Honeywell netaxs 123 port forwarding 443
How do i login outside the network for netaxs 123 and need the steps
StuartB
  • 807 Answers
SOURCE: Port Forwarding
Try here:
http://www.portforward.com
Posted on Aug 11, 2008
mastersaintx
  • 928 Answers
SOURCE: port fowarding and remote desktop
Port forwarding is not the only thing that you have to enable to access your home network. Firstly do you just want to access your router from the outside? If that is the case enable remote login via the administration tab.
If you want to login to your computer from the outside then you must first enable remote desktop and enable port forwarding on your router.
You enable port forwarding for port 3389 which is the remote desktop port. So start port is 3389 and end port is 3389 after that set a static IP on your computer that you want to access.
You can enable remote desktop by following the directions below at the link '
http://www.microsoft.com/windowsxp/using/mobility/getstarted/enableremote.mspx
After doing this. What you do is go to the status tab of your router. Look at the IP there.
On the remote computer lauch remote desktop and enter that IP then click connect. IT will then ask you for the username and password of the computer behind the router that you want to login to. After that you should be able to get in.
If you need any clarifications regarding this you may message me and id be glad to help.
Posted on Oct 06, 2008
marked
  • 6487 Answers
SOURCE: How do I port forward?
This a sample on how to do a Port Forwarding on your Linksys router, you can use this step by step way on how to do that http://portforward.com/english/routers/port_forwarding/Linksys/WRT54G/ABC.htm
Posted on Nov 15, 2008
nitro329
  • 5 Answers
SOURCE: I need to open a port to use utorrent
To open a port, you first need to know what port you need to open. Once you know this you need to access you router properties. Open your browser and go to http://192.168.1.1/ (BE VERY CAREFUL WHEN GOING THERE! You can brick your router!). when it asks for username and password, type it in if you know it, if not check your manuel or http://www.routerpasswords.com/ to find the default login. Once your in there, find something that mentions about ports, for instance, I have a Lynksys router and my port forwarding is under Applications and Gaming>Port Range Forward. When you find the correct page, type in the port number, save it, and there you go! If it mentions about TCP/UDP open one at a time, test it, then close the unused one to prevent a hacker highway into your computer and/or network. To test if your port is open without waiting forever for your torrent or utorrent to say that its still closed, use this free lightweight port checker that I use. http://portforward.com/help/portcheck.htm
Hope this helps,
Dan
Posted on Jun 17, 2009
johnwmaustin
  • 222 Answers
SOURCE: IP Camera Port Forwarding
The best way to find out what is being forwarded is to look at the traffic with the Wireshark program. You can install this from the Internet.
Wireshark is perfect for this but you have to learn how to filter traffic or there will be too much information collected. It is also regarded as (a bit of) a burglar tool so don't use it at work without permission.
I would recommend that you connect a PC to a wired port on the inside LAN and configure the router to forward outside requests to the PC. When you run wireshark on the inside PC with a filter that selects for tcp port 80 (or tcp port == 80) you will see traffic forwarded from the router.
Use your outside machine to request a page from the router's outside address and the port you are forwarding. If you have forwarding set up correctly, you should see a TCP connection attempt. If you are not running a web server on the inside PC, there will be no connection so you will only see the SYN packet from.
outside. If you have a web server on port 80, you will see a fair number of packets in both directions. (SYN -- SYN-ACK -- SYN -- some HTTP Headers an HTTP GET / a response and FIN -- FIN-ACK).
Once you see successful port forwarding (your are forwarding TCP packets, right?) at the PC, change the destination of the forwarding to the camera.
This is really technical but Wireshark is so good that it is quite easy to use.
Posted on Sep 13, 2012
Port forwarding 443 for netaxs 123
Try using portfoward.com and choose the free setup instructions. Listed by games.
May 03, 2013 | Computers & Internet
Tip
Port Forwarding for PLAY STATION on NETGEAR routers
The following steps will help you forward ports on the NETGEAR router for Play station network (PS2, PS3, PSP). At time you can not access or play online games through your PS and in such cases you need to make sure that you have the required ports forwarded on your router as mentioned below. The below steps are applicable for NETGEAR router model WGR614, WGT624, WPN824, WNR2000, WNDR3300, WNR854T, WNR834B etc
1. Open a browser (Internet Explorer, Mozilla Firefox or Safari) on your computer connected to the router.
2. Access the router, usually by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
3. Login to the router (Username = admin and Password = Password unless you have changed it).
4. Click on Port Forwarding under Advanced.
5. Click on 'Add Custom Service' button.
6. Specify any name for the service (PSN1). Select Service Type as TCP/UDP
7. Specify the Start and the End Port as 80.
8. In the server IP Address specify the ip address of the PS3.
9. Click on 'Add' button.
10. Follow the same steps to open the below ports
Start = 443 End = 443 use name as PSN2
Start = 5223 End = 5223 use name as PSN3
Start = 3478 End = 3479 use name as PSN4.
