Question about Nokia Computers & Internet
Lcd light not litted - Nokia Computers & Internet
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 40 Answers
Feel around the corners of the monitor. until touch screen action activates the monitor to on.
Posted on May 09, 2013
I have a LG 50LN5600 LED Smart TV w/sound no/pic Have replaced the power supply board and t-con board. Main board only one left and research says that this would not be a main board prob. Any help?
If the LCD panel back light is not lit you have a bad LCD panel. If the back light stays lit when the set is turned on then you almost certainly have a bad main board since you have already replaced the power supply and T-con.
Aug 17, 2015 | LG Televison & Video
Lights on but not cooling, LCD display is lit up but blank
The LCD is light up by the lights in the refrigerator, so that doesn't mean the board is turning on just the interior lights. I would have to recommend a service call.
Sep 21, 2013 | Sub-Zero Refrigerators
My omnia 7 LCD abnormal display. The LCD takes time to light up and display nothing.
You may say the display back light is not bright!There is the image, but a dark?If that is so, said display lamp is not lit .Need for a period of time will gradually light up!This may be associated with an operating voltage, at the same time, the display of inverter would let check design does not reach the designated position!Somewhat similar to " light " the voltage is not enough is not lit!You can try, don't open other electrical appliances, the first open display, and then, again other equipment!If the screen is fuzzy, so, I think we should display inside the PCBA plate has a problem!USB Data Sync Cable
Sep 05, 2012 | Eforcity Samsung GT-i8700 Omnia 7...
Washer will not go through spin cycle just puts water in tub then will constantly beep
Hi just read your posting.When the machine stops and beeps an error code will appear.In the models with an LCD screen it will tell you what the code is.On machines without an LCD screen a series of lights will light up. The lit lights will be in a row of 8 lights.Starting from the left to right which lights are lit when the machine beeps?Is it the 2nd and 4th or the 3rd and 6th ----etc----?Please reply with additional information on the error code and I can help you rectify this fault.
Jul 19, 2010 | Fisher and Paykel GWL11 Top Load Washer
My Samsung 2493HM Monitor wont turn on, the blue light just blinks, then after some undetermined amount of time the light goes solid and all is well. It took over an hour today to start working. This just...
sales660, Monitor should not be doing that!!! Use Samsung warranty if available. Complain about "premature failure". Examine black screen for very faint displayed image with aid of bright flashlight(test all owners of CCFL back-lit lcd displays should know) to determine full or partial SMPS shutdown mode. Read more in my fixya profile for more that you can do. It could be bad capacitors or a thermally intermittant solder connection that you or qualified electronics tech will need to fix if warranty not option. After reading and surfing net you will understand your CCFL back-lit lcd display and how it works. Your monitor no different than ANY other brand of CCFL back-lit lcd monitor in it's basic design and operation!!! 12fixlouie
Mar 07, 2010 | Samsung SyncMaster 203B LCD Monitor
My lcd monitor is not working after power failure (syncmaster 170t) .
The monitor was probably fried during the power outage due to a spike just before the power went out.
On the power brick check to see if there is an LED light and see if that is lit when its plugged in. If its not lit up then you may want to try a new power brick, if it is lit up then your monitor is a dead.
Nov 12, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Tv wont turn on, light is lit
Most likely defective capacitors in the power supply. Have you local service center look at it for you.
Oct 15, 2009 | Olevia LT23HVX 23 in. LCD Television
Mx 3000 universal lcd remote
There are 4 reasons why your unit is behaving this way:
1. Charger is the problem.
2. The docking station is the broken.
3. The battery is broken or not accepting charge.
4. The actual unit is the problem.
It is very hard to tell which one is causing this to happen.
Let us do some troubleshooting first:
1. Plug your charger in an A/C outlet and make sure the red power light (left) is lit, otherwise the charger or the docking station is broken.
2. You can test the charger with a multimeter. Unplug the charger from the docking station and measure the voltage across the outside and inside, it should register more than 5 volts DC. If there is a 5Volt DC the docking station is the problem otherwise the charger is broken.
3. If the red power light is lit and the status light (right) is lit too, your docking station is broken.
4. If the red power light is lit, dock the unit into the charger, the status light (left) should turn red when your battery is accepting charge or turn blue when your battery is fully charged.
5. If the status light will not lit at all (while the red power light is on), tap the screen while the unit is docked on the charger. If the unit will become alive, you need a new battery otherwise you need a new unit.
12 hours is very long time to charge, the status light should turn to blue in less than 2 hours especially for a new battery.
Aug 29, 2008 | Universal Remote Control MX-3000 LCD...
LCD LIGHT
LCD screen only displays information when phone is off the hook, goes blank when you hang phone up.
Aug 02, 2007 | Innovage Speaker/Caller ID* LCD Touch...
Computers & Internet Logo
61 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
