Question about Porter Cable Tools & Hardware - Others
Change carbon brushes - Porter Cable Tools & Hardware - Others
3 Suggested Answers
  • 225 Answers
SOURCE: How to cahnge carbon brushes
The brushes usually "come complete with brush-holders", which is a way of selling you something extra that you don't need. Easiest way is to disconnect the machine from the power and the water, turn it onto its front on an old cardboard box and remove the motor from its mountings on the washer. You can usually get acces to one of the brushes really easily and the other is guaranteed to be a real pig, so keep it simple. The brush-holders are usually fastened to the motor casing with either self-tapping screws or small bolts.
I buy my brushes from Ebay sellers and always send them a digital photo of the old brush together with the make and serial number off the motor itself, just to be sure. Brushes can look similar and be that silly millimetre too short, or long, or wide.
Did that answer the question? If not, add a comment and I'll expand further as necessary. Cheers, D.
Posted on Jul 22, 2008
  • 35 Answers
SOURCE: Motor carbon brushes
hi try potts in derby babbington lane ,very help full
Posted on Apr 09, 2013
My belt is lubed and properly tightened. The belt will slow down intermittently randomly while running without anyone on it. Model NTL2495.0
first of all check the drive belt is loose or not. Drive beit connect with the motor and roller of the treadmill. its not possible to see the drive belt out side. you can only see it if you remove the motor cover. if its loose the try to tighten it. if its not the problem then the treadmill motor have some problem. Either the motor is faulty or the carbon brush is faulty. There is 2 carbon brush inside the motor which is replaceable, its used to take the voltage to the rotary part (armature) of the motor. If the contact with the rotary part and carbon brush is poor the this type of problem can occur. tyr to change the brush. Here i have added a video which demonstrate how to change the carbon brush of the treadmill motor. It not the exact model you have. but almost all treadmills have the same type of motor. even after replacing the carbon brush the treadmill shows the same problem then you have to charge the motor with a new one .
http://electro-medical.blogspot.com/
Fitness repairs
Nov 13, 2015 | Exercise & Fitness
Electrolux el 7020 Canister Vacuum shuts of continuously do i need to Change the Carbon Brushes
How old? If fairly new you should not need brushes, bad brushes would probably not allow the vacuum to run at all. Last time you changed filter? Sounds like the cover to the filter is not closing well enough. There's also possibility you have a clog in the wand or hose.
Mar 05, 2015 | Electrolux EL7020 Bagged Canister Vacuum
How to change carbon brushes on wt960 washing machine
Most washing machine motors do not have brushes.
Feb 25, 2015 | Washing Machines
How do you check/change the brushes on a freud ft3000vce?
I run these routers on a cnc mill that I made and have 3 running at once. What you need to do is take out the carbon brushes and there will be a little spring sticking out of one of the carbon brushes. I like to call this their "scam switch". Just rip off the spring that is sticking out of the carbon brush and put it back together. It will run for a long while again before the brushes wear out.
Dec 26, 2011 | Freud FT3000VCE Router
HI; How do i change the brushes in an electric
Motors with carbon brush can be detected due to the two brush access at two opposite sides. Open this up,
and you can already change the carbon brush.
However, if your motor doesn't brush access, the probability is your motor is a capacitor motor. Replacing
the capacitors will restore your motor proper speed.
Oct 27, 2009 | Coleman Powermate 4 Gallon Air Compressor
My generator starts and runs great, It is not
  1. Check for any blown fuse and replace. It can be traced directly from the output lines.
  2. Check field excitation. The field excitation is supplied by the battery to the excitation coil through a pair of carbon brushes. If the brushes are worn out, no excitation field is supplied and no output is generated. Replace carbon brush if found worn-out.
  3. Use an analog multitester to check the continuity of the carbon brush and the field coil.
Sep 24, 2009 | Northstar Generator 18 Hp, 10,000 Watt,...
Trying to change the carbon brushes but can't find a socket the right size any ideas?
all done it was the brushes on both sides of the motor and borrowed a tool set to do it only cost £7 each and the machine is back on
Apr 28, 2008 | Tricity Bendix AW1400W Front Load Washer
Remove carbon brushes from bosch washing machine
u can sometimes tip the washer backwards and with a torch u should be able to see the carbon brushes and the 2 star screws which hold them in undue these screws and the carbon brushes will pop out very easily for u to change them m8
Feb 24, 2008 | Bosch Classixx WFO 2466 Front Load Washer
WD62 is not spinning even after chaning new carbon brushes
when u changed the carbon brushes did u move the little metal pin to free the carbon off it must be able to come out then in with ease if not do this if u did then if the carbon brushes have got too low then it will have more then likely damage your motor m8
Feb 09, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Tools & Hardware - Others Logo
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
Jim London
Jim London
Ed Mac
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