Start = 3658 End = 3658 use name as PSN5.
Start = 10070 End = 10080 use name as PSN6.
Click Apply.
These steps would allow you to access online games on your PS connected through the NETGEAR router.
on Mar 18, 2010 | NetGear WGR614 Router
Not able to stay on line with my playstation3 , tech is telling me that i need a port number
For issues related to PS3 on the router, please follow the below steps fo forward the ports on the router:
1. Connect a computer to the router using any one of the 4 available ports.
2. Open a web browser like Internet Explorer, Mozilla Firefox or Safari.
3. Access the router's GUI by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
4. When prompted for Username and Password, please enter 'admin' for the Username and 'password' for Password.
5. Click on Port Forwarding under Advanced. Click on 'Add Custom Service' button.
Click Apply.
Please revert for any further clarification.
Regards
Anand
Apr 21, 2011 | NetGear N150 / RANGEMAX 150 Router
I keep getting signed out of the Playstation Network Keeps saying error 80710A06 HEELLLPPPP!!!!
80710A06 - An error occurred during the install operation (error when downloading game from PSN - network error occured
This error can occur when the PlayStation Network is down, or when your router is not forwarding ports.
It does appear that the network is down, as stated here. However, you can still check to see if port forwarding is the issue.
To check if you are port forwarding, visit this site and select the router you are using.
These are the ports needed to be forwarded:
-This may not be required if your router has an option called UPNP-
  • TCP:
    • 80
    • 443
    • 5223
  • UDP:
    • 3478
    • 3479
    • 3658 (voice chat)
Mar 01, 2011 | Sony Playstation 3 (PS3) Console
I have Nat type 3 on my playstation 3 i used to have 2 but i didn't do anything to my router is there anyway i can get it back i have a Netgear WNR3500 router
To overcome the issue, please perform the below steps to forward the required ports on the router:
Click Apply.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jan 05, 2010 | NetGear RangeMax Premium Wireless-N...
I am trying to open the router ports to allow a ps3 to connect. when i try to play call of duty:modern warfare 2, i keep losing the connection. can you help me open the ports and configure the settings?
Some times you will need to open the Logical Ports on the router.
These are the logical ports.
For this you will need to open the set up interface of the router.
Once you open the set up interface of the router, you will be able to find the settings on the router where you can open the ports for the particular program.
If you are opening the ports for a special device in your network, then you must know the IP address of that device.
For example, wireless camera, DVR, X-box, Play station ...
You can choose the option PORT FORWARDING for a special device application.
If you just want to open the ports for all the network, then you can choose PORT TRIGGERING
For example ,
You have a Linksys wireless router and you want to open the ports for the X-box.
You have opened the set up interface of the router. You will see Application and Gaming TAB at the top.
If you click on that tab you will find different Sub tabs.
Click on Port Triggering => Here you can open the port numbers for the network.
Click On Port forwarding if you want to open the ports for a special device in the network.
Click Save settings once you open the ports on the router.
Some of the recommended port numbers for different applications :
IMAP ==> 143 SMTP : 25
HTTPS ==> 443 HTTP : 80
DNS ==> 53 FTP : 21
SNMP ==> 161 TELNET : 23
XBOX ==> 53, 80-88, 3074
PS3 ==> 80, 443-447 ,5223, 3478-3479, 3658, 10070-10080.
WII ==> 28910, 29900, 29901, 29920, 80, 443
VPN ==> 1723, 500, 443-447, 10000-20000
World of Wars ==> 3724, 6112, 6881 - 6999
Click Here for more info
Dec 13, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
HOW TO DO THE PORTFORWARD
For example ,
DNS ==> 53 FTP : 21
Dec 06, 2009 | Belkin F5D8631-4 Router (F5D8631au4A)
Port Forwarding on NB7Plus4W router
For example ,
DNS ==> 53 FTP : 21
Nov 22, 2009 | NetComm NB5PLUS4W Wireless Router
I have a cricket broadband wireless internet modem and im trying to get online with my playstation 3
Hi, follow the below steps to forward ports on the router for PS3:
2. Access the router usually by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
Click Apply.
Regards
Anand
Oct 26, 2009 | NetGear WGR614 Wireless Router
Port fowarding and remote desktop
Oct 06, 2008 | Linksys Wireless-N WRT150N Router
Computers & Internet Logo
664 people viewed this question
David Payne
David Payne
