Honeywell netaxs 123 port forwarding
I try to port forwarded 443 in the router,so i can login outside network, and then put the static ip into the netaxs 123 panel, after reboot the system, and then open web broswer, cannot login in
SOURCE: Cannot open port 21 for ftp but port 22 is ALWAYS open
fist it a lot
Posted on Nov 13, 2007
SOURCE: TEW-452BRP - can't open a port (forward)
I had the same problem.. the router did forward another port for me (port 12345) so i just set the port for uTorrent to 12344 and it magically worked... i'm not sure why but i would try setting the port to a lower range
Posted on May 02, 2008
SOURCE: port forwading
http://portforward.com/
this site may be of some assistance
Posted on Jun 19, 2008
  • 258 Answers
SOURCE: Port Forwarding not working on Port 80 from our website
The best way to test this is to forward it to a test webpage on another PC or server first to make sure it is working correctly, before trying the unix/linux php server.
In my experience external addresses do not work internally, unless you have your ISP allocate you moe than one external static ip
Please post your results, the provider and whether you already have multiple static ip addresses purchased
Posted on Feb 09, 2009
3764alan
  • 127 Answers
SOURCE: Network routing problem with Axis Camera's
They would need to be on different TCP or UDP port numbers ... in order to access them from the Internet. I'm guestimating that on the LAN you can access all of them because they are on different RFC1918 IP Addresses (e.g. 192.168.1.10, 20, 30) but same port number (e.g. port 80 for web.)
Once you hop through NAT to get to the Internet you now only have one IP Address. The real Internet IP Address. So now you have to have different port numbers for 2 or more cameras. For example use:
#1 port 80
#2 port 8080
#3 port 8081
#4 port 8082
How about that?
And you will have to forward each of those ports to the correct ip address for the correct camera.
Where's my free restaurant dinner? :-)
Posted on Nov 22, 2009
Port forwarding 443 for netaxs 123
Try using portfoward.com and choose the free setup instructions. Listed by games.
May 03, 2013 | Computers & Internet
Tip
Port Forwarding for PLAY STATION on NETGEAR routers
The following steps will help you forward ports on the NETGEAR router for Play station network (PS2, PS3, PSP). At time you can not access or play online games through your PS and in such cases you need to make sure that you have the required ports forwarded on your router as mentioned below. The below steps are applicable for NETGEAR router model WGR614, WGT624, WPN824, WNR2000, WNDR3300, WNR854T, WNR834B etc
1. Open a browser (Internet Explorer, Mozilla Firefox or Safari) on your computer connected to the router.
2. Access the router, usually by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
3. Login to the router (Username = admin and Password = Password unless you have changed it).
4. Click on Port Forwarding under Advanced.
5. Click on 'Add Custom Service' button.
6. Specify any name for the service (PSN1). Select Service Type as TCP/UDP
7. Specify the Start and the End Port as 80.
8. In the server IP Address specify the ip address of the PS3.
9. Click on 'Add' button.
10. Follow the same steps to open the below ports
Start = 443 End = 443 use name as PSN2
Start = 5223 End = 5223 use name as PSN3
Start = 3478 End = 3479 use name as PSN4.
Start = 3658 End = 3658 use name as PSN5.
Start = 10070 End = 10080 use name as PSN6.
Click Apply.
These steps would allow you to access online games on your PS connected through the NETGEAR router.
on Mar 18, 2010 | NetGear WGR614 Router
How do i open my nat for my motorola sbg900
for static IPs: check your router settings. router should be in "bridged" mode so that all the devices have own static "lan" ips like 192.168.0.1 / 192.168.0.255 router will have one lan ip static and one global ip(one it gets from service provider) you must manually give one address of 192.168.0.1 / 192.168.0.255 for your xbox. then give correct subnetmask (default 255.255.255.0) and gateway routers lan ip (default 192.168.0.254) you can aslo put routehrs lan ip as default dns if needed dmz or port forwarding is a tool in your router settings you can assign outside ports to specific ip i have only done manual port forwarding, not sure how dmz works.
Feb 26, 2011 | Arris SURFboard SBG900 Wireless Router...
Port Forwarding on NB7Plus4W router
Some times you will need to open the Logical Ports on the router.
These are the logical ports.
For this you will need to open the set up interface of the router.
Once you open the set up interface of the router, you will be able to find the settings on the router where you can open the ports for the particular program.
If you are opening the ports for a special device in your network, then you must know the IP address of that device.
For example, wireless camera, DVR, X-box, Play station ...
You can choose the option PORT FORWARDING for a special device application.
