Question about Mocool Radiator Additive-Motocross Coolant
Coolant how much must we mix the coolant on water? i know they say 20:1, but how many is that
  • Motul Master
  • 17,328 Answers
What make and model and year are you putting it in?
Posted on May 09, 2013
What happen when you put coolant in and dont mix 50/50?
Coolant comes either ready mixed or concentrated, concentrated needs to be mixed with water and ready mixed can be filled as is into the vehicle! Do you know what type of coolant you have used?
Dec 27, 2015 | Cars & Trucks
How do I flush water out and add antifreeze to my 2001 dodge intrepid
Technically speaking, the cooling system uses a 50-50 mix of coolant and water. You can buy coolant already mixed, or full strength.
There are hydrometers that you can buy to test the condition of the coolant. I would suggest draining the radiator and refilling with full strength, then test it. You would still have some water in the block and heater core to mix with the new coolant.
Jun 08, 2013 | 2001 Dodge Intrepid
I have a mitsubishi lancer 2002. The coolant reservoir tank is empty. Radiator is full. I just need to add coolant to reservoir. Do i add straight coolant or does it need to be a 50/50 water/coolant mix?
It is best to add a coolant mix. You can get it ready mixed, but try to ascertain if your car now has in it green mix or red mix. It is best not to mix these 2 mixes LOL
If you cannot make out what is in there now, just add demineralised water.
Dec 14, 2011 | 2002 Mitsubishi Lancer
What is used as coolant in the radiator of 1994 4runner? water or something else?
YOU SUPPOSE TO USE 50/50 GREEN ANTIFREEZE AND WATER TO COOLANT SYSTEM. IF YOU USE STRAIGHT WATER IT WILL BOIL EVAPORATE AWAY WHILE ANTIFREEZE WILL RAISE BOILING POINT.
Jul 04, 2011 | 1994 Toyota 4Runner
I have a pontiac sunfire 2001, Can you poor water to the coolant or just plain coolant? . At the plastic container where you put the coolant it is marked coolant only.... Help!!!! Where you put the water?
Coolant should be mixed with water before adding it to the plastic container. If the coolant is not already mixed with water at a 50/50 ratio, (50 percent water/50 percent coolant) do so before adding. Coolant should always be mixed and not added as straight coolant, the water helps the coolant flow thru the cooling system and aids in helping the coolant remove heat from the engine during the cooling process.
Jul 01, 2011 | 2001 Pontiac Sunfire
I need to know what type of coolant to put in my truck
Use the green. Just make sure that it mixes with all coolants.
Feb 20, 2011 | Toyota Pickup Cars & Trucks
I have Opel Astra 1997 model. Should I mix coolent with water or use only coolent? If, so, the propotion of coolent : water
You should always use a coolant-water mix. Not only does it give you more protection fron freezing temps but it also gives you more protection from heat. Coolant added to water raises the boiling point.
Normally, cars and trucks use a 50-50 mix of water and coolant which is fine for most situations.Any pre-mix coolant is this ratio. Pre-mix does cost a little more but also saves you the hassle of doing your own mixing. You do have to watch if you are doing your own mixing because coolant is toxic. It's sweet smell will attract pets to drink and it can kill them. It does take more than a drop or two but it can so if you spill wipe it up.
Pure coolant jugs will have a label on the back that gives you a ratio of water to coolant based on temperatures. Read across to find an average low or high temperature in your area and read down to see what the recommended coolant to water mix is.
You should also pay attention to type. Coolant comes in 2 colors, green and red(or a version of it). Green is for cast iron engines and red is for engines with aluminum. According to those who know the green stuff will corrode aluminum and therefore the red is designed to be aluminum friendly. Using the wrong coolant could void warranty.
Hope this helps.
Dec 15, 2010 | GMC G1500 Cars & Trucks
Could you please let me know if it is okay to mix
It's better if you boil it first. Or...buy distilled water. They also sell pre-mixed coolant, that's ready to use.
Oct 08, 2009 | 2003 Lexus IS 300
Mocool Radiator Additive-Motocross Coolant Logo
23 people viewed this question
Top Motul Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Motul Vehicle Part and Accessory Expert? Answer questions, earn points and help others
