Calibration Trying to calibrate the machine. Directions are followed to the "T", and the same message pops up every time "Kodak/Tiffen Q-13 Gray scale not detected." What am I doing wrong?
itdude4321
  • 13 Answers
SOURCE: Zebra S600 printer continues calibrating
The factory default settings for the S600 is to auto calibrate every time the printhead is closed and every time the power is cycled. If the media sensor is not positioned correctly for the media you are using the label size will not be detected during a calibration. You mentioned the media has no markings, doe sthe media have a space between the labels? If so, the media sensor may not see the gap in the labels adn therefor is not calibrating properly or not calibrating at all. Check the media sensor position. I have found that the media sensor must be at least 1" from the inner wall of the printer so it doesn't see the edge of the backing in oder to read the size of the labels.
Posted on Feb 02, 2008
  • 2976 Answers
SOURCE: calibrating 5100 kodak all in one easy share printer
Go to the printer maintenance program and select "Calibrate printer".
Posted on Jan 31, 2009
efs_perpends
  • 1996 Answers
SOURCE: What is the matter with "calibration error (1042)" in plotter?
HP actually recommends that you contact them directly when you get this type of error message.
I can provide a link for you to access their troubleshooting online, at http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=82218&prodTypeId=18972&prodSeriesId=82218&objectID=bpp02995
where you can click on the contact HP link in calibration errors to receive further assistance.
Here's that link:
Click here for information on contacting HP support at http://h20000.www2.hp.com/bizsupport/TechSupport/CallHP.jsp?locale=en_US&docIndexId=179680&taskId=101&prodTypeId=18972&prodSeriesId=25301.
If that doesn't interest you, you can browse the HP support forums, and you will find other examples of printers like yours with the same or similar errors, and HP experts who guide them through the fix. http://forums13.itrc.hp.com/service/forums/bizsupport/categoryhome.do?prodSeriesId=82218&lang=en&prodTypeId=18972&categoryId=414&cc=us&admit=109447627+1238315749385+28353475
That's my best advice for a quick solution, to go straight to the source. After all, they have the most experience with these things...
If somehow I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Mar 29, 2009
prashanthcl
  • 460 Answers
SOURCE: Printronix t5000r "GAP NOT DETECTED"
pls you can checked it by gap adjust lever. it is available in right side of printer.
Posted on Oct 20, 2009
SOURCE: Canon LBP-5000 Printer and Calibration
I solved this problem.
You need to bring your printer to some service, and perform cleanig of the printer's optic instruments, which are most probably coverd with dirt, and printer just can't recognize catridges, and can't give you the best print quality.
Just take it to the people who refill toners, or to some official service, they'll know what to do. I had the same problem as you, and today I can't recognize how better print quality is, and more importan, printer is not asking calibration any more.
Posted on Jun 02, 2010
I have a docucolor 12 and x12 fiery. I am trying to calibrate from the fiery. It will printer calibration page, but it can't measure scanner. It comes up with check scanner cable connection. I have tried...
You should have a color separation guide with small gray scale from Kodak. You put the gray scale and the calibration sheet on the glass and follow the instructions from the fiery display.
Jan 02, 2011 | Xerox DocuColor 12 Color Copier
How do you calibrate the scale on a robinair 34700z A/C Machine?
Robinair Model-34700Z,for scal calibration follow as bellow:
Form the main menu go to ''CHANGE DEFAULT'' then press 5454 & YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & press YES key. now follow the on screen text.
NOTE:you should have 9KG/20LBS of weight for scale calibration. Do not change ''TANK TARE''. it must be on factory setup 16.30 lbs OR 7.40 kg.
Hope this will help you to solve thr problem & if my solution is useful to you please vote for it
Aug 27, 2010 | Robinair Cool Tech 34700Z Recovery,...
Over charges. machine seems to operate normal, but it over charges every time. I tried to recalibrate the scale. this didn't help.
It seems to be your last calibration was not correct!
For Robinair Model-34700z scal calibration follow as bellow:
Aug 15, 2010 | Robinair Cool Tech 34700Z Recovery,...
During tank refilling
With switch on press YES/ENTER & STOP/NO key at the same time and watch the screen to come back as normal condition. If it is the same then you have to replace SCALE assy.
After replacing SCALE assy.you must CALIBRATE the new scal before use the machine. For calibration follow as bellow:
Hope this will solve your problem & if my solution is useful to you please vote for it.
Jul 15, 2010 | Robinair Cool Tech 34700Z Recovery,...
How do you calibrate the scales on A robinar 34800
Form the main menu go to ''CHANGE DEFAULT'' then press 5454 (old typ machine 8787 without F1 botton on key pad) & YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & press YES key.now follow the on screen help text.NOTE:you should have 9KG/20LBS of weight for scale calibration.
Hope this will solve you.
May 19, 2010 | Robinair Cool Tech 34700Z Recovery,...
Wont vacuum
With machine power OFF,remove old pressure transducer & replace new one.now power ON the machine & go for calibration.Calibration step for Robinair 34700Z machine.Form the main menu go to ''CHANGE DEFAULT'' then press 5454 & YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & press YES key.now follow the on screen help text.NOTE:you should have 9KG/20LBS of weight for scale calibration.
May 21, 2010 | Robinair Cool Tech 34700Z Recovery,...
PROBLEM WITH WEIGHT CALIBRATION
Calibration procedure for Robinair AC machine.
NOTE:FOR SCAL CALIBRATION YOU SHOULD HAVE 9KG/20LB OF WEIGHT.From main menu go to change default (press 8787 for old type machine or 5454 new type machine)
then press enter/start key.after enter to default nenu you have to select calibrate scal option.press again enter/start key then follow the on scree message.once you done so,press stop/exit key to complete the prcess.
Aug 18, 2009 | Robinair Cool Tech 34700Z Recovery,...
How do you calibrate a new internal scale in a modle 347002k/replaced scale now I need to calibrate it before putting machine back in service.
From the main menu go to change default option,press 5454 then press enter key.after access to default nenu you have to select calibrate scal option.press again enter key then follow the on scree message.NOTE:FOR SCAL CALIBRATION YOU SHOULD HAVE 9KG/20LB OF WEIGHT.once you done so,press stop key to complete the prcess.
Jul 16, 2009 | Robinair Cool Tech 34700Z Recovery,...
Do you know how to calibrate the scale?
From main menu: go to change default (press 8787 for old type machine or 5454 new type machine)
then press enter/start key.after enter to default nenu you have to select calibrate scal option.press again enter/start key then follow the on scree message.NOTE:FOR SCAL CALIBRATION YOU SHOULD HAVE 9KG/20LB OF WEIGHT.once you done so,press stop/exit key to complete the prcess.
Jun 25, 2009 | Robinair Cool Tech 34700Z Recovery,...
Scanner Error
Some electronic equipment such as printers and scanners need to be "calibrated".
I recommend you follow the directions and allow the Scanner to calibrate. This may result in better scans and for printers, better printouts.
Mar 30, 2009 | Kodak I660 Flatbed Scanner
158 people viewed this question
k24674
