Question about Car Audio & Video
Stereo What could i do
Yes you can just match the colors of the wires from the stereo to the car plug
Posted on May 04, 2013
Philips model #24PT6341/37 Is this TV capable of switching from mono to stereo??
Its a stereo TV. And there is nothing to do to make it mono/stereo.If yo get stereo transmission then it will automatically change to stereo and vice versa.
If you wish to get some details; check the site linked here. Pull up older posts.
Jun 11, 2016 | Philips Televison & Video
How do I remove the radio out of the car for repair?
Cadillac Allante Bose Stereo Removal and Repair - YouTube
? 4:44
https://www.youtube.com/watch?v=gnoCICSMdto
Mar 2, 2009 - Uploaded by Factory Car Stereo Repair
Cadillac Allante Bose Stereo Removal and Repair. Factory Car Stereo Repair ... Cadillac Allante Promo 1988? ... Restricted Mode: Off. History
88-94 Cadillac Radio - YouTube
? 1:44
https://www.youtube.com/watch?v=IQyA-i_G_Lw
Feb 25, 2012 - Uploaded by mrzhvac
Cadillac Fleetwood Car Stereo Removal 1993 - 1996 - Duration: 3:10. Factory Car Stereo Repair 3,801 views. 3:10. 1990 Cadillac Brougham ...
Car Stereo Removal - Cadillac Allante Car Stereo Removal ...
Jan 08, 2016 | 1988 Cadillac Fleetwood
Mono stereo function
Tv Speaker; Stereo/dual Reception; Nicam Reception ...
www.manualslib.com > ... > Flat Panel TV > 141K TX > Owner's manual
LG 141K TX) Manual Online: Tv Speaker, Stereo/dual Reception, Nicam ... Stereo. Dual. Mono Sound Selection. In stereo reception if the stereo signal is weak, ...
Video Mode; Audio Mode; Still; Stereo/mono - ManualsLib
www.manualslib.com > ... > LCD-32CA9S > Owner's manual
Dec 21, 2015 | Televison & Video
Changed car battery and the dual car stereo won't work now. reset the stereo and the security light is flashing and the stereo still won't work?
Your solution depends on the brand and model number of your stereo system I take it your stereo system is Ruth is included in a anti-theft device this is highly technical and manufacture specific you need to follow the instructions for installing the system initially somehow your system lost sanity. You need to unplug the fuse that goes to your stereo turn your stereo switch on and let it sit for a day then return with the users manual and go through the installation sequence that has to do with connecting power and setting default settings other than that you have to contact the manufacturer
Nov 25, 2014 | Dual Xdma6540 Car Stereo Receiver
The stereo in my 2013 rzr 800s is making my rzr not start. The light in the stereo comes on but not the stereo and the rzr won't start, only click
This could be any number of issues, such as a fuse or it could be electrical such as wiring, did you recently upgrade your stereo system? And was is the make and model of your stereo?
Sep 01, 2013 | Polaris RZR Stereo System Top
How to can i replace stereo
see this : God bless you
Review your car's owner's manual to see if it has any tips on removing the current stereo. It may have a diagram of the wiring and the area where the stereo is installed.
  • 2 Disconnect the battery to avoid an electrical short while working with the wiring.
  • 3 Use a screwdriver to remove the retaining screws holding in your car stereo. Grab hold of the stereo and pull it toward you to remove it from the dashboard.
  • 4 Get a pair of DIN tools to slip on either side of the stereo, if the stereo connects to the dash using spring clips and bolts. These thin tools slide in easily, release the clips, and allow the stereo to come out easily. You may need to remove dash panels when bolts hold in the stereo. Take out the bolts and screws that hold the stereo in, and then simply pull it out.
  • 5 Look at the wires on the back of your car stereo. You should see 2 wires attached to the stereo. A wiring clip protects the stereo from vibrations and holds the wiring harness steady.
  • 6 Pry the wires up from the stereo and loosen them using a pulling/pushing motion. After working the wires back and forth, you should be able to pull the wires straight out.
  • Sep 28, 2012 | 1996 Toyota Tercel
    How do i eject a cd from the JVC KD G510 car stereo. A CD is already in there but i can't figure out how to get it out and put a new one in
    A malfunctioning stereo may least allow feature buttons to perform extractions of CDs. Depending on how the stereo was installed, the car would have to be powered on to attain stereo functionalities. Second, CDs have to be inserted with the readable media side facing the appropriate lenses to achieve results. A wrong insertion of the CD into stereo compartment may require forceful extraction. Observe the type of stereo to ascertain CD extraction also known as reset buttons. Usually a tiny area, the reset button allows inserting an object that forces the car stereo to eject stuck disks. Every mean to eject stereo disk have to be performed while the car is turned on to utilize the source of power. An unsuccessful attempt to dislodge CDs in stereo compartments would require auto electrician's consultation. An unsuccessful dislodge attempt usually requires acquiring a new stereo in replacement of the malfunction.
    Feb 02, 2011 | JVC KD-G510 CD Player
    Hi, i have a 1998 chevy malibu and was wondering how to remove the cd player? i wanted to install a new faceplate so i can get sub woofers in there
    Follow the below steps:
    1. Review your car's owner's manual to see if it has any tips on removing the current stereo. It may have a diagram of the wiring and the area where the stereo is installed.
    2. Disconnect the battery to avoid an electrical short while working with the wiring.
    3. Use a screwdriver to remove the retaining screws holding in your car stereo. Grab hold of the stereo and pull it toward you to remove it from the dashboard.
    4. Get a pair of DIN tools to slip on either side of the stereo, if the stereo connects to the dash using spring clips and bolts. These thin tools slide in easily, release the clips, and allow the stereo to come out easily. You may need to remove dash panels when bolts hold in the stereo. Take out the bolts and screws that hold the stereo in, and then simply pull it out.
    5. Look at the wires on the back of your car stereo. You should see 2 wires attached to the stereo. A wiring clip protects the stereo from vibrations and holds the wiring harness steady.
    6. Pry the wires up from the stereo and loosen them using a pulling/pushing motion. After working the wires back and forth, you should be able to pull the wires straight out.
    I hope the above helps.
    Good luck.
    Aug 23, 2010 | Car Audio & Video
    I have a rca truflat tv 27F522T how do i change it from mona to stero
    This is a stereo TV:
    From the manual:
    Stereo Capability: Includes built-in amplifier twinspeaker
    system; allows reception of TV programs
    broadcast in stereo.
    Use a stereo cable
    Sep 17, 2009 | RCA TruFlat 27F520T 27" TV
    I need to install a kenwood cd player into my 2001 ford explorer step by step
    goto the auto parts store and purchase a pair of stereo keys, fascia adaptor and wiring harness (you may need to get fascia and harness from a car audio store or circuit city.)
    Then use the stereo keys to remove the factory stereo. Push them into the small holes on the front of the stereo push them slightly outwards and pull to release the stereo. Unplug all the connectors from back keeping track of where they fall.
    Insert wiring harness into the stock wiring
    attach fascia in regards to its packaged instructions.
    Place cage from new stereo into the hole in the dash using the tabs on cage to secure it,
    Attach stereo to other end of new harness along with aerial (may need adaptor for this also depending on the new head unit.)
    Insert stereo into new cage and voila nice new stereo.
    Nov 27, 2008 | Kenwood Car Audio & Video
    Car Audio & Video Logo
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
