Question about EnGenius EOC-2610 802.11b/g Wireless Access Point
Reset engenius eoc2610
Help not reseting plz help me thank you
4 Suggested Answers
davecon
  • 85 Answers
SOURCE: Engenius EOC-3220+
if you have a the router's manual,there is a guide on how to do that.
but in case you dont have the manual go to the device website and get some guide.default ip varied from different manufacturer
Posted on Apr 23, 2008
  • 351 Answers
SOURCE: resetting EnGenius EOC 3610
Dear Venmattey,
please follow these steps, it works:
1. Connect the EOC-3610 to your computer with a null modem serial cable.
2.Start a HyperTerminal session: Click Start and then select Programs-> Accessories -> Communications -> HyperTerminal.
3. After the HyperTerminal window appears:
a. Give this new connection a name. Ex: EOC-3610.
b. Select correct COM port. Ex:COM1.
c.Set baud rate as "38400", data bits "8", parity "none", stop bits "1",and flow control as "None". Then press “OK” to bring up theHyperTerminal window.
d. Unplug the power on the POE injector and wait 5 seconds then plug the power back in.
4. Wait until the "#" is displayed in the HyperTerminal window.
5. Type "flash reset", then hit enter.
6. Type "reboot", then hit enter. After the device reboots, all settings will be at factory default.
NEW: Keenan Systems has written a software that will soft reset the 3610 series back to factory reset. Thisfree software is provided "AS IS" by Keenan Systems and is notsupported or guaranteed by EnGenius Technologies. Use at your own risk.
Be Happy Always
Regards
Posted on Dec 03, 2008
Macs R We
  • 481 Answers
SOURCE: i have EnGenius EOC-3220 (EOC3220)
Depending on the serial cable you have, you may need a modem (crossover) adapter between the cable and the EOC-3220. A good diagnostic is the following: with the EOC-3220 unplugged from power, connect your serial cable and make all the proper baud rate etc. settings in your serial communications program. When it is running, plug the EOC-3220 into power. If you don't see any garbage characters appear on your screen when you plug the power in, your comm program is probably not set up properly. If you see garbage characters but they are not immediately followed by good information from the EOC-3220, then you either need a null modem adapter inline, or you have a dead EOC-3220. If you've never communicated successfully with an EOC-3220 before over the serial channel, the only way to know if you have a dead one is to try again with a known-good one.
Posted on Oct 27, 2010
How do I reset my password for the EnGenius ESR 900?
To reset the password you can hold the reset button down for 5-10 seconds, problem is now you have to set everything back up unless you saved a config file that has all the settings. Don't forget your password next time. :)
Aug 08, 2014 | EnGenius Computers & Internet
Forgot username and password for acess
Is there a tiny hole in the back of the router? Use a straightened paperclip, or similar,. Press in this hole and hold down for twenty seconds to completely reset your router.
Jan 19, 2014 | EnGenius Computers & Internet
How can you tell if the points are bad on a 1967 Camaro?
If the engine still runs, they are still usable. with the engine off, remove the distributor cap. Rotate the engine by hand until the breaker points are on the high point of the distributor cam, then check the gap with a feeler guage. It should be right around .017". They should be fairly smooth, not pitted up bad. And when the points are closed, (on the low point of the cam ), the point contacts should be lined up with each other. If you have no spark, engine wont run, the condensor is probably burnt out.
Sep 16, 2013 | EnGenius EOC-2610, HD26912 EOC2610 Outdoor...
Unable to login my engenius router from surewest
I wanna login into engenius, but after entering DNS server Ip, I get Air OS, or D-Link interface, to enter username and password. I want engenius inter face, to enter in engenius. anyone here to help plz?
Feb 02, 2012 | EnGenius ESR-1221 EXT Router
I have a Engenius 3220, can't access on 192.168.1.1, I was change the firmware and can't connect now... are another IP to access, I try whit DDRT tool but not can see the IP.-
Try the program Belarc Advisor. It worked for me. I had the same problem when I updated the firmware of my EnGenius ERB9250 Extender. Once Belarc has displayed everything it has discovered about your computer, scroll down to the area labeled Network Map. There you will find your EnGenius 3220's IP.
Aug 22, 2011 | EnGenius EOC-3220 (EOC3220)
How do reset "EOC 8610
Push in the rest button on the back:
Reset Setting
  • Reboot (press 1 second)
  • Reset to Factory Default (press 5 seconds)
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 17, 2010 | EnGenius / EOC-8610 EXT / 54Mbps /...
I am trying to setup my set up a Access Point at my house with the following product. a EnGenius EOC 2611P. when i set security on the device it is not sending an ip address to the computer. is there a...
Assigning an IP address to a computer is a function of DHCP. Either the access point's DHCP server much be enabled, or a DHCP server somewhere on the network to which the AP provides a path must be enabled. There should be only one DHCP server per LAN.
For example, if you have a home router handing out DHCP addresses to computers in your home, and you wire this AP to your router to wirelessly serve an additional computer or computers in a remote location, then its DHCP server should be off, because DHCP service will be performed by your home router to both local and remote computers.
However, if you connect this AP directly to your network interface and serve ONLY computers in a remote location, then its DHCP server should be on, so that it will provide DHCP addresses to the remote computers (because your network interface in general won't, unless it is also a router itself, in which case see the previous paragraph).
Aug 28, 2010 | EnGenius EOC2610 80211g Outdoor High Power...
No reseting engenios router why?
I am pursuing this problem with the poster offline.
Jun 06, 2009 | EnGenius EOC-3220 (EOC3220)
Username password
Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal. c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press "OK" to bring up the HyperTerminal window.
Apr 18, 2009 | EnGenius EOC-3220 (EOC3220)
Resetting the senao eoc-3220 long range wireless access point/bridge
Feb 21, 2008 | EnGenius EOC-3220 (EOC3220)
EnGenius EOC-2610 802.11b/g Wireless Access Point Logo
69 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
