Question about Roundup "" Weed & Grass Killer
Chemical spill in our dam
Spilt 40liters concerntrate in dam, how can i fix water
What is wrong with my pressure washer when I turn in on there is no pressure to the spray
Dear Sir,
Most probably, you left the pressure on when you used it last. You could also have let it with soap or chemical in the system.
When you finish using a pressure washer, you should, after switching off and removing water inlet...RELEASE THE PRESSURE. Before this you can, pass clear water to clean and clear any chemical or detergent. Now to get to the problem. If you do not release the pressure and do not clean from detergent.....this will result in jamming the SPILL VALVE. This valve controls the pressure and controls the shutting down of flow, after gun is closed. Myself I prefer to renew the Spill Valve, than to service it. Now to get to the spill valve....this requires professional work. But if you have the right tools, you can get to it very easy. Usually you can spot a Spill Valve, by noticing a micro switch, with wires protruding out....on top or near the spill valve.
Also beside the spill valve.....there could be something that have locked a valve open. Thus pressure never builds up. To check this, the machine needs to be dismantled altogether. In a few words, the machine can get fixed, but if what I mentioned is too difficult for you, you have to get professional help.
Regards.
Fulltech.
May 24, 2014 | Karcher Garden
Tranaction control wont go off
If you can get to it try unplugging the switch. If this makes no difference it may have damaged something in the electronics. To clarify, You spilled water on the button for the traction control?
Dec 21, 2013 | 2006 Pontiac Grand Prix
Grandson spilt milk on my mitsubishi HD tv how do I get it cleaned if it got into the screen
Do not use any cleaner with chemicals in it---try a lens cloth with just a little pressure and slightly damp with distilled water---you can damage the screen very easily as most are anti-glare coated like a camera lens.
Nov 04, 2012 | Televison & Video
Turn water on then actuate wand trigger. Pressure washer leaks when wand trigger is actuated and has very low pressure/flow output. After releasing trigger the pressure cycles on - off at approx 1 second...
You gave a very close solution yourself for the problem. But other leakages can cause such symtoms.Forexample a leaking head or a leaking chemical inlet. These can be caused because the spill valve (pressure control valve) is stuck. When this valve stucks it will leave a micro switch ON. So the machine keeps working with the gun closed. This will in turn creat internal pressure and damages the head, valves and chemical non-return and even damage outlet hose. So besides fixing the leakages you must check and service the spill valve. I often replace the spill valve. One must also checks if the micro switch is faulty. Now very important that what you mentioned that the machine cycles at one minute intervals, with trigger closed...this is most probably always the spill valve fault. If you open machine you see a place where there is a wire..this belongs to the micro switch...under you find the spill valve. Intake and suction valves may now also have a fault. Also there are systems with non-return valves at the machine outlet. You have to tackle by elimination. Fix the leakage..then tackle spill valve and micro switch.
Fulltech.
Jul 03, 2010 | Karcher PSI Electric Pressure Washer
My son has spilt coke on the laptop 1 key not working O
If you spill drinks on a keyboard, something is bound to break, and apparantly only the O key did... The only way to fix it is to get a new keyboard, I'm sorry. I hope this helps, Yannick.
Jun 09, 2009 | Toshiba Equium 2000 (PV1065E0-011FR) PC...
Spilt water on my computer
take to the near by technician with experience in electronics and IT
May 25, 2009 | HP Pavilion dv8000 Notebook
I pod won't turn on. spilled water on it and it won't turn on.
Just take it to an Apple store or call them on the phone "DONT TELL THEM YOU SPILT WATER ON IT" just say it stopped working. And they will probably replace it.
Apr 10, 2009 | Apple iPod touch
Chemicals left behind in washer
i honestly would check with the manufacture of the chemical, with out knowing whats in it how do you know how to clean it?
Dec 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Karcher electric pressure washer
Dear mike husband,
One reasin for this fault could be a damaged lance or turbo lance. Try by replacing with new ones. If the problem is not solved, then the fault is due to a damaged spill valve. The spill valve could easily be damaged by using not suitable chemical or detergents. After using chemical detergents, one must always rinse the machine by passing pure water. The spill valve could also be damaged by leaving the machine for a long time with pressure in the system. One must never store such machines with pressure still inside. Always press the gun before storing.
Well the solution is to change the spill valve with a new one. In some cases even faulty suction valves can give this problem. But in the majority of cases it is the spill valve.
If you do not know how to fix this problem, it is better to be done by an expirienced technician.
Regards,
MG.
Oct 23, 2008 | Karcher K2.26 Electric Power Washer
Water damage
Consider yourself luck. My spill lost all life in my phone and so I lost my contact list. I wish I had transferred my list to Verizon.com where it can be stored.
Aug 06, 2008 | LG VX8300 Cellular Phone
Roundup "" Weed & Grass Killer Logo
47 people viewed this question
Top Roundup Garden Experts
Mike
Matt Olenzek
Matt Olenzek
Are you a Roundup Garden Expert? Answer questions, earn points and help others
