Question about Ibanez SR Series SR305 5String Electric Bass Guitar
My Ibanez SR 305 bass bridge is broken
There is a slight crack inside the bridge where the head of the string gets locked, so due to this the whole bridge has to be replaced. Is there an alternative solution or if not where can it be purchased?
4 Suggested Answers
  • 30 Answers
SOURCE: When I lower the bridge of my ibanez grg170dxbkn
if its your truss rod this is how u adjust it. remove the 3 screws on the plastic piece directly behind the nut bridge. rotate the allen head a qtr of a turn to the right NO MORE THAN A QTR TURN!!!!. let set for preferably 48 hrs (24 would be ok if no more adjusting is required) to allow the neck time to adjust. repeat if necessary.... any more than a qtr turn could cause the neck to twist or crack. have patience after each turn and let it set!!!
Posted on Jan 24, 2010
  • 5603 Answers
SOURCE: How do you setup an
Watch videos on YouTube about guitaar setup. You won't find specific ones, but find one for the same type hollow or solid body and view several. The videos tell what we could not put in words here.
Posted on May 12, 2011
  • 5603 Answers
SOURCE: I recently broke the E
Replace it with the same size as the original and the original type. The 100 sounds right for the E. Make sure it is the SAME type string as there are non magnetic for some guitars and if you have magnetic pickups the bronze types won't work. There are also round wound, flat wound and some are flattened on one side. You need to make sure the replacement is exact type. Take sample of old to show store clerk.
Posted on May 24, 2011
I have an IBANEZ AEG10E with an Ibanez SST Fishman pickup. The problem is the lower three strings are not as loud as the Higher three strings when connected to an amp or mixer.
Assuming you have the bass eq turned up, the problem will be in the pickup rather than the preamp . It's easiest to just replace it.
Sep 25, 2015 | Ibanez Music
Make my bass strings feel lose
Ask for lite gauge steal strings
Apr 29, 2013 | Music
My boy has an esp ltd ax 150 bass which has broken E strings at the bridge since new almost 1 a week the bridge was modified by a Luthier which worked for a small amount of time then the problem came
You friends bass has a burr on the saddle. take a small fine file and go along the pacth of the string...Go over the saddle and slowly file lightly..This should get rid of your problem...take it to a service center if you arent comfortable doing this
Apr 08, 2013 | ESP AX-414 LTD 4-String Electric Bass...
I recently broke the E string on my Ibanez 5 string bass and replaced it with a 100 guage one. The sound level is now very low, lower than both adjacent strings. I have tried lowering the bridge, but this ...
May 24, 2011 | Ibanez Srx505 5 String Srx Bass
High action even though neck is straight. I have also messed with the bridge saddles and not much has changed except it gives fret buzz when i lower the saddles just a little bit. Is high action a common...
Sounds like you need to get it intonated. Take it to your local guitar shop tell them your problem and where you'd like your strings to sit or that straight neck of yours won't be like that for long.
Good Luck, Cody J
Dec 14, 2010 | Ibanez ATK300 Electric Bass
I need a wiring chart for my ibanez edb 605. thanks
This should do it:http://www.ibanez.com/support/wiringdiagrams
Dec 01, 2010 | Ibanez Edb605 5 String Electric Bass...
Ibanez intonation problem
Hi there. Use guitar tuner. Pluck string in open position. Tune. Now pluck same string at 12th fret. If tuner says flat, adjust bridge for that string towards neck. Towards bridge if sharp. Repeat procedure until in tune at open and 12th fret. Go to next string and repeat procedure.
Thanks
Paul
May 11, 2009 | Music
When I lower the bridge of my ibanez grg170dxbkn to the required action of the strings(2mm bass)(1.5mm treble) my strings on the treble side produce a buzzing sound mostly on the 12 fret...do i need to...
I can understand it a bit of a daunting task setting up these guitars (I have bought at least 5 like this) But yes it might be the truss rod ... Without looking at the guitar myself its hard to say ... If you tighten the truss rod remember how much you turned the allen wrench because if it doesnt work your going to need to reset it and start again ... Remember to turn it the right way! and if all else fails ... If your near me (Bournemouth, South of the UK) then you can always pop on over to mine and I can take a look at it.
Failing that just take it to your nearest guitar repair shop and a setup should cost you about £30 if your in the UK.
Apr 07, 2009 | Ibanez Grg170dxbkn Electric Guitar Hsh...
Ibanez SR Series SR305 5String Electric Bass Guitar Logo
134 people viewed this question
Top Ibanez Music Experts
Michial Gueffroy
Wayne Tolonen
Are you an Ibanez Music Expert? Answer questions, earn points and help others
