Question about Water Heaters
Ruud pacemaker water heater model PE52-2T
How to reset this water heater
4 Suggested Answers
SOURCE: Ruudglss Pacemaker electric water heater; still
Suspects include: Sediment in tank, shorting breaker, bad lower element, bad thermostat, water leak causing hot water to run out of tank:
Suspects that are excluded: Tank is not overheating, upper element is good, ECO reset button is not tripped, insulation and thermostat covers are present.
For troubleshoot resources and testing:
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Aug 26, 2011
  • 5245 Answers
SOURCE: how to drain ruud pacemaker water heater
Turn off water, turn off power, drain tank:
Copy following link for illustrations
http://waterheatertimer.org/Emergency-steps-for-leaking-water-heater.html
Posted on Aug 27, 2012
  • 5245 Answers
SOURCE: ruud pacemaker
Copy following link for testing, and replacing TP valve
http://waterheatertimer.org/How-to-replace-TP-valve.html
Posted on Oct 27, 2012
I am looking for magnesium anode rod for an electric Ruud pacemaker 10 gallon water heater model# PEP 10-1 and serial # 0598304245. Do you know the parts number? Bill
no
try contacting the manufacturer for the part or talk with a plumber supplies shop ( where plumbers get their supplies and parts ) to see if it is available
it will be a sacrificial rod to prevent the tank from corroding out especially around the heating element fittings
Jan 29, 2017 | Water Water Heaters
Changing thermostat on ruud water heater
1) Copy following link to adjust water heater temperature.:
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
2) Add a comment if more help is needed. Jan 2013
Jan 26, 2013 | Rheem Ruud Commercial Electric Water...
I have a ruud ruudglas pacemaker electric hot water heater. model number pem52-2b. first person to ake show in the moring has hto water for about 5mins and then it turns luke warm . when you wati about 10...
sounds like thermostat but element can be checked with a multi-meter, turn power off at fuse panel, pull one wire of element put multimeter on both screws on element using continuity setting should show continuity or beep as most do if not its burned out and needs to be replaced
Dec 01, 2012 | Water Heaters
How to drain ruud pacemaker water heater
Aug 26, 2012 | Water Heaters
Ruudglss Pacemaker electric water heater; still produces hot water, but the hot water last (in shower) for a much shorter time. The most likely cause is.?
Aug 26, 2011 | Reliance & Lowboy& Electric Water Heater
Water Heaters Logo
112 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
