Question about Sailrite Ultrafeed LSZ-1 Mechanical Sewing Machine
Dressmaker s3000 euro
I am also looking for a User manual and/or a diagram of the underside, my feed dogs I believe need to be adjusted...anything might help, thank you for your troubles ahead of time, sincerely
My euro pro EP382 problem: needle goes down & then it locks up. When I free it there is an extra thread with the bobbib thread that comes up. What can I do to fix this?
Euro Pro Sewing Machine - YouTube
? 0:59
https://www.youtube.com/watch?v=QndkRbDfM2w
Jan 20, 2009 - Uploaded by simplysoldstore
Euro Pro Sewing Machine. ... on piece on top then runs downthe right side of long and around the bottom up ...
EURO-PRO 380 INSTRUCTION MANUAL Pdf Download.
www.manualslib.com > ... > Euro-Pro Manuals > Sewing Machine > 380
Sewing Machine Euro-Pro Dressmaker 998B Owner's Manual ... take-up lever Palanca tensora de hilo Presser Foot Prensstela Needle plate ... Drop Feed Control / Control De Gota A. Push feed dog lever down to drop feed dog below needle plate for darning, embroidery and button sewing. .... This manual also for: Ep382 ...
Euro Pro Mechanical 30 Stitch Sewing Machine - Overstock ...
www.overstock.com > ... > Sewing Machines
Overstock.com
Rating: 4.4 - ‎5 votes - ‎$119.99 - ‎Out of stock
Shop for Euro Pro Mechanical 30 Stitch Sewing Machine. ... I can sew in the middle of the night and not worry about waking anyone up, it is so quiet, and it sews ...
Amazon.com: Distinctive Even Feed Walking Sewing ...
Jan 05, 2016 | Sewing Machines
Feed dogs wont feed
Look in your manual. They are probably dropped. The switch is normally near your slide on utility tray. If your machine has not been used in two years or more the oil could have seized up your feed mechanism. Could be time for service.
Jan 29, 2014 | Sewing Machines
How do I thred or get instructions for an older sewing machine called '' DressMaker'', I believe the model number is. 63923887 ?
Hi. Relics (http://www.tias.com/stores/relics/) has instruction manuals for Dressmaker sewing machines.
Happy Sewing!
Robbie
Mar 03, 2010 | Euro-Pro Dressmaker 998B
The dog feed stuck in the downward position.
Have you turned the machine off and then back on?
The switch may be broken and you will need to find a sewing machine repair shop that repairs all brands of sewing equipment.
If you decide to purchase another machine try a different brand. This one seems to have on a lot of issues.
Feb 19, 2010 | Sewing Machines
When you set the switch for the feed dogs to be in the up position, turn the handwheel 1 complete revolution and they should come up.
Feb 19, 2010 | Euro-Pro 9105 Computerized Sewing Machine
Dressmaker 2 Date 2608 thread snarled on underside of material. Sewing on one layer of cotten.
Here are a couple of things to try.
- Re-thread your machine, it may be threaded incorrectly.
- Raise your feed dogs if your machine has this feature.
Note:
when you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
Hope this helps.
Sep 24, 2009 | Euro-Pro Sewing Machines
Euro pro problem
Have you checked the feed dog button? To find this check your manual.
Oct 23, 2008 | Euro-Pro 373 Mechanical Sewing Machine
Here's the link; http://www.euro-pro.com/europro/manuals/998B.pdf Hope this helps :)
Aug 20, 2007 | Euro-Pro Dressmaker 998B
Sailrite Ultrafeed LSZ-1 Mechanical Sewing Machine Logo
Top Sailrite Sewing Machines Experts
Derek Massey
Douglas Plant
Douglas Plant
Debbie
Are you a Sailrite Sewing Machine Expert? Answer questions, earn points and help others
