Question about EnGenius EOC-2610 802.11b/g Wireless Access Point
Default password username engenius 2610
Dear sir I need help I can't access user and password I try to reset but not access thank you
3 Suggested Answers
mimranon
  • 72 Answers
SOURCE: username password
Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal. c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press "OK" to bring up the HyperTerminal window.
Posted on Apr 18, 2009
Macs R We
  • 481 Answers
SOURCE: my Engenius access point is having problem wth the
Assuming you are using the proper serial channel reset procedure, this should not be occurring. If it is occurring, your unit is probably malfunctioning and cannot be corrected.
Posted on Nov 01, 2010
I forgot my password on my EnGenius ESR900 wifi router
Almost all routers have a reset button, with the router on, push the button for 20 sec, this should set it to default. user name is always Admin, password most of the time is password, or admin again, good luck
Jan 19, 2014 | EnGenius ESR900 Xtra Range Dual Band N900...
Linksys password recovery
Computer Hope does not assist users in bypassing this security measure. If this is your router and you've forgotten the username or password we suggest that the router be hard reset and then setup with a new username and password.
Default username and password
Before doing a hard reset on the router you may want to try the default username and password. While this is not the same for all routers, this may allow you access to your router.
Username: Admin or Administrator
Password: <Blank>, try just pressing enter or try "admin" as the password as well.
If this does not work and you believe the router is using the default username and passwords try viewing the default settings at routerpasswords.com.
Resetting your router
If the default username and password doesn't work it's likely you or someone whose setup your router has enabled a password that has been forgotten. Thankfully most routers will have a small pinhole button on the back or bottom of the router (like that shown in the picture to the right), pressing this button in and holding on this button for 10-15 seconds will hard reset the router. After this has been done setup the router again and enter a username and password that you can write down.
hope this helps
Dec 21, 2011 | Linksys Wireless-G WRT54G Router
Lost password,after reset (pressing for 5 second), admin/admin failed to log . Pl advice.
Some engenius wireless access points do not have a username password configured by default, so try it with the username and password fields both blank.
Sometimes, I have tried to reset the password on a wireless access point, and later figured out that I had failed to successfully reset the device. Make sure that the device is plugged in while you hold down the reset button. Hold down the reset button for 30 seconds instead of 5.
May 08, 2011 | EnGenius EAP-3660 802.11b/g Wireless...
In my browser address bar i typed 192.168.1.1. when prompted i left user name blank and typed in the default password to my router 'admin'. I cannot get access to change my security pin from the...
You need to factory reset the router by holding down the little button on the back of the router (use a paper clip to push it). After doing so it will reset the password to the default which is admin.
May 06, 2011 | Linksys WRT54G2 Wireless Router
Forgot password and user name
Go to the router and reset it.
To reset it, press and hold the reset button on the router for 30 or more seconds.
The default username is admin, and the password is admin. To configure settings for your router, visit 192.168.1.1. on your browser.
Please don't forget to rate my solution, thanks.
Apr 30, 2011 | EnGenius Computers & Internet
Took unit out of storage. Cannot access 192.168.1.1. Have set proper IP address. Keeps asking for username and password, and admin doesn't work. Lost my created username and password. Please help
just try this. reset the hardware EOC-3220 then,
in your internet explorer browser type, 192.168.1.1 when you get in, it will ask username and password
put admin in username and leave the password blank. or put admin in username same in password.
hope it will help you.
Feb 04, 2011 | EnGenius EOC-3220 (EOC3220)
How do I log into my router config if I don't know the password? I've tried pushing the button on the back to reset but that didn't work
Hi vmontour,
To Factory reset your router you need to locate the Reset Button at the back of the router. The Reset Button is the small hole at the back and you need a Pen or a Paperclip to press it. Press and hold the reset button for 15-30 seconds. Make sure that the router is on when you reset it.
To access the router page just open a browser then type 192.168.0.1. the username is admin and the password is blank.
Rate me if this will help you so that i can help other people.
Thanks for using Fixya.
Jan 31, 2011 | D-Link AirPlus DI-524 Wireless Router
How can i get password to access router from my loptop via WIFI or how can i know the password that came from the factory
Most of the time the user manual provides the default user name and password for the router model. Most seem to come default with admin/admin. If this has been changed and forgotten press in the reset button for 10 - 20 seconds will reset the router to factory defaults. Usually
Oct 07, 2010 | EnGenius ESR9753 Wireless N Router Point ...
Username password
Apr 18, 2009 | EnGenius EOC-3220 (EOC3220)
EnGenius EOC-2610 802.11b/g Wireless Access Point Logo
26 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
