Question about Ricoh Aficio MP-C6000
My printer has frozen resetting a job.
The printer says it is resetting a job but is completely frozen, it also says it is offline, but i cannot connect it back online as it is frozen. the copy and scans function stills works
2 Suggested Answers
Blackhathack
  • 124 Answers
SOURCE: Ricoh Aficio MP C6000 Printer Offline
check weather u have connected all cables properly
then check for your printer driver
after checking if everything is proper then right click on mycomputer select manage then serch for the installed driver then right click on pirticular driver go to properties then select driver tab then select rollback option if this dosent works then go to control pannel then go to printer n scanner option delet the installed printer and add it again
Posted on Jul 05, 2012
Is offline how can I bring it online
It could be just a minor communication issue. Try to unplug your printer from your computer. Unplug and replug your printer into the power source to reset itself. When your printer turns on completely, reconnect it to your computer. If problem continues, you may refer to these articles for further troubleshooting:
- 'Communication Not Available' Error Message and Print Job Stalls in Print Queue - Error: "Problem communicating with the printer" or Bogus Error Messages
You may also contact Lexmark technical support for additional assistance. Thanks.
Feb 17, 2011 | Lexmark Color JetPrinter Z54se InkJet
Error 79.00FE
In order to fix the 79.00FE printer error, first you have to print a configuration page. Then remove the jet direct and power on while holding the go button down on the printer. After display reads offline, the reset process is complete. After the cold reset, remove the jet direct card and see if the 79.00FE error goes away. If the 79.00FE error appears before a job is sent then it may be the DIMMS, try removing them to see if the error persists.
Dec 08, 2010 | HP LaserJet 5100dtn Printer
Printer is offline and will not print. Restarting does not help.
When you double click the Printer and Faxes icon in the Control Panel you will see the printer that your computer is currently using. See.... if the printer image is clear it is online and ready to use, if its blurred then its in offline mode and cannot be use.
To correct offline printer.. some possible reasons is on the usb cable.. check if there is no open wire along the cable...Inserting the USB connector on the other usb slot of the cpu sometimes work just wait first until it is read.
If the printer is still blurred and offline after checking the usb connection, the 2nd thing to do is check the properties of the printer if it is set to offline mode. how? Double click your printer icon. It will display the print jobs window. Click on the Printer tab and uncheck on the "Use printer Offline". Cancel all pending print jobs, close the printer window and try again to print.
Aug 10, 2010 | Office Equipment & Supplies
Printer Offline Message
If your system is showing Printer Offline message, then you need to check the status of the printer in control panel. If it is offline then you need to set it online. The following steps will help:-
1) Click start -> Control Panel -> Hardware and Sound -> Select Printer.
2) If the printer is online it shows "Ready". and if the printer is offline, then it shows "offline".
3) Set the printer online if it is showing offline.
4) Now right click the printer and select "Use Printer Online".
5) The display should change to ready.
Note:- If still you are facing the issues, then update the printer driver or you can also take assistance from any tech support provider such as AskPCExperts. To know more you can also visit: http://www.askpcexperts.com.
Jan 07, 2010 | Epson Aculaser C1100 Printer
Hp Laserjet P2015d has suddenly stopped working. jobs don't reach the printer. printer has to be shut off and "reset" to get jobs to print. Why?
Check to make sure the printer isn't set to Offline mode, if is ok then it sounds like a driver problem, you need to uninstall the printer driver and then reinstall it again.
Aug 03, 2009 | HP LaserJet P2015 Printer
I have 1 offline print job in queue but won't let me cansel or print it or anything else due to error 0x000000005. please help if possible!!!!
Restart the computer. If the print job is still listed uninstall the printer completely restart and reinstall it, then restart again.
Apr 26, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Status on print job says offline dell m5200
a few questions:
-Do you know this printer IP?
-Can you ping this printer?
-How many printers do you have on your network?
-Did all the printers on your network offline or just this printer?
-Did you check the network cable that connected to your printer?
solution:
-you might try to restart printer spooling service on your print server
or
-If your server is still functional, you might try to reinstall/set up this printer on network
Mar 24, 2009 | Dell M5200n Laser Printer
HP4000 not printing LPT1
Dear sir;I believe you can try " cold reset", that's means going to clear all data from the printer memory and sets all the defaults back to the factory settings.performing a "cold reset" resets the jetDireect configuraion. to avoid making changes to yourconfiguration, remove the jetDirect card before performing a cold reset. if possible, print a configuration page prior to performing a cold reset. this will document current settings for later reference.
to perform a cold reset;
1, turn off the printer.
2, while pressing "go", turn the printer on. COLD RESET appears briefly on the display, then INITIALIZING appears.after a few seconds, RESTORING FACTORY SETTING appears on the display, followed by OFFLINE.the cold reset is complete.
3, press "go" to return the printer online "ready " appearson the display.
Little bit complicated but is easy ,hope can take care your problem, GOOD LUCK! Let me know the resolve please!
HAVE A HAPPY HOLIDAY !!!
Dec 15, 2008 | HP LaserJet 4000 Printer
Printing problems
offline means it cannot detect the presence of the printer, though virtually present, check the ff
1- cable are intact, USB or Parallel to PC
2- power line, light on the printer itself
if ok, then reset all queued jobs and restart the PC once again
dont forget to mark my suggestion pls
Jul 31, 2008 | HP PSC 1315 All-In-One InkJet Printer
How to cancel a print job
Press the printer key. The printer screen will appear, and reset job will be an option. You must clear the print queue on the computer or it will just get sent again.
Nov 27, 2007 | Gestetner 10512 Printer
Ricoh Aficio MP-C6000 Logo
Top Ricoh Computers & Internet Experts
Chris Braid
Level 1 Expert
Are you a Ricoh Computer and Internet Expert? Answer questions, earn points and help others
