Port forwarding 443 for netaxs 123 - Computers & Internet
  • 2,878 Answers
Try using portfoward.com and choose the free setup instructions. Listed by games.
Posted on May 06, 2013
Need to unblock a firewall to pick up net flix wireless on my new visio tv how do you do this. it was something like a 80 443 code
80 and 443 are the port numbers,
80 is the default for internet
443 is the default for Secure Socket Layer Internet
There will be an option in your firewall settings of the router
You should be able to forward the exact ports you need to allow them to work
Don't however open all ports as this will leave your computer open to attack
You can assign a pre defined application to by pass the firewewall
You probably need to create a new application, call it "Visio TV" for eg and enter ports 80 and 443 and save it
Apr 05, 2011 | D-Link DIR-625 (790069292637) Wireless...
Tip
Port Forwarding for PLAY STATION on NETGEAR routers
The following steps will help you forward ports on the NETGEAR router for Play station network (PS2, PS3, PSP). At time you can not access or play online games through your PS and in such cases you need to make sure that you have the required ports forwarded on your router as mentioned below. The below steps are applicable for NETGEAR router model WGR614, WGT624, WPN824, WNR2000, WNDR3300, WNR854T, WNR834B etc
1. Open a browser (Internet Explorer, Mozilla Firefox or Safari) on your computer connected to the router.
2. Access the router, usually by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
3. Login to the router (Username = admin and Password = Password unless you have changed it).
4. Click on Port Forwarding under Advanced.
5. Click on 'Add Custom Service' button.
6. Specify any name for the service (PSN1). Select Service Type as TCP/UDP
7. Specify the Start and the End Port as 80.
8. In the server IP Address specify the ip address of the PS3.
9. Click on 'Add' button.
10. Follow the same steps to open the below ports
Start = 443 End = 443 use name as PSN2
Start = 5223 End = 5223 use name as PSN3
Start = 3478 End = 3479 use name as PSN4.
Start = 3658 End = 3658 use name as PSN5.
Start = 10070 End = 10080 use name as PSN6.
Click Apply.
These steps would allow you to access online games on your PS connected through the NETGEAR router.
on Mar 18, 2010 | NetGear WGR614 Router
When trying to connect to the internet wired the ps3 retrieves the ip but gets an error tht says 80710092
Get into your router and Port forward the following ports:
80
443
5223
3478-3479
3658
5001
Most likely your router is blocking this ports
Jun 18, 2010 | Sony Playstation 3 (PS3) Console
I have an edimax IC 7000 pt IP camera, I am having problems getting it to work using port forwarding..I have the latest sw & firmware loaded but seem to be going around in...
You have forward 2 ports.
forward port 80
forward port 443
make sure you have typed in the proper ip address for your camera,
ie. check the admin thingy to get your ip address for the cam.
then check if you can access it locally, then call a friend to see if they can access it remotely.
R.
Feb 11, 2010 | Edimax Computers & Internet
I am trying to open the router ports to allow a ps3 to connect. when i try to play call of duty:modern warfare 2, i keep losing the connection. can you help me open the ports and configure the settings?
Some times you will need to open the Logical Ports on the router.
These are the logical ports.
For this you will need to open the set up interface of the router.
Once you open the set up interface of the router, you will be able to find the settings on the router where you can open the ports for the particular program.
If you are opening the ports for a special device in your network, then you must know the IP address of that device.
For example, wireless camera, DVR, X-box, Play station ...
You can choose the option PORT FORWARDING for a special device application.
If you just want to open the ports for all the network, then you can choose PORT TRIGGERING
For example ,
You have a Linksys wireless router and you want to open the ports for the X-box.
You have opened the set up interface of the router. You will see Application and Gaming TAB at the top.
If you click on that tab you will find different Sub tabs.
Click on Port Triggering => Here you can open the port numbers for the network.
Click On Port forwarding if you want to open the ports for a special device in the network.
Click Save settings once you open the ports on the router.
Some of the recommended port numbers for different applications :
IMAP ==> 143 SMTP : 25
HTTPS ==> 443 HTTP : 80
DNS ==> 53 FTP : 21
SNMP ==> 161 TELNET : 23
XBOX ==> 53, 80-88, 3074
PS3 ==> 80, 443-447 ,5223, 3478-3479, 3658, 10070-10080.
WII ==> 28910, 29900, 29901, 29920, 80, 443
VPN ==> 1723, 500, 443-447, 10000-20000
World of Wars ==> 3724, 6112, 6881 - 6999
Click Here for more info
Dec 13, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
HOW TO DO THE PORTFORWARD
For example ,
DNS ==> 53 FTP : 21
Dec 06, 2009 | Belkin F5D8631-4 Router (F5D8631au4A)
Port Forwarding on NB7Plus4W router
For example ,
DNS ==> 53 FTP : 21
Nov 22, 2009 | NetComm NB5PLUS4W Wireless Router
Having a problem getting DynDNS to pass through router and connect to my web server. Web Server can communicate with DynDNS, but an http or https request (ports 80 and 443) do not get to the server. I...
I did this with a cctv and another dns server and does not really work. So i just change my ip to static and open ports 80 and 443 and 8000 (server) and worked fine without using ddns or free dns. Oh and i use this to check my ports if they are working
http://canyouseeme.org/
Jun 13, 2017 | Encore ENHWI-N Router
Port forwarding my wireless interent linksys and netgear
access the admin page by http://192.168.0.1 - If you have the manuals, you should be able to access port forwarding with the admin page.
Manuals are avail. online, as well.
May I ask, what do u need to setup for port forwarding?
Oct 24, 2008 | Computers & Internet
Help with edimax
port forward the ports used by the ps3 avoid others being firewalled, port forwarding allows connections through the router firewall on specified ports
TCP: 80, 443, 5223 and UDP: 3478, 3479, 4658. UDP: 3658 should also be opened for voice chat.
see http://www.portforward.com/english/routers/port_forwarding/routerindex.htm for instuctions for your router.
Assuming you have turned on uPnP and NAT in the router and that did not work?
Jul 20, 2008 | Edimax Computers & Internet
Computers & Internet Logo
109 people viewed this question
David Payne
David Payne
