Question about SanDisk Sansa e260 MP3 Player
Sansa USB and Charger Problem
I purchased a new USB cable and a new charger for my SanDisk Sansa e260. I plug it in to the USB cable, and nothing happened. Then I plugged it into the charger, and again nothing happened. Since my SanDisk Sansa e260 is now out of power, I can't listen to any of my music now.
  • 3 more comments
  • Aaron Schwieterman Aug 15, 2007
    Ok, I replaced the battery on the SanDisk Sansa e260. I turned it on and it worked, but when i tried to plug it into the computer, nothing happened. That goes the same thing with my charger.
  • buteau Nov 02, 2007
    I plugged my sandisk in the computer when I go it and one time after and it charged OK now it turns on and says connected but does not charge
  • Anonymous Feb 08, 2009
    well i put mine in the computer and nothing pot up
  • Anonymous Feb 10, 2009
    wgat if you lost the screws does that affect it?
  • Anonymous May 03, 2009
    My sansa has always charged well since i got it i just plugged in the usb port it would downlad any new music, and recharge, now after a year i plug it in this morning it will say connected after overnight it says battery low... hmmm =+(
Hi ya, ok one of the solution is checking out the trouble of litium battery, i guess has been out of base, i had the same siptom with sansa e250r 2-g, put in right the battery. In back of sansa there are 4 screws that u have to loose it
Posted on Aug 09, 2007
SOURCE:
SANSA FUZE CHARGER
The Fuze charges through its USB connector. You can plug it into a powered USB port on a computer or a USB charger plugged into a wall outlet. You may already have one of these for your cell phone.
If you need a connector cable, you may order one here. One AC adapter is here.
Mar 16, 2012 | SanDisk Sansa e260 MP3 Player
Where do i get a charger for this i can't find the charge can i buy one at a store like walmart or do i have to buy it on the internet.
You can use any AC-to-USB charger. For my Sansa, I use one that came with a cell phone.
Alternatively, you can plug the Sansa into a computer's powered USB port.
Sep 04, 2011 | SanDisk Sansa e260 MP3 Player
Type of charger of Sansa e260 (4 GB) MP3 Player
i have my SanDisk Sansa e260 MP3 Player and i lost my data cable, good thing is i have a spare of apple ipod charger, can i make use of it as data cable and how is it gonna be? thanks
Aug 15, 2011 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 (4 GB) MP3 Player MP3 and Digital Media i have a e260 sansa mp3. when i plug it into my Answer i have a e260 sansa mp3. when i plug it into my computer it wont charge what should i do
There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Jan 30, 2010 | SanDisk Sansa e260 MP3 Player
Charger & headset not working
u can use the USB cable to charge it directly from ur computer or u can buy a universal USB charger from any shop.
Feb 12, 2009 | SanDisk Sansa e260 MP3 Player
Charging my SanDisk Sansa Clip MP3 Player
You will definitely need to get that USB charger cable.
Dec 09, 2008 | SanDisk Sansa Clip MP3 Player
Charger
Your USB port must be repaired. In the meantime, hopefully, your computer has another USB port that you can use. Battery is a replaceable lithium ion rechargeable battery. There are battery chargers that you can connect to wall outlets - the type that plug into the computer would probably require that you plug it into the USB port, which you said is broken - so that's a no-go. There are multiple vendors for battery chargers - one possibility is http://www.greenbatteries.com/
-Tha Mp3 Doctor
Jun 02, 2008 | SanDisk Sansa e260 MP3 Player
SanDisk e260 Problem
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Aug 24, 2007 | SanDisk Sansa e260 MP3 Player
Sansa Battey
or
-Tha Mp3 Doctor
Aug 15, 2007 | SanDisk Sansa e260 MP3 Player
Ipod charger
1 question: how did you do that? i thought the Ipod and the sansa have different adapter types? anyway, i'd suggest getting a new battery. and it's probably because the sansa and ipod use don't use the same amount of energy (volts, etc.) that this happened.
Aug 12, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
80 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
