Question about Car Audio & Video
I was listening to my stereo system in my car and all the sudden all the speakers stopped working and the sub has a constant and quick vibration. I disconnected the sub but the other speakers still aren't working. I have 4 Jl audio speakers and 10 inch w3 Jl audio sub run on a 5 channel 1500 watt amp. What could the problem be?
    Genius:
  • 1,144 Answers
Check the out put of the head unit . check the out put on amps check speakers do this all with a DMM Digital multi meter, check that amps aren't in protect. check ground on head unit. if you dont know how go to you tube and type in such as, this how to test speakers with a DMM many videos on all subjects.how to test amp out put with the humming you may have a short or a blown speaker some where.
Posted on May 06, 2013
5 Suggested Answers
pjstanley
  • 185 Answers
SOURCE: one of 2 subs stopped working.
ya the sub is blown or the amp channel is blown
Posted on Apr 10, 2008
pjstanley
  • 185 Answers
SOURCE: If I buy 2 12
two amps and get a 2 farad cap please because if u dont u could melt wires together cause a fire or toast ur alt.
Posted on Oct 31, 2008
  • 12 Answers
SOURCE: jl sub not powering on
ok try your sub on another amp is first find out if that works or not if it works then there's a good chance you amp is knackered
Posted on Jan 30, 2009
  • 733 Answers
SOURCE: I hooked up my two 10 inch JL Audio W3v2 2 ohms to
try one at a time. if they work then try hooking them up differently. if none work, then check to see that your amp is not in protect mode. if amp is ok, then check to make sure you have your rcas connected to your amp. in other words, re-check all your wiring. if still nothing, try your amp on your friends car and vise versa.
Posted on Apr 01, 2010
Why does it play and stop but monitors work fine?
Some subs are switched on and off according to the level of the input signal. The purpose of the switching is to prevent initial "pops" and sub-audible pulsing from damaging the speaker. To the listener, however, it creates the sensation of a sudden loss of hearing followed by restoration.
Jan 21, 2016 | Samson Resolv Sub88 Subwoofer
I have the Klipsch Sub-10 Subwoofer, and it no longer plays music. Now it hums (vibrates constant) and corresponds (louder or softer) with volume control. Light is home but no one home situation. V
Does the subwoofer have the same hum when the input cables have been unplugged? Many input cables use very fine conductors, which often fail. A bad cable will often introduce a hum and prevent a signal from getting through. If the noise is still present without the input cable(s) connected, then repair options are limited. No schematics are available. There's a daughterboard that has been available, but its failure usually causes the system to die (short-circuit). The cost to repair the amplifier may be close to the cost to replace the entire sub.
Sep 14, 2014 | Klipsch Synergy Sub-10 Subwoofer Speaker
The subwoofer output on my Kenwood VR-606 has suddenly stopped working. I have tried the "setup" several times, turning the subwoofer off and back on. Also, when I first power up the system, it emits a low...
It sounds like the problem is not with your VR-606. If you hear a hum from the sub, the problem is more likely to be in the sub's built-in power amplifier. However, it is worth resetting the amplifier to factory presets. To do this, unplug the power cable from the mains supply and reconnect whilst holding down the power on/standby key. If the hum persists, connect any powered speaker to the sub-out socket, power on and listen for the hum. If no hum then suspect the powered sub amp. Turn the sub on with no connection to the Kenwood VR-606. If hum persists, the sub has a problem and will need to be replaced or repaired. By the way, you said there is a low frequency hum through the 'speakers' for about 30 mins. Is that all speakers or just the sub? Hope this helps.
Cheers, Don.
Jul 06, 2014 | Kenwood VR-606 Receiver
I can't get A B the sub and the center to play at
Page 26 of the manual: If you turn on the SPEAKERS B system, the SPEAKERS A system also reproduces stereo sound automatically. (The listening mode is set to "Stereo.")
Aug 14, 2011 | Onkyo HTR500 Receiver
I need to know the color codes for the radio rear sub.
2000 Ford Expedition Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: White/Purple
Car Radio Accessory Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: Blue/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Blue
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6′ x 8′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): White/Red
Left Front Speaker Negative Wire (-): Brown
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): White/Orange
Car Audio Rear Speakers Size: 6′ x 8′
Car Audio Rear Speakers Location: Rear Doors
Left Rear Speaker Positive Wire (+): Light Blue/Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Purple/White
Right Rear Speaker Negative Wire (-): Light Blue
Dec 24, 2009 | 2000 Ford Expedition
Wierd problem with my subwoofers please help
It sounds like your RCAs are pickin up noise somewhere, are your rca cables next to your amp power wire? this could be the problem. Just recheck your signal wires and make sure they aren't close to any significant power cables. Also does the noise only come from your subs or your car speakers to? If it comes from all your speakers you may have a headunit problem... hope this helps
Sep 30, 2009 | Orion 12DVC Car Speaker
Subwoofer pushing out problem
it sounds like one channel in your amp had shorted and letting dc go to the speaker...a speaker is an electromagnet and requires ac to make it pulse..the amp has a blown channel and would have to be repaired and a factory service center...there is no quick fix..
May 27, 2009 | Lightning Audio B1.10.4 Car Subwoofer
Sub works but doesn't sound right
hey been there before u need new rca wires form ur radio to the amp.
Nov 12, 2008 | Jl Audio 12W3 Car Subwoofer
Subwoofer noise
You didn't say is your sub active or passive.If its active first check signal cables from theater system,power line of the sub, it has to be the same phase as the system.If its passive take a voltmeter disconnect the sub from the system and measure for DC voltage on the SUB output on the system when its OFF.If DC voltage is present your amp is damaged.It can also be that the preamp circuit for the sub doesn't mute the input when unit is on stand by and you hear frequency of your power supply (50-60Hz) on the sub
Mar 09, 2008 | Audio Players & Recorders
Sub doesnt sound loud
try to change subs with your friend to find out if the problem is on amplifier or on sub wofer
Nov 21, 2007 | Q-Logic QLT-.3508SS Car Subwoofer
Car Audio & Video Logo
44 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
