HOW DOES THE BOTTOM MECHANISM WORK
WONT WORK
  • 7,627 Answers
What is the Router Make, Model? "BOTTOM MECHANISM"?
Posted on May 03, 2013
Why wont vcr work after new belt. mode a waste of time
Whenever you work on a VCR, or the mechanism goes faulty, the mode switch - which tells the electronics what mode the mechanism is in - has to be set up correctly. This is a very complex procedure and unless you have done it before you will need a service manual. Mostly because the mechanism is rarely ever set up in eject mode. At the moment you VCR is trying to work out what mode the mechanism is and is trying to eject a tape, when the mechanism has already done so!
Feb 01, 2016 | Televison & Video
Radio wont show display...yet radio works...a/c isnt blowing cold air....freon is full..and in the same area button to release rear hatch isnt opening it...nor is the key !!!
Radio is an internal problem. A/C, have your mechanic friend check the high and low pressures, along with the outside temperature when he checked it. Repost, I'll tell you what's wrong. And the hatch, there is a rod that unlocks it, it has came loose in the hatch. You have to climb in back and pop off the top bezel for the hatch. Then remove the screws on each side of the bottom bezel. Start popping it out, enough to reach down and open the hatch. After it is open, remove the screws at the handle on the bottom and finish popping it off. Replace the plastic tab that has broken for the rod. I suggest replacing all of them.
May 16, 2015 | 2002 Pontiac Aztek
My air innovations humidifier wont turn on
I'm afraid you busted your humidifier using not approved procedures. Maybe it can be repaired, though I don't know much about it's mechanism, so you should take it to some electricist repair tech service
Feb 06, 2015 | Refrigerators
Says add paper . I do & still wont print
Select another tray or bypass tray and set it the same size as the damage tray .. Pull out the tray of the damage tray so it will not be detected. When you printout it will select the other tray of the same size.Select the tray from the properties in your computer if not selecting automatically ..
Oct 29, 2014 | Toshiba e-STUDIO166 Printer
Where is the timing belt on a Singer 3820 located
The timing belt is inside the bottom of the machine.
Dec 07, 2012 | Singer 3820 Mechanical Sewing Machine
Passenger door lock wont work and cannot even pull or push the unlock mechanism
You will need to remove the door panel and replace the electric door lock motor in the bottom of the door, they get water in them and jam from rust.
Sep 26, 2010 | 2003 Ford Taurus
New battery, car wont start..mechanic says to hit the starter..where is the starter...?
first, the starter is on the bottom of the engine toward the back and has a large wire from the battery attached to it. Second, if a mechanic said to hit it he is a pretty sorry mechanic who you should never let work on even your bicycle. Hitting a starter can damage it to the point it can't be rebuilt as it cracks the housing and wire loom assy inside. Sure, it might start a time or two like that but will cost you dearly in the long run.
May 09, 2009 | 1993 Saab 900
Volvo
i changed mine without the filter because i could not find one. i had no problem. the drain was in the bottom.
Oct 09, 2008 | 2001 Volvo C70
Cassette drawer wont eject when cover open.
the flexwire of the camera at the bottom of the mechanical assembly is already cut..it is need to repair that flexwire or replace the mechanical assembly to sony service center....
Oct 29, 2007 | Sony Handycam DCR-HC90 Mini DV Digital...
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
