Question about Fujitsu Siemens ESPRIMO MOBILE V6535 Laptop Ac Adapter 19V-4.74A(5.5*2.5)mm 90W
Base System Device Driver - Fujitsu Siemens ESPRIMO MOBILE V6535 Laptop Ac Adapter 19V-4.74A(5.5*2.5)mm 90W
What is the base system device on my Dell laptop?
A base system device is any hardware device pre-installed on your laptop, such as a CD-rom drive, a USB port, an Ethernet port, video card, etc. These devices all require pre-installed drivers that were supplied by Dell with the factory setup. The most common problem is to have one of these driver files corrupted or deleted by accident. To solve a base system device driver problem, you have to go into Windows Device Manager (Look in Control Panel), and look for devices listed with yellow question marks or other indications that they have a missing driver. You either then go to the Dell support site for your laptop model, or the driver disk you may have gotten with your laptop, and reinstall the needed driver.
Jul 22, 2014 | Dell Inspiron Computers & Internet
Base system decive
when you get a base system device in the other devices category in device manager it usually means that either the chipset drive has not been installed or a lot of the time it's the sd card reader driver.
Nov 05, 2013 | ASUS K52F Notebook
Sony vaio vpcw21aaj base system device driver software
i can install all drivers through internet if you need contact me
Jan 10, 2012 | Sony Computers & Internet
Aspire 4520 driver missing..!!~
if you can download driver easy https://drivereasy.en.softonic.com/download or put on a device like usb stick and put on the aspire it will find the missing drivers and you just down load and install them, don't use automatic as you will need to pay for this to be activated but to load them yours self its free. been using it for years now my self.
Dec 23, 2017 | Conexant chipset 56K V.92 PCI Data/Fax...
Base system device driver not install
Direct install driver then reboot then it will show new hard ware found then update driver and give path of program file and update with XP driver
Jun 01, 2009 | Lenovo 3000 Y410 Notebook
Base system device and network controller driver error in device manager at win XP
"Base System Device" is your card reader, I had the same problem. If you dont use it jst disable the device, otherwise the drivers should be on your alienware Master CD, if not get a tech support guy to send 'em to you.
May 25, 2009 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Fujitsu Siemens ESPRIMO MOBILE V6535 Laptop Ac Adapter 19V-4.74A(5.5*2.5)mm 90W Logo
201 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
