will bank those waste ink in the ink absorber and after it is full the waste ink have no place to store and it will jam the mantenance unit and the worse case it the ink maybe spoil other part of the printer go and find engineer  asap if not you need to replace new unit....
Posted on Apr 25, 2009
  • 105 Answers
SOURCE: printing error ''Printing Online'' and nothing prints.
TURN MACHINE OFF HOLD DOWN STOP KEY AND THEN TURN ON OR PLUG IN
Posted on Aug 20, 2009
Semi-Driver
  • 434 Answers
SOURCE: brother MFC-465CN printer Error code 51 unable to print
Usually this is caused by a foreign object or debris under the printhead path, or under where the printhead "parks."
Unplug the machine. Open the cover. Check the printhead path for little bits of paper, push pins, paperclips, staples etc. Note the location of the printhead.
If the printhead is at the far left, gently slide it towards the center (do not force it). Look carefully under where the printhead was stopped for debris. Use a flashlight if necessary.
Close the cover. Plug in the unit. Try again.
Posted on Jan 21, 2010
komguy
  • 2306 Answers
SOURCE: Brother MFC-6490CW printer error unable to print
Any of the 30 series errors say that the carriage is not free to move from side to side across the paper. You need to look close on each side of the machine where the carriage travels to see if there's a paper scrap stopping it. Also the encoder strip could be out of the slot in the carriage assembly. If all is OK you need a shop repair to determine if the logic or carriage pcb's are OK.
Posted on Feb 09, 2010
6b error what part replac fused unit or power supply
Your fuser unit is faulty, could be due to the thermistor in it.
Oct 17, 2014 | Brother MFC-8440 All-In-One Laser Printer
How to reset " replace drum" for brother MFC-7860DW
Time to really order a new drum and really replace with a new one.
Resetting the drum unit will not improve print quality. It only resets your drum and allows you to continue to print. You decide when to replace the drum unit not the manufacturer!
1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
2.Replace the drum unit and toner cartridge into printer.
3.The error message "Change Drum Soon/Drum end soon" will continue to appear if the drum counter was not reset when you replace the drum unit.
4.To clear this error message, you need to reset the drum counter as instructed below.
5.Make sure that the machine is turned on.
6.Press Options.
To confirm you are installing a new drum, press 1.
7.When the LCD shows Accepted, close the front cover.
8.Your drum is now reset.
Jul 30, 2014 | Brother MFC-7860DW Laser All-In-One
Why do printouts have increasingly larger blank margins?
Go to the printer's settings menu and look for an option to "Restore Default Settings" or similar words.
Jul 30, 2014 | Brother MFC 7860DW - Multifunction fax /...
Says manual feed. Load paper
There is a manual fee slot just above the paper tray. Sounds like the manual feed slot isn't closed all the way. Here's a link to support for your machine: MFC 7860DW Others Brother Solutions Center Note there is a firmware update available.
Jun 19, 2014 | Brother MFC 7860DW - Multifunction fax /...
Unable to clean 50 error
I have a Brother MFC-440CN fax machine and I am receiving error message "unable to clean 50". Can anyone help me to fix this error problem
Jan 13, 2010 | Brother Office Equipment & Supplies
Oct 23, 2007 | Brother MFC 420CN All-In-One InkJet...
MFC-210C displaying "Unable to Print"
press menu then start mono (b/w) then 4x arrow-up-button. What error code does the machine display?
Sep 24, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 7860DW - Multifunction  fax / copier / - MFC-7860DW-US Logo
73 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
