Question about True GDM-7 Beverage Cooler
Unit will not shut off - True GDM-7 Beverage Cooler
Load disc, unit tries to load & play, unit shuts off. Turn power on to set time,etc,machine shuts off.
Laser pickup unit fault. The unit alongwith its flat connecting cable should be replaced. Contact any service technician. Electro help
Feb 23, 2015 | Samsung DVD-V2500 DVD Player
Unit won't shut off
Swithch yhe on/off button to left, mean off position and held it gor about three second. The unit will now shut down
Mar 12, 2014 | Garmin Nuvi 1490T
Is the thermostat wired to the unit? If so, note the wire locations and disconnect them. If the unit stops it's the thermostat. If the unit keeps running, it's the unit.
If the thermostat is wireless, change the battery and test the unit.
Nov 28, 2013 | Heating & Cooling
Can't open,in protect mode
Hi:
First disconnect all speakers from the unit and then try turning the unit on too see if it still goes to protect mode. Protect mode is a shut down feature that shuts down the unit because of a shorted speaker or speaker wires are touching each other. If the unit does not shut down after disconnecting all speakers then reconnect them one at a time while turing the unit on after each conncection until you find the shorted speaker. If it shuts down with no speakers attached to it then you have a internal problem with the amplifier section, probably a shorted output transistor in the Amp circuit or preamp circuit.
Jul 08, 2011 | Yamaha Audio Players & Recorders
My unit shuts off whenever it wants even with the charger plugged in. When I try to turn it on it comes on for a few seconds and shuts off again.
Is the Unit being fully charged before using it. Your Unit should have a Reset on the bottom of the GPS. Use a paper clip and press into rest hole with the Unit turned on. It will now shut off, restart the Unit. Usually this will helps with a lot of the problems. Good Luck!!
Jun 25, 2011 | Tomtom GPS
The Inner Fam Will Not Stop Turning And Continues To Blow Un Cooled Air
Hello my name is Heath it will be my pleasure to assist you. Make sure the fan switch on the thermostat is set to auto to turn the indoor blower off. If its the outside unit that will not shut off take the cover off the thermostat and disconnect the y wire and see if the outside unit shuts off. If the unit doesn't shut off then pull the cover to the outside unit and check to be sure that the contactor is not welded shut not allowing the outside unit to shut off.
Oct 11, 2010 | Goodman CLQ36AR49 Air Conditioner
AC Condenser motor will stop at 1pm but inside unit is still running but no AC. If I turn the AC unit breaker unit off and then an hour later turn it back on. The unit runs fine all day until 1pm. Had a...
Hi, the tech should have been able to figure the stat out with out a manual to see why the condenser is shutting off at 1:00 P.M. This is unusual for this to happen, unless it was winter and this is a heat-pump going into defrost, but just the fan would shut down. Does this unit have a box on it that was installed by your electric company that shuts the unit off during high peak conditions in the summer? This would cause it to shut down at the same time everyday. If not, it would have to be something in the thermostat that is set for it to shut off at that time. It still does not make since, as it would shut both the indoor and outdoor unit off, not just the condenser. Are you saying that just the condenser fan motor is shutting off, but the compressor continues to run until it shuts off on high head pressure when the fan stops, or does the complete outdoor unit shut down fan, compressor and all at that time??. It sounds to me like this outdoor unit has a time delay relay that has a fault in it may be shutting it off at this time daily? Please let me know if its just the condenser fan motor that shuts off, or if the complete unit is shutting off all together, this will help .
Sincerely,
Shastalaker7
A/C, Heating,
Sep 08, 2010 | Carrier 38CKC060 Air Conditioner
Unit shuts off slam door or hit unit and it comes
Replace the thermostat , and that will guarantee , to fix the problem . Where the temp is adjusted .
Dec 22, 2009 | Refrigerators
True GDM-7 Beverage Cooler Logo
20 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a True Refrigerator Expert? Answer questions, earn points and help others