If you just want to open the ports for all the network, then you can choose PORT TRIGGERING
For example ,
You have a Linksys wireless router and you want to open the ports for the X-box.
You have opened the set up interface of the router. You will see Application and Gaming TAB at the top.
If you click on that tab you will find different Sub tabs.
Click on Port Triggering => Here you can open the port numbers for the network.
Click On Port forwarding if you want to open the ports for a special device in the network.
Click Save settings once you open the ports on the router.
Some of the recommended port numbers for different applications :
IMAP ==> 143 SMTP : 25
HTTPS ==> 443 HTTP : 80
DNS ==> 53 FTP : 21
SNMP ==> 161 TELNET : 23
XBOX ==> 53, 80-88, 3074
PS3 ==> 80, 443-447 ,5223, 3478-3479, 3658, 10070-10080.
WII ==> 28910, 29900, 29901, 29920, 80, 443
VPN ==> 1723, 500, 443-447, 10000-20000
World of Wars ==> 3724, 6112, 6881 - 6999
Click Here for more info
Nov 22, 2009 | NetComm NB5PLUS4W Wireless Router
How do I do port forwarding with one static IP to put my address in my other computers . I need to shadow into with VNC after I install address on my computer is port forwarding marked on the menus are...
Find the IP-address of the computer that you want to accept VNC connections.
Access the router's web-interface.
Find its web-page for "port-forwarding".
Define 'TCP' port '5900' to be forwarded to the IP-address that you found.
Save the settings, and restart your router.
Hopefully, Verizon's FIOS network does not "block" all 'TCP:5900' traffic.
Nov 17, 2009 | Linksys Computers & Internet
Trying to port forward requests to the IK-WB21A webcam. From inside the house it works great. From outside, port forwarding port 8001 to 80 and I get NO response. Tried tcpdump and there is no response...
What are you using to view the Camera? Is this the only IP camera you are viewing/.accessing on the network? If it is not, are you using different IPs in the non-DHCP pool.
Typically you do not have to set-up port forwarding to gain access to the camera within the network. Normally port forwarding is set-up when you are outside your network and need to gain access to different applications/devices in your network using the same static IP address.
Let say you have a camera ip on 192.168.1.20.
You can connect to the camera with your web browser inside your network with the IP 192.168.1.20 (obviously), but if you have the camera set up to only be triggered on a specific port (other than the browser's default 80) let's say 100, then you would enter 192.168.1.20:100.
If the only thing on your network is the camera that you want to access from outside. you would setup in your router to route all incoming requests from port 80 (which is the web browser default) to the IP of the camera. Sometimes routers ask for a range just enter 80 to 80.
If the camera is working on a different port like 8001 then you would port forward 8001 to 8001 to IP 192.168.1.20. You would enter in your web browser (off-site) your static IP 69.132.54.176:8001. But I would suggest if the camera is the only thing you will be trying to gain remote access to, then leave it at 80 and set up forwarding for port 80 to the IP.
That way you can set up a free DNS service and not worry about paying extra for a static.
Nov 13, 2009 | Home Security
How to forward website to belkin n1 vision router
You would have to log into the router to configure port forwarding on port 80. You would have to know the IP address of the computer hosting the website and put that in the routers config under port forwarding.
Oct 27, 2009 | Belkin N1 Vision Router
Feb 09, 2009 | NetGear RangeMax WPN824 Router
Port forwarding my wireless interent linksys and netgear
access the admin page by http://192.168.0.1 - If you have the manuals, you should be able to access port forwarding with the admin page.
Manuals are avail. online, as well.
May I ask, what do u need to setup for port forwarding?
Oct 24, 2008 | Computers & Internet
Port fowarding and remote desktop
Port forwarding is not the only thing that you have to enable to access your home network. Firstly do you just want to access your router from the outside? If that is the case enable remote login via the administration tab.
If you want to login to your computer from the outside then you must first enable remote desktop and enable port forwarding on your router.
You enable port forwarding for port 3389 which is the remote desktop port. So start port is 3389 and end port is 3389 after that set a static IP on your computer that you want to access.
You can enable remote desktop by following the directions below at the link '
http://www.microsoft.com/windowsxp/using/mobility/getstarted/enableremote.mspx
After doing this. What you do is go to the status tab of your router. Look at the IP there.
On the remote computer lauch remote desktop and enter that IP then click connect. IT will then ask you for the username and password of the computer behind the router that you want to login to. After that you should be able to get in.
If you need any clarifications regarding this you may message me and id be glad to help.
Oct 06, 2008 | Linksys Wireless-N WRT150N Router
Computers & Internet Logo
304 people viewed this question
David Payne
David Payne
