Question about Nokia E66 Smartphone
Mastercode i need my puk code please help me
Nokia 6300 Mastercode Needed, Forgot my security code
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Jan 28, 2013 | Nokia 6300 Cellular Phone
I forgot my security code and wene am restart my mobile he ask me the security code please help me
If it's asking security code.....Default code will be 12345 try the following *You will get the master code from http://www.nokialockcode.com/mastercode.php
or mobile-unlocker.com/samsung-a837/rs2wp9/ and superunlockcodes.com/unlocking-services/rs12wp6
*you can flash your phone to reset the security code to 12345
To flash you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokkia Software updater by selecting this option) *Install the "NOKIA Software Updater" *Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
If it's asking PIN CODE *Default code will be 0000 *Enter the any numbers 3 times and your sim will locks and asks for PUK code.Now contact network operators customer care they will provide your PUK code
Don't enter wrong PUK code 10 times.....
Thank you Don't Forget to rate Have a nice day
Jan 28, 2011 | Nokia E66 Smartphone
Need puk code (6630)
Unlock code:
IMEI number: 356657009905925
This is Your Nokia Mastercode: 0024745063
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 05, 2009 | Nokia 6630 Handheld
Need unlock code for nokia 6300
Hi, alabob...your IMEI: 356436018384038
mastercode:
324525051x
The mastercode can be entered instead of standard security code.
and
hi, jewelahasan your IMEI: 356960019571988
mastercode:
322340244x
and
Hi, Guest please know ---
please tell me your IMEI number by pressing >>
*#06#
Note: IMEI number is must for unlock any phone.
please do not forget to rate this solution if it works.
Dec 13, 2008 | Nokia 6300 Cellular Phone
Need 2 unlock phone
very simple to unlock ur mobile,because lot of unlock source available across the globe inorder to get unlock assistance just reach this http://www.mobileunlocksolutions.com/
Nov 19, 2008 | Nokia 3110 Cellular Phone
SX1is blocked
please can u help me? my siemens sx1 phone is blocked.please help me to release the phone code.thank u for the help..
Jun 07, 2008 | Siemens SX1 Cellular Phone
Forgot my lock code and i am litreally lost ...pls help me sum1.!!
The Mastercode:
This is the code needed to reset the Security code, nothing else, and it's for your phone only. You type in security codes (any) until the phone request the Mastercode, when it does, leave your phone still, don't use it for 15 minutes, then type in the Master code.
SIM pin code:
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even
if your sim is put into another handset.
If this is the code you need then:
Pin Unlock Code (PUK)
If you miss keyed (or forget) your SIM PIN code, and enter the wrong one 3-5 times in a row, the sim will lock up, and you'll need to enter the unlock code to release it. You should ask your Service Provider for this code when you need it. Don't try to guess it, because after a few wrong guesses, the sim will be permanently disabled.
You should have a PUK number, on the plastic card where your sim card was. Enter 2-3 more pin numbers and your phone will lock itself and request the PUK number... tap it in and hey! Presto.
PUK number is available from your network service provider.
Mar 17, 2008 | Nokia N70 Cellular Phone
I forget my phone lock code for my n95 could anyone help, zaids you asked for imei number here it's 358998-01-479249-6 please could you help the e-mail bspq6@yahoo.com
Here's the master code for your phone, although I don't see how that's going to help.
IMEI: 358998014792496
CODE: 4341415744
Your service provider can reset the security code, if that's what you need. Nokia default is 12345
Or if it's the PIN number you need, enter any series of numbers untill it request the PUK number. Your service provider can give you that too, if you've lost the box your phone came in.
Feb 12, 2008 | Nokia N70 Cellular Phone
Master code
Mastercode:
This is the code needed to reset the Security code, nothing else, and it's for your phone only. You type in security codes until the phone request the Mastercode, when it does, leave your phone still, don't use it for 15 minutes, then type in the Mastercode.
To give you your Master Code I need the IMEI number to get this type *#06#
Jan 18, 2008 | Nokia 6300 Cellular Phone
Nokia E66 Smartphone Logo
24 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
